New or reuse TPMS sensors?
Discussion in 'Wheels & Tires' started by Ken b, Apr 28, 2014.
  1. Apr 28, 2014 at 1:06 PM
    Ken b
    Ken b [OP] Well-Known Member
    Ken
    Surprise, Az
    14 offroad 4x4
    ARE shell, bedrug, TRD wheels
    I just ordered a set of rims for my Tacoma. I'm going with the black TRD Baja rims. I like thier look the best.
    I will be moving my tires over to the new rims but was wondering if I should replace the TPMS sensors or can I safly reuse them?
    Mind you I am asking this because the local Discount Tire recomended New TPMS sensors. So I'm not sure if they where just trying to make a buck or not.
  2. Apr 28, 2014 at 1:16 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    When I got new tires they just swapped them over. That wasnt at Discount Tire though. I say if its not broken why fix it?
  3. Apr 28, 2014 at 3:29 PM
    Tuctaco
    Tuctaco Well-Known Member
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    Katzkins, Redline hood struts, Pop & Lock,285/75/16 Toyo Open County ATll, 16X8 Konig Countersteer, Icon extended coilovers, Icon rear shocks, Icon progressive leaf pack, LR UCA's, extended brake lines,
    You definitely reuse them, just buy rebuild kits for them.
  4. Apr 28, 2014 at 5:42 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    +1, if they're still functional just buy their rebuild kit and reuse them. DT is always trying to make a buck;).
  5. Apr 28, 2014 at 6:28 PM
    JDM
    JDM Well-Known Member
    Jimmy
    CO
    2009 DCSB TRD OR S/C
    TRD supercharger, TRD exhaust, skids, sliders
    I would say it depends on how old and how much use they've seen. If they're statistically on the high end (well used/old), then you're saving yourself the irritation (depending on your viewpoint) and expense of dealing with dying sensors in the near-term (if you're determined to keep the system functioning as intended).
  6. Apr 29, 2014 at 12:26 PM
    Ken b
    Ken
    Surprise, Az
    14 offroad 4x4
    The truck is brand new so are the sensors. Thanks for the info on a rebuild kit. Didn't know those were out there.
  7. Apr 29, 2014 at 5:18 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    If your truck is a 2014 and if the sensors are taken out with care, they shouldn't need to be rebuild. A good inspection by the tire tech should determine if it needs to be or not.
  8. Apr 29, 2014 at 5:24 PM
    Negatetime
    Negatetime Got syrup?
    Expatriated Vermonter living in Arizona
    2015 DCSB TRD Offroad
    886 springs, OME shocks, 2" add-a-leaf kit, ARB front bumper. Yeasu 857D with a Little Tarheel antenna 80-6 meters and a Diamond antenna 440-70cm. White camper shell with a roof rack. Black powder coated rims.
    Here is my TPMS story. My 2014 came with steel rims. I picked up some TRD Off Road rims and had them powder coated black. I planned on using my old sensors, but I was unable to. Toyota makes two different sensors that hug the inside of the rim at different angles. When tightening down the old sensors it caused the stem to come out of alignment in the hole and leaked air. I ended up purchasing the correct sensors. I didn't want to have to worry about any leaks. The online store at Camelback Toyota in Phoenix had a good discounted price incase you need new ones.
  9. Apr 29, 2014 at 5:29 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    OEM alloy wheels come with 20* angled sensors and OEM steel wheels come with 40* angled sensors. Most aftermarket alloy wheels accept 20* sensors so going from alloy to alloy is a straight forward swap.
    Governor and bax like this.
  10. Apr 29, 2014 at 6:18 PM
    JDM
    Jimmy
    CO
    I'm with SCSPerformance... just have them swapped as is. There should be no need for the rebuild kits. Shame on Discount Tire! It'd be one thing if you had an early 2nd gen with original sensors, but yours are still new. Did you new truck come with steel wheels and you're switching to alloys, as that would explain DT's recommendation.
    On the steel sensors onto alloys, have read (but no personal experience) that the sensor can be installed on an alloy rotated 180* from the normal position when installed on a steel wheel. It'll stick up, so care has to be taken when removing the tire (the shop would need to know to drop the sensor first). Not all shops will agree to doing this, so shop around if need be.
  11. Apr 30, 2014 at 12:33 PM
    Negatetime
    I installed my old sensors like that while I waited for my new ones to come in.
  12. May 22, 2014 at 8:52 AM
    Hilltowner
    Hilltowner Member
    New England
    Tacoma Access Cab 4x4
    My understanding is the the batteries are encased in plastic and are not replaceable - which gives the sensors a lifespan of 5-7 years - depending on mileage.
    Toyota OEM sensors can be had for about $50 each - aftermarket can be less, but don't know how they compare.
