New sub-forum for offroad - overland trailers
Discussion in 'Towing' started by Box Rocket, Jan 3, 2014.
  1. Jan 3, 2014 at 2:36 PM
    Box Rocket
    Box Rocket [OP] Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    I propose a new sub forum be created here that is dedicated to off road camping and overland travel type trailers. There is lots and lots of general towing information here in the main section, but more and more people are building and buying small rugged offroad trailers and a sub forum specifically dedicated to these types of trailers would be a great resource.
    Can I get a "hell yes"?
  2. Jan 3, 2014 at 3:47 PM
    robu
    robu Well-Known Member
    Rob1224
    Cottonwood, AZ
    TRD sport debadged
    kings front and rear 3" expedition deaver pack 700lbs in front. lighted 4x4 switch and fixed temp console
    HELL YEA!
  3. Jan 4, 2014 at 2:35 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    A Jayco Baja is supposedly a good offroad trailer. I looked at one before I bought the Kodiak 166E. Here's a discussion about it:
    http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24596839/print/true.cfm
    And specs on it:
    http://www.jayco.com/products/camping-trailers/baja/floorplans-specs
    Pros (compared to a hybrid trailer like my Kodiak, or other hybrids - Jayco, quite a few other brands):
    *13" ground clearance, low profile while traveling.
    *Large toy-hauler area on front of trailer, as well as outside storage
    *DC/AC converter in the trailer
    *Sewage drain pipes and valves are up high as a result of the 13" ground clearance
    And that's about it for the pros, IMO.
    Cons (again compared to a hybrid):
    *Tiny refrigerator.
    *Lack of secure inside storage.
    *Lack of inside storage period when traveling
    *Outside shower.
    *Lack of privacy and conveniences in the bathroom.
    *Small fresh water/black/grey tanks. (In fairness, a lot of the hybrids have small tanks. One of the main reasons I got this Kodiak is because it has the huge 52-gallon fresh water tank as well as black/grey tanks that are 2-3 times larger than other makes).
    *Only 150 lbs less dry weight than a hybrid
    *Just as expensive as a hybrid
    *Air conditioner has to be bought as an option
    *Smaller furnace
    *Huge tongue weight when the front storage area is loaded up.
    The main problem with the Kodiak is the lack of ground clearance. It has about 6" as is with the 205/75/14 tires on it. It's possible to do an axle flip (which is how the Baja gets that 13" of ground clearance), but then you run into maybe some stability issues on the highway. It's a wide trailer, 8-ft, so that is helpful.
    I figure I can get a 225/75/15 tire on it though, so that gives me 2" more ground clearance right there. In fact, I'm pretty sure a 15" Toyota truck wheel will fit the axles with the 4.5" 5-lug pattern.
    The problem with hybrid trailers is the low-hanging sewage pipes and valves, maybe the rear stabilizer jacks, maybe too long of a rear porch if you get too long of a trailer. Everything else is pretty high up.
    I figure just the 15" tires get me up to 8" of ground clearance, that's a big help.
    Aaaaand, that's my contribution. I did quite a bit of research since I was considering offroading with the trailer as part of the buying process.
  4. Jan 6, 2014 at 11:01 AM
    Box Rocket
    Adam
    Syracuse, Utah
    Bump....
    I'm talking more about trailers like these.....but larger professionally built ones are fine too as long as they are OFFROAD trailers like the Kimberly Kamper or Conqueror Compact etc.
    Mine.
    Jberry's.
    05chaos likes this.
  5. Jan 8, 2014 at 2:29 PM
    monkeyface
    Colorado
  6. Jan 8, 2014 at 2:50 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Great set-up Adam, your SD pics are awesome! How the heck are you transporting a family of 6 in a 5 seater?
  7. Jan 9, 2014 at 10:15 AM
    Box Rocket
    Adam
    Syracuse, Utah
    Thanks. There are details in my build thread on the seating for 7.
