Nitrogen tanks and tire refills
Discussion in 'Wheels & Tires' started by Explor, Apr 2, 2014.
  1. Apr 2, 2014 at 6:01 PM
    Explor
    Explor [OP] Don’t take the trip ... let the trip take you
    Northampton County Pa.
    FUN
    TRD valve stem caps , A Chimney & Back up camera. , Cooper STMaxx 255/80/17, SCS Dark Bronze wheels, , bed matt, weathertech floor liners and bug deflector , flyzeyez dash and glove box light , Best Top supertop, Brute Force Sliders , Bumpers ,KC back up lights, vent shades, tinting, superwinch 9.5 , Factor 55 winch thimble , KC ditch lights , BAMF IFS skid plates , Tepui Ruggedized RTT , Awning , Bed light kit , Hood Struts , Camburg UCAs ,Bud built gas skid , all pro differential skid , cbi jerry can holder , 15lb CO2 Tank , URD short shift , Defined engineering shackle bolt crossmember, Clazzio seat covers , 4:56 Nitro gears , ARB rear locker, CMKA12 compressor. Super Bump Stops, Bushwacker Flares , CBI bed rack , king resi front 700# , OME Dakar, Bilstein 6100's 10" light bar diode dynamics , AV monster fogs , TC bed reinforcement brackets , TC spindle gussets w swaybar Yeasue Ham , cb
    I need some help in determining how many 33" tires can I fill with a 40 cubic ft nitrogen tank ?
    Please Do Not go into all the BS about nitrogen and C02 ... I read it all !
    I just want to know how many tires I can expect to fill up with my 40 Nitrogen tank ?
    33 " tires 17" rims
    Thank's for your help : )
    sorry if this was posted before ....I did a search .... and searched the web for 2 hours .... I'm done
  2. Apr 2, 2014 at 6:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Om not really sure how to calculate that, other than to fill them up until the tank is depleted.
  3. Apr 3, 2014 at 8:23 AM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Too many variables, but it depends on the pressure the tank is at mainly, 0 PSI = 0 tires. 2000 psi = volume of gas in tank @ tires pressure / volume of tires @tire pressure. Temperature is also factored into here as well.
  4. Apr 3, 2014 at 8:39 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    One of the popular tank companies has a chart that shows it. On my phone and forget what brand or I would search and link it. P something I think.
    Oh and co2 FTW lol
  5. Apr 3, 2014 at 8:43 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    If you had more info, I could tell you. Pressure on tank, ambient temp, what size are your tires and rims? Also, what pressure do you want in the tires?
  6. Apr 3, 2014 at 4:21 PM
    Explor
    FUN
    Ok ... The key here is 40 cubic feet ... It can b 40 cf at 10 psi of pressure or 40 cf at 2000 psi .... 40 cf is 40 cf ....
    A 20-40-60 CF tank from the welding supply all have 2000psi ... The difference is the Volume 20 being 20 cubic ft - - 60 being 60 cubic ft .... Volume ...
    As I mentioned in my original post ... 33" tires , 17" rims .....
    I don't want to sound rude , because it's not my intention..... But this kind of stuff makes me laugh at how every article I read (for 2 hrs) ! and now here where I ask the question ... Everybody wants to get technical ... Forget the temperature , the altitude , the phase of the moon or weather the tide is in or out at 0:430 hours ... Someone here must use a nitrogen tank as back up air ?
    I don't need an answer of 3.257 tires ... Just an approximate ...
    If I go from 25 psi to 45 psi how many tires can I do that to with 40 CF ?
    If I go from flat 0 psi to 45-50 psi how many flats can I fix @. ?
    I believe I should not have been lazy and did the math myself ... I took a shortcut because I'm working so many hours at work I don't have time ... Figured somebody here uses a 20 CF or a 40 CF tank ?
    I know I'm not the only person in the world who uses a nitrogen tank for air ups
    Thanks again ....
  7. Apr 3, 2014 at 5:41 PM
    Explor
    FUN
    According to my simplified calculations ... I could do 5 tires from flat to 40-45 psi
    "How much wood could a Woodchuck chuck ... If a Woodchuck could chuck wood"?
  8. Apr 3, 2014 at 5:58 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Go with liquid CO2 - you'll get far more gas out of a cylinder and you can get a setup fairly cheaply.
    http://www.lieblweb.com/liquidco2.html
    Unless you could do liquid nitrogen - which, I don't think you can safely & cheaply - you're not gonna get nearly as much gas out of pressurized tank VS pressurized / liquid.
  9. Apr 4, 2014 at 6:43 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Yeah, I was going to calculate it down to the last molecule. I use Nitrogen in my tires as well. Glad you got ot figured out on your own.
