New Wheel Hub & Unit Bearing Assemblies
Discussion in 'Marlin Crawler' started by Marlin Crawler, Aug 14, 2024.
  1. Aug 14, 2024 at 1:57 PM
    Marlin Crawler
    Marlin Crawler [OP] Well-Known Member Vendor
    Fresno, CA
    We are now pressing together and pre-assembling KOYO Unit Bearings with Toyota Spindles for Type 3 & 4 4WD IFS Knuckles!
    This is everything you need to replace your wheel hub parts in an easy-to-install pre-assembled Japanese-made long lasting and high performance unit that does not require a press or special tools to install!
    Pre-assembled parts:
    • Toyota/KOYO Front Unit Bearing
    • Toyota Spindle
    • Toyota Outer Seal for Hub to Bearing, greased & installed
    • Toyota Mounting Bolts (4), installed
    Additional parts:
    • Toyota O-Ring for Unit bearing to Knuckle
    • Toyota Cotter pin for CV Axle Nut
    Click for details: marlincrawler.com/product/pre-assembled-wheel-hub-unit-bearing-type-3-type-4
    joba27n likes this.
