New V6 engine for 2004 taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by badswimmer5, Nov 30, 2021.
  1. Nov 30, 2021 at 8:05 AM
    badswimmer5
    badswimmer5 [OP] New Member
    Toyota Tacoma
    My name is Ramon. I am the original owner of a 2004 Tacoma, V6 4 dr. My truck has 160K on it. 3 years ago I replaced the water pump and all the belts at the dealer. I have never had any problems with it. Change the oil, add gas, go.
    Earlier this year, it overheated. I checked it and radiator fluid all over the engine. Thought my radiator went bad. Took it to the dealer to get a new radiator. Dealer did a test (maybe a pressure test) and said that the radiator fluid is somehow leaking into the engine, something leaking. I asked about fixing that issue. I was told that I would need a new engine, or that it is cheaper and easier to replace the engine.
    So now I am looking to replace my engine. I understand it will cost upwards of $4000. I just want to do it, correctly and hand the truck to my son.
    Looking for references on reliable resources for:
    1) replacement engine
    2) reliable mechanic to install
    thanks
    Ramon
  2. Nov 30, 2021 at 8:21 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
  3. Dec 1, 2021 at 9:43 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Hard to answer without knowing where you live!!
    I doubt you want to find a place 1000 plus miles away.
    Myself look for a running engine close to home.unless your looking for a new engine !!
    I would also check into just what is wrong with your engine and the cost to repair.
  4. Dec 1, 2021 at 12:29 PM
    SellyKlater
    SellyKlater Well-Known Member
    Ponce Inlet, Fl
    2004 Tacoma 3.4L Double Cab TRD
    3" ome lift 883. Fnfx pros.
    I've seen a few jdm 3.4 engines going for $1600. Might want to look into that. They usually have less then 50k miles on them.
