New wheel and tires causing high pitch howl on the highway?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fourfourone, Apr 25, 2023.
  1. Apr 25, 2023 at 5:51 AM
    fourfourone
    fourfourone [OP] Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    I wanted to get some feedback on a new noise. 2 weeks ago I put on my new wheel and tire set. Ray10 16x8 and Nitto ridge grapplers in 265/75r16 standard load. This set up replaced my stock 17" sport wheels and Wilpeaks.
    Right after I put the new set on, I started to get a howl on the highway from 65ish plus mph. I know aggressive all terrains are going to make noise as I was used to the wild peaks. The grapplers have the typical slight all terrain hum at most speeds. When I get to higher speeds the tire noise seems to turn into a high pitch howl. Sounds like when you blow lightly into a glass bottle. To me it sounds different that normal AT or MT tire hum but these are deff the most aggressive tires I have ever owned so I don't have much to compare too. It almost sounds like high pitched resonance. It not terribly loud and easily drowned out by low volume music.
    I can almost rule out a rear diff issue as the it 100% speed dependent. Doesn't matter if I'm on or off the gas or coasting or staying steady speed, the noise stays the same. Throttle input doesn't change it all. My 3rd gen company truck has the 3rd gen diff howl and this is different. Similar sound but you have the feather the throttle to make it happen on the 3rd gen.
    The noise does seem to change a bit depending on the highway surface. The noise doesn't really change if I try steering side to side. When I got the new tires I had the alignment checked and it was perfectly in spec(got an alignment last year) so no adjustments were made. Tire PSI is currently 30 rear and 32 front.
    I had the truck at the dealer a few weeks ago and all suspension components are tight. Since the noise just started with the new wheels and tires I would think it wouldn't be a mechanical issue.
    Anyone else get this noise? It's not loud, but deff there.
  2. Apr 25, 2023 at 5:57 AM
    Littlemule1
    Littlemule1 Well-Known Member
    2015 SuperWhite Tacoma DCSB TRD Sport
    Can you put old set back on to confirm its the wheels and tires.
  3. Apr 25, 2023 at 5:59 AM
    fourfourone
    Tires were thrown out except for one I kept as a spare.
    I'm pretty in tune with noises on this truck as I drive it a lot. Noise deff was not there with the old tires.
  4. Apr 25, 2023 at 5:59 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Yup. Or any other set
  5. Apr 25, 2023 at 6:04 AM
    fourfourone
  6. Apr 25, 2023 at 6:16 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    Those little hairs on the tread of new tires will make alot of noise but will quiet down once they wear off.
  7. Apr 25, 2023 at 6:29 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Ok then it's settled. Your new tires are noisier than your old ones.
    My Duratracs had a howl above 55 mph, a bit like semi truck tires, not unexpected when it's marketed as "commercial traction".
  8. Apr 25, 2023 at 6:31 AM
    fourfourone
    It deff sounds like when you drive next to a box truck or semi on the highway and you hear the high pitch howl, just much quieter.
    I'm fine with noise just seemed odd but it makes sense as these tires are more aggressive than the wilpeaks they replaced.
  9. Apr 25, 2023 at 7:07 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    My Yokies are just NOISY AND RUMBLY at any speed....its the tread design, wouldnt worry about it!
