New Tire - Goodyear Wrangler Boulder MT
Discussion in 'Wheels & Tires' started by Sand_In_My_Taco, Sep 22, 2023.
  1. Sep 22, 2023 at 1:10 AM
    Sand_In_My_Taco
    Sand_In_My_Taco [OP] Well-Known Member
    NOR*CAL
    2019 TRD-OR AC
    boostedka likes this.
  2. Sep 22, 2023 at 1:13 AM
    Sand_In_My_Taco
    NOR*CAL
    2019 TRD-OR AC
    Here's what they look like.
    boostedka and DavesTaco68 like this.
  3. Sep 22, 2023 at 3:14 AM
    Pete_Patter
    Pete_Patter Well-Known Member
    2018 Calvary Blue Tacoma TRD Pro
    Those look awesome! Yeah they are a full Mud Tire so they are going to be loud. I don’t think Goodyear has had a true MT since they release the MTR a long time ago. But these look way more functional than the MTR’s.
    boostedka and BC Hunter like this.
  4. Sep 22, 2023 at 8:40 AM
    Sand_In_My_Taco
    NOR*CAL
    2019 TRD-OR AC
    It looks like there is quite a bit of gap between the lugs.
  5. Sep 22, 2023 at 8:47 AM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit.* Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit.* Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler . Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    The stone ejectors look like the ones from the Duratrac but slightly more aggressive. A tire I'll be keeping my eye on.
  6. Sep 22, 2023 at 10:39 AM
    Hilborn
    Michael
    Utah
  7. Sep 26, 2023 at 1:40 PM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Newer, high end MTs are not as loud as the old generation. I went from Falken AT3W to Mickey Thompson Baja MT and barely hear a difference. Even going from the 34/11.50r17 to a 35/12.50r17. They have surprisingly good road manners.
    I also have the 315/70r17 Goodyear Territory MT; what the Raptor Bronco comes with. They are under the Wrangler line, but they try to hide that naming as it would not be a good look to have (Jeep) Wrangler on a Ford. I'd consider them an aggressive AT due to lug spacing and tread depth. They do tend to squeal in the turns more than the others. Compound feels softer.
    I believe Goodyear defines the MT as Maximum Traction, not Mud Terrain.
    And finally, Goodyear bought Cooper who owns Mickey Thompson. Cooper MT and Mickey's MT are very similar, and this new Goodyear looks like an iteration of the 2, just more basic technology.
    For the right price these could be a good option.
  8. Sep 26, 2023 at 1:41 PM
    Sand_In_My_Taco
    NOR*CAL
    2019 TRD-OR AC
    Interesting.
    I look forward to seeing some reviews.
  9. Sep 27, 2023 at 7:41 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    It's a Goodyear, so it will be loud, it will not be round, it will cup no matter what you do, and it will be impossible to keep balanced.
    PTSDTherapy likes this.
  10. Sep 28, 2023 at 3:24 AM
    Pete_Patter
    Looking at the construction and pattern I think it is based on Cooper tire technology. The construction by size matches the Cooper STT Pro. But based on the pattern type as a mud tire it will definitely be louder than a AT or RT which is the case for all Mud Tires. If it is based on the Cooper STT Pro it will be one of the best MT’s on the market.
  11. Sep 28, 2023 at 8:35 AM
    findingthingsout
    midwest
    Is that every line of goodyears, every size, use case and how have you had a chance to run all those configurations?
    Are you from the Future?!?!
  12. Sep 28, 2023 at 8:48 AM
    savethewheels
    savethewheels Well-Known Member
    Nashville, TN
    truck
    What's the tire weight?
    edit: in 285/75/16, for example; and other popular Tacoma friendly sizes.
    23MGM likes this.
  13. Sep 29, 2023 at 1:46 PM
    Maticuno
    2011 Suburban 2500
    Been running Goodyear on my fleet due to mandatory contracts on and off for the last 15 years. It is universal on everything they make that is an all-terrain or more.
  14. Sep 29, 2023 at 2:19 PM
    findingthingsout
    midwest
    Sounds like a real headache. We'll see how the Goodyear Territories perform. Only ~5k so far. They were so cheap I couldn't pass them up. Ran the Goodyear Wrangler Kevlar 15 years ago without any issue on my 1st Gen. But my experience is limited as compared to yours.
  15. Oct 19, 2023 at 1:57 PM
    cjc208
    cjc208 Well-Known Member
    CJ
    Boise, ID
    2017 Tacoma SR Access Cab 2.7l 5speed 4WD
    265/75/16 goodyear duratrac, 16" sr5 anthracite wheels CBI Baja Front bumper / skid plate
    Anyone know the weight on 265/75/16 ? Cant seem to see it anywhere. Assuming it will be E only?...a C load would be sweeeeet
  16. Oct 19, 2023 at 3:37 PM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    @cjc208 the actual weight per Goodyear Tire Co. is 54.81lbs and is expected to be available 10/23/2023. :thumbsup:
    cjc208 and boostedka like this.
  17. Oct 19, 2023 at 3:53 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Tread looks similar to the Mastercraft Courser MXT
  18. Oct 20, 2023 at 4:55 AM
    Pete_Patter
    Really? I geuss they are both Mud Tires and have a 4 block configuration. To me it looks closer to the BFG KM3 than the Mastercraft MXT
    [​IMG][​IMG]
    boostedka[QUOTED] likes this.
  19. Oct 20, 2023 at 8:06 AM
    Hilborn
    Michael
    Utah
    Looks like a revised old school MT.
    Maticuno likes this.
  20. Oct 21, 2023 at 7:34 AM
    savethewheels
    Nashville, TN
    truck
    Do you know the weight for 285/75/16? Thank you in advance!
