New tire size
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ken14, Jun 1, 2024.
  1. Jun 1, 2024 at 5:22 PM
    Ken14
    Ken14 [OP] Well-Known Member
    East Tx.
    23 SR5 DC Blue Crush
    Im getting ready to replace the tires on my '23 SR5 2WD. Its got the factory 245/75/16's on it. No lift etc. My '10 ran 265/70/16' which I thought gave it a taller look. Any suggestions on a tire size upgrade on 16" wheels. Im. NOT going to 17-18" wheels.
  2. Jun 1, 2024 at 5:25 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    245/75R16 & 265/70R16 are essentially the same overall diameter, the 265 would just be almost an inch wider.
    If you are wanting it to have a taller look, the only real choice on a 16” wheel is 265/75R16, which will be 1.1” taller and again, almost an inch wider. That’s the size I went with on my 16” Off-Road wheels.
    TacoManOne and Radd like this.
  3. Jun 1, 2024 at 5:26 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    I only got about 15,000 miles out of my stock firestones and replaced them with stock sized Falken Wildpeaks.
    They 'look' bigger without being 'bigger', feel and ride great too.
  4. Jun 1, 2024 at 5:27 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    255/85r16 is a thing.
    Tocamo, OldSchlPunk, helix66 and 2 others like this.
  5. Jun 1, 2024 at 5:28 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    245/75/16's and 265/70/16's are the same height. The 265's are 20mm wider, or about 3/4" at the sidewall. 265/70/16's are, or at least were an optional tire size from the factory. Mine came with that size.
    The exact width of the tread that contacts the ground can be different depending on the manufacturer and the exact tire. Some tires even in the same size will be a bit wider. E rated tires in the same size are slightly larger in diameter.
    I moved to 265/75/16's years ago. They are about 1" taller and about 3/4" wider than your current size. Just enough bigger to look a bit better, give a little more ground clearance, but have no real downsides. That size is often less expensive as well.
    You can run them with no lift and they still don't look too small even with a 2-3" lift.
    Ken14[OP] likes this.
  6. Jun 1, 2024 at 5:29 PM
    Ken14
    East Tx.
    Thanks for the sensible reply I don't really have a need for a mega lift or 4x4 or 6.+gears
  7. Jun 1, 2024 at 5:36 PM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
    dand, helix66, Squirt and 2 others like this.
  8. Jun 1, 2024 at 5:39 PM
    Ken14
    East Tx.
    Just what I was expecting some codsack suggesting a 40" tire on 20" wheels.
    T4R_hereforbearings likes this.
  9. Jun 1, 2024 at 5:42 PM
    T4R_hereforbearings
    WA
    08 4Runner
  10. Jun 1, 2024 at 6:39 PM
    530Taco
    530Taco Gone fishin'
    Adam
    Old Hangtown, CA
    '21 DCSB OR MT Cement
    265/75s look good on stock trucks, little bit taller, fits no problem...
    Stock (265/70)
    265/75
    Evostaco, Radd and Ken14[QUOTED][OP] like this.
  11. Jun 1, 2024 at 7:49 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Second vote for 255/85/16.
    OldSchlPunk and Inyo_man like this.
  12. Jun 1, 2024 at 7:50 PM
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    265/75
    RIX TUX likes this.
  13. Jun 1, 2024 at 7:56 PM
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can
    Ahhh the best all around tire :thumbsup:
  14. Jun 1, 2024 at 7:59 PM
    T4R_hereforbearings
    WA
    08 4Runner
    Squirt[QUOTED] likes this.
  15. Jun 1, 2024 at 8:01 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    The 265/75 is going to be your best bet, it’s basically a 31” tire.
  16. Jun 1, 2024 at 8:04 PM
    T4R_hereforbearings
    WA
    08 4Runner
  17. Jun 1, 2024 at 8:06 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    I did the cooper stt max 255/85/16 on the oem offroad rims without any mods or rubbing (daily street driving).
    They're basically 33’s, look good but they are heavy, load range E (helped handling but drive more truck-like) and took a gas mileage hit.
    I’m lifted now and considering rims and 285s….or stay on the 255, not sure yet.
    Inyo_man likes this.
  18. Jun 2, 2024 at 8:09 AM
    Inyo_man
    Inyo_man Don't piss down my back and tell me it's raining.
    U.S.A.
    2023 Tacoma TRD, off-road, access cab
    It appears the OP does not want to go up to 33's, but here is another vote for 255/85/16's. After the 265/75's wear out, that's what's on the list.
    Cheers
  19. Jun 2, 2024 at 11:05 AM
    PTPinETN
    PTPinETN Well-Known Member
    Alan
    ETN
    Put 255/85s on my OR a few weeks back. No lift, stock suspension.
    Inyo_man and helix66 like this.
  20. Jun 2, 2024 at 11:13 AM
    Hawkeye5543
    Hawkeye5543 Active Member
    changing out my wheels and tires on my 2017 Toyota Tacoma sr. Buying tires and wheels off a 2020 Toyota Tacoma TRD. Do I need to reset my tire sensor?
