New to Vermont, need to upgrade
Discussion in 'North East' started by russperry20, Sep 15, 2016.
  1. Sep 20, 2016 at 5:50 PM
    802coma
    802coma Well-Known Member
    Caleb
    NEK & Southern VT (Berkshires occasionally)
    '10 Reg Cab 4x4 MT
    Russ, did you decide on tires?
  2. Sep 21, 2016 at 11:01 AM
    russperry20
    russperry20 [OP] Well-Known Member
    Russ
    Yea I'm going to go with the DuraTrac 265/75R16's.
    I'm still up in the air about getting a small lift at the same time as getting the tires switched out. There is a ton of information on this forum about this that its making my head spin.
    Keeping in mind I do not want a significant "lift".. How much more clearance would I get if I had Bilstein 5100's installed all around and had the front set at 0.85? I do like have the back a little higher than the front. Is it worth getting 5100's all around or get something different for the back? Guess I'm not sure the benefits of getting shocks or coils for the front.
  3. Sep 22, 2016 at 6:40 AM
    802coma
    Caleb
    '10 Reg Cab 4x4 MT
    5100's with stock springs at .85 would give you (I'm guessing) anywhere between .85 to 1 inch of lift. If you search around here I'm sure you could find some exact numbers for your specific truck using that set-up. You may also want to consider the ride becoming a little stiffer if the stock coil is preloaded.
    What I plan on doing is 5100's up front with OME 884 springs, and a 3-pack AAL in the rear from wheelers. Rear shocks will either be 5100's or OME.
    884's should be around 2 inch lift (depends on truck) and the 3-pack is a nicer rider compared to a single AAL from what I've read on here (giving about a 1.5 inch lift).
    A key thing to remember is that 2.5 to 3 inches of lift in the front and you will most likely need new UCA's to correct the geometry for a proper alignment.
  4. Sep 27, 2016 at 10:54 AM
    russperry20
    Russ
    First step, got the tires on..
    before
    after
    802coma[QUOTED] likes this.
  5. Oct 20, 2016 at 3:52 PM
    Logan.spencer
    Logan.spencer Well-Known Member
    Logan
    Southern VT
    '18 TRD OR DCSB Cement Manual
    2018 TRD OR DCSB 6 Speed MT Magnaflow Catback CBI T3 Front bumper RCI Skids (front, trans, t-case) RCI Rear Bumper (custom swivel recovery points) Rocky Road SuperSliders ARE Overland cap with area lighting Rigid SRQ backup lights Rigid DSS ditch lights Baja Designes 20" single row Baja Designs squadron sport fogs Icon Stage 9 SwitchPros power system ...i may be forgetting something...
    they are AWFUL!!! absolutely clueless and terrible service. i have a set of duratracs for sale though!
    DrFunker[QUOTED] likes this.
  6. Oct 21, 2016 at 1:54 AM
    DrFunker
    DrFunker Well-Known Member
    Good to know.
  7. Nov 12, 2016 at 5:26 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Kinda late here sorry.
    I don't post much or visit much anymore.
    I had my 5100's @ .85 installed at baileys spring shop in Essex jct.
    Good guys, kinda old school they did it without an appt.
    Pretty glad I had them do it. They did the alignment also.
    They handled my truck with kids gloves pretty cool. Even ask if it's ok to use a impact on my lugs.
    They had replaced my broken leafs for me in the past. In the past haha every yr was one side or the other.
    Kinda funny seeing my little truck in with the big rigs. They had spring packs I wouldn't be able to even carry in truck!!!
    After the recall springs were put on my truck last November I was going to raise the 5100s at home.
    Really not a great garage set up pretty basic, anyway checked to see if J&L in St. Albans could do an alignment for me once I got done.
    They offered to lift them to 1.75 from .85 and charge 1 hr labor to do it.
    J&L scratched and scuffed up the shocks and coil springs.
    I would use Baileys again for suspension stuff I don't want to tackle.
    There's the 4x4 center in Burlington also. I've not had any dealings with them but have heard mostly good about them.
    This just sounds like a good freaking deal and a good time!
    I need to do my rear wheel bearings at some time. :cheers:
