New Tire - Goodyear Duratrac RT
Discussion in 'Wheels & Tires' started by Hilborn, Oct 14, 2023.
  1. Oct 14, 2023 at 4:44 AM
    Hilborn
    Hilborn [OP] Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit.* Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit.* Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler . Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
  2. Oct 14, 2023 at 7:15 AM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Looks good! Probably going to be much quieter as they wear down than the regular DTs. Hopefully winter traction holds up better as they wear down as well. Regular DTs seem to really suffer quickly as they wear. Tread/lug width seem on par with Toyo AT3's, AT3WS, etc...
    DavesTaco68 likes this.
  3. Oct 14, 2023 at 1:52 PM
    Hilborn
    Michael
    Utah
    I ran a set of the originals that were 7 years old and had 60k before I got another set of tires.
  4. Oct 16, 2023 at 5:08 AM
    Pete_Patter
    Pete_Patter Well-Known Member
    2018 Calvary Blue Tacoma TRD Pro
    Looks more snow tire than off-road tire.
    Road_Warrior likes this.
  5. Oct 16, 2023 at 5:25 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I can see that. It looks like it has some crazy siping. It looks like it will be excellent in the snow and rain.
    I hope they eventually release it in LT265/75/16.
    Evostaco likes this.
  6. Oct 16, 2023 at 1:18 PM
    Roody
    Roody Well-Known Member
    Ross
    SW CT
    GX460
    Looking forward to seeing what the 255/80/17 weighs
  7. Oct 18, 2023 at 8:52 AM
    Thegrassisalwaysgreener
    Thegrassisalwaysgreener Well-Known Member
    Manitoba
    Looks good, always loved duratracs. If only they would release them in 255/85r16.
    I would say these will be the final nail in the coffin of k02s. I hate those tires so much. The amount of times I got stuck on 35s in snow not even deep enough to bottom out was getting out of hand. I'll never understand why they have a cult like following.
    For reference I ran two different sizes on two drastically different vehicles for over 120k km. Trash.
    czukie and TS4x4 like this.
  8. Oct 18, 2023 at 9:03 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Do they ONLY come in E/F load??
  9. Oct 18, 2023 at 10:41 AM
    Hilborn
    Michael
    Utah
  10. Oct 18, 2023 at 10:49 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
  11. Oct 25, 2023 at 5:28 PM
    VTacoma6
    VTacoma6 Well-Known Member
    Vince
    Florida
    2015 Toyota Tacoma Trd Sport 4x4
    16 inch Matte Bronze FN Countersteer Type X wheels 0 offset With Goodyear Duratracs 265/75R16
    As far as 285/75/16 there is about a 6lb difference per tire between the OG Duratracs and the new RT.
  12. Oct 25, 2023 at 5:54 PM
    Pete_Patter
    That doesn’t feel right. The new DuraTrac RT has 3-ply sidewalls and the old one only has 2-ply sidewalls. Plus the upper sidewall tread is much thicker on the new RT. The new RT should be heavier than the old tire.
    I wonder if they gave you them backwards or if the OG Duratrac was a LT285/75R16 and the new RT was a P285/75R16.
  13. Oct 25, 2023 at 7:00 PM
    VTacoma6
    Vince
    Florida
    Not sure, but you have good points. You could try and ask them tomorrow and see if you get a different response, if you do let me know what they say.
  14. Oct 28, 2023 at 7:31 AM
    Manitoba
    My friend just ordered a set for his tundra. I'm very excited to see them in person.
  15. Nov 9, 2023 at 8:41 AM
    Manitoba
  16. Nov 10, 2023 at 6:07 PM
    1blink
    1blink Well-Known Member
    Storm Mtn, CO
    2000 3.4 manual SR5
    not studdable. interesting choice to remove that, if they are aiming at more of a winter-ish tire.
  17. Nov 10, 2023 at 11:58 PM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I don't think I've ever seen a regular Duratrac actually studded so my guess is +90% of people don't anyway. If you need to stud, get the regular ones then!
  18. Nov 18, 2023 at 12:56 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    I'm not sure the design looks different enough to fix the cupping and out of balance issues that the regular Duratrac has.
