new wheels means new alignment??
Discussion in 'Wheels & Tires' started by toyotahenry, Dec 5, 2022.
  1. Dec 5, 2022 at 3:43 AM
    toyotahenry
    toyotahenry [OP] N/A
    Henry
    Houston, Texas
    2021 TRD OFF ROAD 4X4 ARMY GREEN
    one of the local shops near me had told me that if i get a new wheel setup then i would need an alignment to prevent any premature wear and tear.. does this sound like bologna to you folks? TIA!
  2. Dec 5, 2022 at 4:14 AM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    Your caster and camber will be the same. I'm thinking the toe could change if you change tire size. This would explain why my tires wore funny when I went to 33s without an alignment. I would think just the wheels wouldn't matter. I ran the same tires when I went to a negative offset wheel and I went 30000 more miles with perfect wear
  3. Dec 5, 2022 at 4:21 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    It would be a good idea to have the alignment checked after you get new wheels or tires.
    It might not need a major adjustment, but get it checked.
  4. Dec 5, 2022 at 4:23 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    A change in geometry- wider wheels or different backspacing would suggest a need to align for me.
  5. Dec 5, 2022 at 4:48 AM
    toyotahenry
    Henry
    Houston, Texas
    more context*
    i plan to use the reuse my current tires. i am simply just installing new wheels with different backspacing.
  6. Dec 5, 2022 at 4:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    The hubs are what's being aligned. IE the wheel / tire combo just goes where the hub tells it to.
    OTOH, if it's been some time since your last alignment, and depending on use of the truck, it might be time anyway.
    drizzoh and SR-71A like this.
  7. Dec 5, 2022 at 5:19 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    If your tires carry a mileage warranty a lot of the big box tire places require an alignment or no warranty.
    I’m sure they offer a package for rotation and alignments also.
    Most of these shops have low paid employees also beware.
    BigEasy likes this.
  8. Dec 5, 2022 at 5:42 AM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    I’d get one. Your lower control arms are mounted by rubber bushings so more backspacing = more leverage on those bushings so they might flex and tweak your alignment a bit
  9. Dec 5, 2022 at 7:19 AM
    toyotahenry
    Henry
    Houston, Texas
    discount tire doesn’t do alignments unfortunately Lol
  10. Dec 5, 2022 at 8:55 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Changing wheels AND/OR tires does NOT change your alignment settings.
    You do not need to get an alignment if you only replace your wheels and/or tires. But, if your current tires are wearing funny, it's been a long time since you had an alignment or otherwise think you may need one then go for it. But, the change you're making doesn't require you get one.
    toyotahenry[OP] and 5nahalf like this.
  11. Dec 6, 2022 at 10:00 PM
    toyotahenry
    Henry
    Houston, Texas
    so you do suggest following through with an alignment.. correct?
  12. Dec 7, 2022 at 4:32 AM
    Clearwater Bill
    Billy
    Largo Florida
    Maybe. Consider the rest of my post. Only you know those conditions..
  13. Dec 8, 2022 at 10:24 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    Wheels aren't changing any of your alignment settings so do you HAVE TO get an alignment? No. But if it's been a while since you had one or you want to have them add some caster to push the front wheel and tire forward for clearance from the cab mount or mud flaps then it's a good idea.
