New wheels! Volk TE37x Progressives
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JohnnyTRD06, Feb 27, 2022.
  1. Feb 27, 2022 at 3:19 AM
    JohnnyTRD06
    JohnnyTRD06 [OP] Well-Known Member
    2017 Tacoma TRD Pro
    Smoked WeatherTec rain guards Access roll up bed cover Tinted front side windows TRD Cold air intake TRD Billet oil fill cap Spartan X Customs hood scoop lightbar Meso Customs dual mode LED interior lights Meso Customs V1 mirror turn signal lights Meso Customs sequential taillights Meso Customs puddle lights and switch kit Putco Nitro Lux LED headlights CBI Off-Road rear skid plate CBI Off-Road gas tank skid plate Kicker DS series door speakers Kicker dash tweeters Overland Tailor Tuning tune
    Goodbye TRD Pros......and Hello Volk Racing TE37s!
    The weight of these things is astounding. Even with tires....it's a massive difference in weight. I can pick these up with 4 fingers in the barrel of the wheel, no issue.
    They lightened the steering and made it more responsive, especially at speed.
    They also livened up the trucks acceleration too, with a massive reduction in unsprung rotational weight, adding to the tunes performance bump.
    I'm keeping my stock wheels with all terrains for off roading....but for most of my driving on road, these greatly improved the comfort, noise, and handling.
    And best of all...with the larger offset...it's got a MUCH nicer stance too. Not too much, but out just enough.
    They do rub the aftermarket mudflaps at full lock, but after a little trimming, I can easily live with it.
    The wheels are 16x8 -20mm offset
    Lets see some of your rides with Volk, Enkei or other forged mono-block wheels!
    IMG_20220226_153403_483.jpg PXL_20220226_131707823~2.jpg IMG_20220226_153605_887.jpg PXL_20220226_043307409~2.jpg IMG_20220226_153605_948.jpg
    Polythemus, Siblue, CreoUCLA and 8 others like this.
  2. Feb 27, 2022 at 3:24 AM
    JohnnyTRD06
    2017 Tacoma TRD Pro
    For anyone wondering,
    Just the wheel weight alone changed 10 lbs per wheel. From 26 lbs to 16 lbs. That's 40 lbs of unsprung and rotational weight removed.
    The tires are a bit lighter too. I dropped about 18 pounds total off each wheel/tire.....and about 4 lbs switching to forged aluminum lug nuts.
    That's a total of 56 pounds of weight that the driveline no longer has to spin.
    Rotating unsprung weight works at a 1 to 4 ratio to sprung weight. So for every pound of rotating weight removed, it's equivalent to removing 4 lbs from the truck itself.
    So the total of 56 lbs taken off the driveline will have the added effects of removing 224 lbs of dead weight from the truck, almost like taking a quad out of your bed.
    It made a huge difference in turning sensitivity, acceleration, and braking.
    Polythemus, Vinny C, pinochle and 4 others like this.
  3. Feb 27, 2022 at 3:59 AM
    JakNY
    JakNY 30yr/360,000mi Plan
    Jack
    NNY
    21 TRD PRO DCSB SUPER WHITE
    Impressive numbers, like the look! Rotated to a set of light summer setup on a prior truck and it was a lot of fun. Curious if you considered 17" wheels and road tires. Would you mind sharing where you sourced these?
    JohnnyTRD06[OP] likes this.
  4. Feb 27, 2022 at 4:04 AM
    JohnnyTRD06
    2017 Tacoma TRD Pro
    My tuner actually had these for sale off his truck. He was planning to go to 17s....and put these up. I bought them off him with decent tires, tpms sensors, lugs and center caps all in one shot.
    I was trying to stick with 16s because I had a fairly new set of Wildpeak AT3Ws on my stock Pro wheels, and I wanted to swap them over at some point. Though, now after driving this truck with road tires again...I may just swap wheel/tires to go off roading and what not.....then switch back for most of my normal driving.
    Arcticdc5 likes this.
