New owner with pace edwards switchblade tonneau cover problem
Discussion in 'Tonneau Covers, Caps and Shells' started by Pinzmann, Nov 29, 2023.
  1. Nov 29, 2023 at 10:20 AM
    Pinzmann
    Pinzmann [OP] New Member
    Jerry
    New Tacoma’23 owner. First purchase was a pace edwards retractable tonneau cover. I got this because it suited my specific needs. Installation was a breeze. So after going to my desert cabin via bumpy dirt road, I noticed it was retracted. I left that was as we did some rough trail riding. Back on the regular dirt roads, I closed it again. With a few minutes, retracted again.
    So what is causing this? Thinking it might be the latch bouncing loose? Or is the bed flexing enough for locking catches to pop out?
    Another possibility could be that I didn’t install the side rails tight enough? What do you all think.
  2. Nov 30, 2023 at 8:38 AM
    jon_elc
    jon_elc Well-Known Member
    NorCal
    2011 SR5 4x4 Timberland Mica Snugtop Rebel
    245-70R-17 Revo3 Cut mudflaps 4.5" F / 1.5" R
    yep, its #3. the side rails need to be closer , most notably at the tailgate area. you can doublecheck the amount of side-to-side motion of the tonneau when closed. if there's alot of play, then rattling movement during bumpy rides will shift the tonneau and the side latches will 'escape' the slots holding it in place. I experienced this when i took my pace edwards off and then reinstalled it.
