Nitro Ridge Grapplers XL tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jp5385, Jan 3, 2022.
  1. Jan 3, 2022 at 11:31 PM
    Jp5385
    Jp5385 [OP] Well-Known Member
    2014 TRD Sport V6 4x4
    The stock tire size for my Tacoma is 265/65/r17 and they only come in XL for the Nitto Ridge Grapplers. Are XL tires similar to C rated tires?
  2. Jan 3, 2022 at 11:51 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
  3. Jan 3, 2022 at 11:58 PM
    URD07taco
    URD07taco Member
    2007 Tacoma sport 6speed
    Bilstein coils bilstein shocks urd short shifter urd supercharger
    My truck came on 265/70/r17. It’s only an inch taller than 65s try and see if 70s come I c rated
  4. Jan 4, 2022 at 12:12 AM
    Jp5385
  5. Jan 4, 2022 at 12:13 AM
    Jp5385
    They only come in XL or E rated. I feel like the E rated tires are overkill for what I’ll use them for.
  6. Jan 4, 2022 at 1:44 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    I just got these tires about a month ago coming from duratracs . So far im happy with them 29911AD8-CF6C-4738-A265-2AB6B053B145.jpg
    drizzoh, Jp5385[OP] and Aqualoon like this.