  5. Feb 27, 2022 at 5:26 AM
    sdshack
    sdshack Well-Known Member
    TN
    ‘18 Tacoma OR 6MT (SOLD) - ‘99 4Runner Limited - ‘10 Cayenne TSSY - too many BMWs
  6. Feb 27, 2022 at 6:10 AM
    JakNY
    Jack
    NNY
    Makes sense, nice to have options :thumbsup:
    Thanks for this. Late to the party by a few years I see :oops:
  7. Feb 27, 2022 at 6:35 AM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    16lbs!? Whoa
  8. Feb 27, 2022 at 7:08 AM
    WinterFalco
    WinterFalco Well-Known Member
    Donald
    2018 Midnight Black SR 4x4 Double Cab
    Added aftermarket Rims and Tires, Fog Lights, Mudflaps, Entune with Nav
    They will also improve your MPG. I changed my rims for aftermarket rims that were lighter, and I also changed to 4 lb each lighter tires.
    Your rims look good, congrads!
  9. Feb 27, 2022 at 8:04 AM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    :thumbsup::thumbsup:
    Two thumbs up!
  10. Feb 27, 2022 at 7:34 PM
    JohnnyTRD06
    2017 Tacoma TRD Pro
    Took a few more pics tonight!
    Polythemus, rsimi72 and rip ej1 like this.
  11. Feb 28, 2022 at 5:54 AM
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    Nice truck OP - really like that classic Toyota color scheme decal. Looks killer on the white.
    Just got some TE37xt's and I was just as surprised as you that 10lbs less per wheel would make such a noticeable difference in throttle response and handling. I am currently on the highest (sport) throttle of the KDMax Pro and am likely going to go down to the mid (normal) setting.
    rip ej1 likes this.
  12. Feb 28, 2022 at 8:02 AM
    rip ej1
    rip ej1 Well-Known Member
    Daniel
    NorCal
    2020 AG TRD Pro
    Love it, thanks for posting your pics OP! I always wondered if I'd have too much poke but it doesn't seem so much now. I've got the exact wheels (in bronze) but haven't had a chance to install them yet. Thinking of getting 265/75 AT3Ws. Do you suspect any rubbing other than the mudflaps (oem)?
  13. Sep 26, 2022 at 2:55 PM
    WiscoTaco4x4
    WiscoTaco4x4 Well-Known Member
    Brady
    2015 SR5 ACLB 4x4
    I am curious what site are you guys buying these from? I am struggling finding them from a site that looks legit and not going to scam me
  14. Sep 26, 2022 at 3:18 PM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    I personally have bought from these sites for my Volks:
    • Versus Auto Sports, instagram DM sales
    • Vivid Racing
    • Showstoppers off road
    I will also not hesitate to buy from these
    • system motor sports
    • evasive motor sports
    • speed image
    • icbmotorsport
    They are all legit, but some are priced higher than others so do check prices and availabilities
    WiscoTaco4x4[QUOTED] likes this.
  15. Sep 26, 2022 at 3:25 PM
    DCB5150
    DCB5150 Well-Known Member
    Where and how much trimming on the flaps? Looks great. I like the meaty look and would go with an argent color.
  16. Sep 26, 2022 at 3:38 PM
    msgs350
    msgs350 Well-Known Member
    PNW
    2020 Tacoma OR Cement DCSB 4x4 AT
    Some Mods
    I've bought from: Showstoppers Off road, System Motorsports and ICB motorsports. All three vendors will pisck-up your phone calls and tell you what they have in stock or when/if they can get the specs you are looking for.
    Just to add, ICBs (Link: https://www.icbmotorsport.com/6x1397.html) website has been reliable in reflecting actual inventory.
  17. Sep 26, 2022 at 3:38 PM
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    What ever retailer stocks these will ask for a premium since they’re long discontinued.
  18. Oct 2, 2022 at 9:11 PM
    JohnnyTRD06
    2017 Tacoma TRD Pro
    Finally had my Wildpeaks mounted onto the new wheels a few days ago. Looks so much better than the old tires!PXL_20220924_205112708~2.jpgPXL_20220925_130752525.jpg PXL_20220925_130941582.jpg
  19. Oct 2, 2022 at 11:53 PM
    thewrongtone
    thewrongtone Well-Known Member
    Central AR
    ‘22 Army Green TRD/OR
    TRD Lift
    Damn, that’s a killer look! I’d slap my mom for a set of TE37s like that.
    what size wildpeaks are you running?
  20. Oct 4, 2022 at 3:25 PM
    JohnnyTRD06
    2017 Tacoma TRD Pro
    Stock size.....265/70/16
    thewrongtone[QUOTED] likes this.
