Newer Tires, Poor gas mileage, what is main cause?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wolfgmuller, Jun 11, 2021.
  1. Jun 11, 2021 at 11:29 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Both sets use Toyo Open Country ATIII C-load tires.
    265-75-16 on TRD beadlocks to 265-70-17 on TRD Rock Warriors are 8lbs each heavier which roughly equates to 320lbs of chassis weight.
  2. Jun 11, 2021 at 12:31 PM
    Wolfgmuller
    Wolfgmuller [OP] Member
    For sure that is good perspective, it’s like a 3 mpg average drop, so it winds up like 350-400$ a year, which isn’t a ton in the grand scheme but it adds up. It’s nice to try to understand what is the actual cause, considering I drive 99% of the time on the highway, is it more the wheels overall diameter or more the tread depth/knobs/road friction? But Sounds like tire weight and some combination of the others. I appreciate your input to help me understand how the tires affect fuel economy!
    hiPSI[QUOTED] likes this.
  3. Jun 11, 2021 at 12:57 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You truly won't know the ramifications for about a year's worth of data. Write down mileage at fill up and next fill up divide the mileage by gallons used. Only truly accurate way.
    tacoman45 likes this.
  4. Jun 11, 2021 at 1:05 PM
    Ol'gray mare
    Ol'gray mare Well-Known Member
    West, Tx
    2017 MGM DCLB TRD OR Geared, locked and tuned, rear disc brakes. 2018 TRD PRO White boss' bone stock
    Build thread coming soon.
    I run a 295/75/16 toyo a/t 3,the truck came factory with 265/70/16. If I go by the computer doing the milage for me I average around 13.5 to 14 mpg. If I measure my milage using a gps for true milage and devide that by gallons I'm getting 15.5 to 16 mpg. You need to have a way to measure true milage after bigger tires or you never get true results.
  5. Jun 11, 2021 at 1:15 PM
    Wolfgmuller
    Ya sounds like I need to verify if the dealership calibrated that or use the old fashion method to determine mileage.
  6. Jun 11, 2021 at 1:15 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Not the weight. There are multiple factors and each only hurts fuel mileage slightly, but combined it adds up. The fact that most of the other factors also make the tires heavier is coincidental. If you keep all other factors the same. Same size tire, same tread type etc. and only change from a 40 lb standard tire to a 55 lb LT tire the fuel mileage will remain so close that you'll need to go several digits to the right of a decimal point to measure it.
    I've been using both standard P series tires and much heavier E rated tires on trucks and SUV's since the 1970's. I've had both types on multiple vehicles and as long as I stayed with the same size and a similar tread I've never noted any difference in fuel mileage. I have noted some difference in acceleration and ride comfort.
    BUT... when you go to a taller tire the engine has to work harder.
    Wider tires with more aggressive tread greatly increase rolling resistance. If you're coasting downhill you can see a dramatic difference between tires. This is the biggest culprit. Guys who go tall with skinny pizza cutter tires don't see nearly as much loss of fuel mileage. Especially if you avoid aggressive mud tires.
    3-4 PSI difference can make 1-2 MPG difference, keep the tires aired up. Bigger tires ride rougher and lots of guys underinflate them to get a better ride.
    The taller tires mess with the accuracy of your odometer meaning you're actually driving a little farther than you think you are and getting a little better MPG than you think. But this isn't a huge factor. If you do the math to get the correct mileage expect about 1/2-1 MPG difference.
  7. Jun 11, 2021 at 4:18 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Yup, i dropped a little bit fuel economy when i went to 265/70 16's a/t tires from the stock 245/75 16's all weather ones. Sill get up to 23 mpg highway. In town is rougher than the stock fuel mileage.
  8. Feb 8, 2022 at 4:29 AM
    capequahog
    capequahog Well-Known Member
    Cape Cod MA
    17TacomaDblCabTRDSport
    in the dreaded black
    2017 sport was getting 19mpg on factory originals, went to Michelin Defenders and now getting 16mpg, around town driving only, not much highway, per the readout thigamajig, seems like a lot
  9. Feb 8, 2022 at 5:42 AM
    coma toy
    coma toy Off Road Taco
    Both. No brainer.