  8. Jan 11, 2014 at 2:13 PM
    scollins
    scollins Well-Known Member
    Scott
    Renton WA
    2019 Ford F450 STX 6.7L Powerstroke
    I have a Starcraft 11RT, which is similar to the Jayco Baja. Seems to be the only picture I have at the moment....
    abc5effb1eb1431d4c8eaf3ba430502b_zps9fed_adbec8f222d83b9604174b18eca392f158570439.jpg
    Here are a few more "Pros" I think you missed. Some are situation-dependent of course:
    *Storage of the RV itself.
    -My 11RT fits in my garage, can't do that with a hybrid or traditional Travel Trailer (TT). As I live in an HOA area, I either park an RV in my garage or pay for off-site storage. Around here that runs about $75/month for outdoor, uncovered space with no power/water.
    *Towing of the RV.
    -Towing a pop-up is way easier than a TT. It has less wind resistance, both from the front and sides (sway.)
    *Height of the trailer
    -Only really an issue if you take it off-road in heavily wooded areas. But still something to consider.
    Mine also has shocks on the axle, which really helps it off-road, as well as when towing.
  9. Jan 13, 2014 at 8:24 PM
    monkeyface
    Colorado
    Yeah, the shocks are a big deal, never thought of that, as well as garage storage ability. Tell you the truth what sold me on this trailer was the huge 52 gallon fresh water tank, and the equally huge black and grey water tanks. Nothing else I looked at had those capacities. That means you can stay offroad for a longer time before you have to look for a place to refresh or dump.
    That Starcraft/Baja is a nice rig, though. That 11RT, do they even sell that anymore? I see that 11RT has a 35 gallon fresh water tank, that's pretty good. The Jayco Baja is 30 gallon.
  10. Jan 13, 2014 at 8:28 PM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    That looks awesome Boxrocket, do you have a build page or shots of it in use for it?
  11. Jan 13, 2014 at 8:32 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    In. Going to be building one sometime soon.
  12. Jan 13, 2014 at 8:34 PM
    Pdugan6
    Pdugan6 Well-Known Member
    Patrick
    Sunnyvale California
    3 link solid axle 2011 Tacoma 4x4
    That would be interesting. I have been toying with the idea of doing a trailer build.
  13. Jan 13, 2014 at 8:37 PM
    NetDep
    NetDep Well-Known Member
    Tim
    Southern Utah
    2011 Toyota Tacoma Off Road MGM
    Glad to see this topic. Mine just got a little bit of attention in a blog:
    http://tinyyellowteardrop.blogspot.com/
    I have a flickr page dedicated to my Tacoma and Little Guy Teardrop:
    http://www.flickr.com/photos/netdep/sets/72157626824134599/
    The trailer is a 6X10 Silver Shadow on a Rough Rider frame and the color is matched to my MGM Tacoma and also has matching wheels/tires (a major pain trust me!!). Creature comforts include upgraded entertainment system, stove and sink not to mention a king size bed. I have not had much chance to get off-road with the trailer - new this past late summer - but have plans to get her out more this coming summer. It has a pintle hitch and beefy skid plate...couple of pics if you don't feel like clicking....
  14. Jan 14, 2014 at 9:15 AM
    Box Rocket
    Adam
    Syracuse, Utah
  15. Jan 14, 2014 at 10:03 AM
    2stroketrush
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
  16. Jan 22, 2014 at 4:16 PM
    Box Rocket
    Adam
    Syracuse, Utah
    That's a good looking teardrop. I appreciate the details of a nicely built teardrop but they just wouldn't work for me. Most teardrops are too long for the places I'd like to take it and there is too much body to worry about damaging. More importantly I don't like that I'd have to unpack my gear from the trailer before I can sleep inside.
    teardrops work great for some, but it's a smaller trailer with RTT that works best for me.
  17. Jan 22, 2014 at 4:50 PM
    NetDep
    Tim
    Southern Utah
    Thanks for the good words!! To each their own but I don't unpack anything...I unhitch, plug in (if shore power) and hop in to watch TV or a movie and stretch out in a king size bed.
  18. Jan 22, 2014 at 4:53 PM
    medic2230
    Murph
    Bama! Roll Tide
    Great idea Adam!
  19. Jan 22, 2014 at 8:57 PM
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    Bout damn time!
  20. Jan 22, 2014 at 9:05 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
