New rotors cost?
Discussion in 'Wheels & Tires' started by RubberTank, May 16, 2012.
  1. May 16, 2012 at 4:35 PM
    RubberTank
    RubberTank [OP] Well-Known Member
    Thousand oaks, CA
    So I've determined that my squeaky brakes and wheel shake are from warped rotors. How much will it cost for new rotors? or should I just have them machined?
  2. May 16, 2012 at 7:30 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Well not sure on rotors alone, but I also had shaky brakes and the brake pad squeal about 2 weeks ago and finally took my truck in to get the front brakes done. I would have done it myself, but time wasn't on my hands and I didn't have any days off for weeks and they were starting to sound real bad. I ended up getting new rotors, new front pads, and new brake fluid in the system. Total cost was $308 with tax. This was done at an independent shop that I know and trust. Toyota wanted almost $600 for the same thing. If you do it yourself you can buy all the parts and fluid for under $150. If your rotors are still good, then you can get them resurfaced at a brake repair shop and save even more. I mainly replaced mine because I'm pretty sure they were the original rotors that had been on the truck since 2003.
  3. May 16, 2012 at 7:36 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Just ordered brembo rotors and hawke pads. 250 shipped to my door.
  4. May 16, 2012 at 9:07 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    $62 a piece from NAPA.
  5. May 16, 2012 at 10:41 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    brembo plain rotor is a good replacement. if you're handy, run to your local autoparts stores and buy a pair. i'm sure you can do it for under $100 or less.
  6. May 16, 2012 at 10:42 PM
    PLC721
    Patrick
    Chandler, Az
    just received mine
  7. May 16, 2012 at 10:50 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    good choice as well as the pads you chose. it's a nice, proven, and budget friendly combo.
  8. May 17, 2012 at 4:26 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Autozone - $55/ea I believe is what I paid. So far they're doing great paired with cermamic pads.
  9. May 17, 2012 at 7:03 PM
    RubberTank
    Thousand oaks, CA
    I think thats going to be my route.
    Thanks for the input everyone
  10. May 18, 2012 at 9:00 AM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    I went with centric powerslot rotors from wheelers and hawk lts pads.
  11. May 18, 2012 at 9:05 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    are the ebc pads any good or does everyone mainly recommend hawke? i have never used either.... past use has normally just been the autozone ceramics. just thought maybe this time i would try something different when it comes time...
  12. May 18, 2012 at 10:12 AM
    Pugga
    Massachusetts
    EBC makes decent stuff. The Autozone pads have a lifetime warranty and seem to be working great (had them for a month so far). Once they're shot, just bring them in and get new pads, no charge.
  13. May 18, 2012 at 10:33 AM
    TacoFMS
    Justin
    Louisa County, VA
    yeah i had them on other vehicles because i used to work there part time. but after finding out recently they switched manufacturers of the pads and are having several issues with them i dont believe i will be taking that route this time around.
  14. May 18, 2012 at 10:39 AM
    Pugga
    Massachusetts
    What issues were they having with the pads? I wasn't aware of any issues when I purchased them. :eek:
  15. May 18, 2012 at 10:44 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Really?? They replace them when they are warn down?? I mean-Broken or whatever for the life of the brakes I can understand- but free replacements until you don't go back any more?? Seems a bit unlikely.
  16. May 18, 2012 at 10:48 AM
    Pugga
    Massachusetts
    Yes. Even if the brakes perform flawlessly for 70k+ miles, when they're worn down, bring them back and get a new set. I asked the guy that and even read the warranty BS that came with them. I think they're hedging their bet on people not keeping their vehicle long enough to require multiple brake changes, not doing the work themselves or not caring and buying something else anyways. As far as I'm concerned, I just bought my last set of pads :D
  17. May 18, 2012 at 10:50 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Very interesting. I may have to take a look at that....
  18. May 18, 2012 at 10:52 AM
    puckstopper55
    puckstopper55 Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    This!! I bought pads for my old truck in 1999 and replaced them at least 7 times before I sold the truck. Never paid for pads after the initial cost .. I never had to replace the rear shoes
  19. May 18, 2012 at 10:55 AM
    Pugga
    Massachusetts
    I've got the Duralast C-Max pads. They're Autozone's ceramic pads and were around $55 - 60/pr. So far I think they stop great, have been quiet and produce about the same amount of dust as the stock pads did. (only gauged by the amount of black crap on the wheels between washes).
    Nice to know they honor it! I wasn't sure how much I'd have to argue when they do finally wear down.
  20. May 18, 2012 at 11:09 AM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Never had a problem with Autozone..........Most of the things they sell has a warranty for as long as you own the vehicle you installed the parts on.