  10. Feb 8, 2022 at 5:55 AM
    Beau_Higgins
    Beau_Higgins Well-Known Member
    I have a TRD off-road manual that came with the stock 31" Goodyears and I got about 20mpg with those. I replaced the stock tires a year ago with the same factory 31" size and chose slightly more agressive General Grabber AT2's (not the heavier ATX version). Even with tires being the same size and about the same weight as stock, the more agressive tread has dropped me to about 17 mpg, alone. So yeah, as others said all those factors are definitely having an impact.
    Panchito V likes this.
  11. Feb 8, 2022 at 6:00 AM
    Montana_Actual
    Montana_Actual ;)
    Good revival.
    Not many of these floating around.
  12. Feb 8, 2022 at 8:43 AM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    I know this thread is from last year, but there are no fuel pump recalls on ‘21s. They started fixing them before then, so it wouldn’t make sense for Toyota to keep installing the known faulty ones in their new trucks after they’ve already been correcting the problem in the older ones (more work, more money, more liability).
    I’d say it is a 110% chance the dealership did not recalibrate your speedo when they mounted your new tires unless you specifically asked them to. The difference in average MPGs going from stock 31s to 32s is about .5. So if your dash says you’re getting 17.5 average, you’re really getting 18, but the truck’s calculator isn’t that accurate. Whenever I calculate it myself at the pump, my dash always seems to be off by +/- 1 MPG.
  13. Feb 8, 2022 at 8:50 AM
    brian2sun
    California
    Nah, tire and wheel weight absolutely play a significant role in fuel mileage. The heavier the tires and wheels are, the more gas the engine uses to get them moving every time you accelerate from a stop and also when going uphill. 15 or so additional lbs. on each corner can easily cost you 1-2 MPGs (not decimals as you say).
    tarbal255 likes this.
  14. Feb 8, 2022 at 10:00 AM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    whoa this is a cool website!
  15. Feb 8, 2022 at 1:04 PM
    #35
    Mr-Paul
    Mr-Paul Well-Known Member
    Paul
    2017 Qucksand Tacoma SR5 4x4 V6 Access-Cab
    Larger diameter tire.
    Tires weight more.
    More aggressive tread pattern.
    And…
  16. Feb 8, 2022 at 1:11 PM
    #36
    AwesomeLaw68
    AwesomeLaw68 Well-Known Member
    Lawson
    2022 Tacoma Off-road edition
    Brand new.
    Technically the larger tire would travel further making less of a revolution that the smaller diameter tire, so its probably the tire itself big that
    they weight to much including the wheel weight.
  17. Feb 8, 2022 at 1:14 PM
    #37
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    Good job, kitten killer.
  18. Feb 8, 2022 at 1:22 PM
    #38
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I notice my MPG goes down during colder months and back up during warmer months. This could also be a factor too.
  19. Feb 8, 2022 at 1:30 PM
    #39
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Larger wheels will generally have more rotational inertia, even at similar weight, than smaller wheels.
    It’s not about weight on the scale, it’s about rotational inertia.
  20. Feb 9, 2022 at 8:36 AM
    #40
    RandomHero01
    RandomHero01 (Amateur Human)
    Oregon
    2021 Tacoma DCSB TRD Sport
    I'm always curious about these kinds of numbers. I've tracked every gallon through my truck for almost a year now and I'm at 21.04 MPG average. That's also currently dropping now that I'm on my third tank since installing LT255/75R17 KO2s (C rated) on 4Runner Pro wheels. Before was stock. My first tank was 18.01 MPG and second was 18.09 MPG with mixed highway/city driving and a number of relatively light loads in the bed as I moved across town. I also KDMAX PRO tuned just before the wheels/tires were installed.
    Are you tracking your MPG using the onboard computer or continuously calculating based on miles/gallons between fill ups? I ask because numbers seem to vary widely and I'm pretty light on the throttle with the above results.
