NGK 6619 Iridium Spark Plugs LFR6AIX-11 tips melted way.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Glamis, Feb 5, 2022.
  1. Feb 6, 2022 at 2:29 PM
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    Those are probably fake plugs. I pulled a set off my 2014 Tacoma and my 2008 that I put on and pulled them at about 10,000 miles when I realized they were fake. I will either buy from local store or Sparkplugs.com. I change the laser iridiums at 100,000 miles on the Tundra and I will change my Tacoma at 80,000 miles.
  2. Feb 6, 2022 at 2:46 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Weird things can happen when the incorrect plugs are installed. The internal resistance and heat range may be different.
    I can't prove it over the internet but I've seen incorrect plugs (iridium in place of copper) cause CAN/BUS communication issues, random stalling and misfires
    Not trying to crap on your new Autolites but I won't let those anywhere near a car. Too many experiences with intermittent misfires
    2015WhiteOR likes this.
  3. Feb 6, 2022 at 4:00 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    On Amazon purchases, to help ensure you aren’t sold counterfeit anything, make sure the item(s) you are buying is/are coming from an Amazon warehouse and not a third party vendor. Iridiums can last 100K but they should be pulled for inspection at about 60K-70K. On my first set of NGK iridiums, the gap was out of spec at 110K, but not nearly as bad as the OP’s. For my second set, I got Denso Long Life iridiums, they have a hardened electrode, but I will still check them by 70K.
  4. Feb 6, 2022 at 4:11 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I've replaced a lot of plugs in my days, always go with NGK, never seen an NGK look like that.
    Me thinks a fake.
  5. Feb 6, 2022 at 4:13 PM
    Bishop84
    Bishop84 Well-Known Member
    Autolites flood in the winter here, I'd rather run your old plugs than autolite.
    Just had one towed in from the mountains and no matter what I did, the autolites would not fire, I used heat, lighters, evaporation everything. The ceramic was even distorted.
  6. Feb 19, 2022 at 3:07 PM
    Glamis
    Glamis [OP] date joined 03-18-2009 this is my new ID
    Anaheim & Glamis, CA
    08 PreRunner DC/LB Sport-2 Debadged
    Debadged, TRD exhaust, Devil Horns, Pop n lock, Stock wheels chromed, K&N, DRL's on/off switch, bed mat, lock & unlock beeper, Disable Seatbelt Warning Chime, 12v Cigarette lighter plug always on, 2009 LED Brake lights, TSP springs, Fire Stone Ride Air springs.
    the truck is like new. MPG is back. Also my Towing power is back. the truck did not seem labored as much.
    Hongster, TnShooter and Key-Rei like this.
