New OEM Brake Pad/Rotor (Break-in)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Audi403, Oct 22, 2023.
  1. Oct 22, 2023 at 8:06 PM
    Audi403
    Audi403 [OP] Well-Known Member
    2015 Tacoma TRD Sport
    Hey guys,
    I'm curious how you break in your new pads/rotors on your truck. I just replaced mine with new OEM parts. I found this on olathetoyota.com:
    1. Startup your Toyota and then take it out for a spin in the neighborhood.
    2. Bring your car up to 45 mph and then press your brakes in a slightly aggressive way. (Repeat 2-3 more times.) You don’t need to come to a complete stop. This step heats up your rotors enough to prevent sudden thermal shock.
    3. Bring your car up to 60 mph and then aggressively hit your brakes until the car slows down to 15 mph. (Repeat 7-9 more times.) Try not to be too aggressive because you don’t want the ABS to kick in and the wheels to lock up.
    4. Cruise on the road at whatever speed you’d like for about 5-10 minutes without stopping. This cools down your brakes. It’s important that you don’t stop. At this point, your rotors and brake pads are extremely hot. If you stop, the brake pads may imprint some material on the rotors and make the surface uneven.
    This Toyota website talks about how to break in new vehicles, and it says to avoid hard braking for the first couple hundred miles. This is sort of the opposite of the above break-in procedure:
    https://www.captoyota.com/service/information/new-toyota-break-in-period.htm
    Then I also found on another Toyota website (can't find the link), an even different procedure. It was much less aggressive than the first one I posted above. I believe it said to slowly brake feom 50mph to 30mph, wait 2-3 minutes for cooling, and to repeat 4 times.
    Any recommendations?
    2015WhiteOR likes this.
  2. Oct 22, 2023 at 8:14 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  3. Oct 22, 2023 at 8:15 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Put them on and drive
    HondaGM, wayupnort and SethM like this.
  4. Oct 22, 2023 at 8:30 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Yes that is the correct routine. If you do NOT do that, you will get pad deposits on the rotors after your first hard brake (like coming to a red light where you have to wait with the brakes held down).
    You will know when the rotors are correctly heated because they'll have a blue/brown hue.
    Audi403[OP] likes this.
  5. Oct 22, 2023 at 8:31 PM
    Bishop84
    Bishop84 Well-Known Member
    Just gentle applications, I try to not hold too much pressure while waiting at a light. Usually can bed pats in 5 minutes, don’t stress it
    Aftermarket upgraded pads usually require more aggressive procedures.
    HondaGM and Audi403[OP] like this.
  6. Oct 23, 2023 at 6:18 AM
    Red13
    Red13 Active Member
    Truckee, California
    2013 DCLB Tacoma 4x4
    The aggressive technique you describe is normal for track cars with track pads that will commonly be at very high temps. At least that’s what I did with mine. OEM pad compounds are usually very soft and rotor friendly so I doubt that technique is needed in this case. I’d just drive.
  7. Oct 23, 2023 at 6:25 AM
    Delta09
    Delta09 OSHA Violator
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I always slow down moderately, but not aggressively.
    10 or so 35-10 slow downs
    Followed by 10 or so 45-5 slow downs
    Drive around a little bit to cool things off, but never stop completely.
    Several 60-15 or so slow downs
    Then drive around normally
    Always seems to work for me. Everybody's experience will vary.
  8. Oct 23, 2023 at 6:25 AM
    Clearwater Bill
    Billy
    Largo Florida
    I'd bet good money over 82.734% of the people here have never properly bedded a set of brakes.
    Look for the 'my rotors are warped' threads :D
  9. Oct 23, 2023 at 6:54 AM
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    how many people get brake jobs done at their mechanic or a midas properly break their pads in ? I would say very few...Even if you
    get your brakes done at Toyota, people don't brake them in properly. New car owners pick up their new car and just drive on..Same with getting new tires installed...People don't re-torque the lug nuts...
  10. Oct 23, 2023 at 7:20 AM
    2015WhiteOR
    Gainesville TX
    Hardest part of the procedure is going to be finding an area with little traffic to be able to not stay stopped for too long.
    HondaGM and RockfordTaco2006 like this.
  11. Oct 23, 2023 at 7:35 AM
    EL DUDE
    EL DUDE Well-Known Member
    Just slap them on and replace them after 4-5 years
    HondaGM and wayupnort like this.
  12. Oct 23, 2023 at 7:39 AM
    Audi403
    I got 8 years (150,000km) out of the first set of OEMs. Pads were down to around 2mm, maybe less on some of them. Was starting to get some shaking in the steering wheel while braking. I'm assuming the rotors were a little warped.
    I want these ones to last as long as the originals. I follwed the break-in procedure from the OP.
    HondaGM and 2015WhiteOR like this.
  13. Oct 26, 2023 at 11:04 PM
    EME
    EME Well-Known Member
    Nick
    05 Tacoma sport
    I cannot count the number of brake jobs I've done (owner operator of a garage) I always bed in brakes after install (50kph to 10kph moderately aggressive about 7-10 times ) when I'm finished the stink and smoke is coming off the brakes lets me know I got it hot enough, if bedded in properly there will be no noises, no shuddering, no pulse. and the brake bite when applied. there are many recommended ways of doing it, speeds and brake intervals vary depending on types of brake systems, hi-performance brakes are usually higher speed break in.
    I also clean the rust from under brake shims, and file fit pads if needed, to get pads to slide freely in brackets. to the idiots who respond in this thread about slapping in pads and not bedding in brakes. you are doing a disservice to others, please don't pass on your shit and make it sound like its ok to do. its not ok, freshly installed brakes in a panic stop may not stop the veh. a local toyota shop made break in mandatory after a customer collided with another car, claiming brakes would not stop car, turns out tech did not bed the brakes.
    rant off
    Morden and HondaGM like this.
  14. Oct 26, 2023 at 11:08 PM
    EME
    Nick
    05 Tacoma sport
    you dont actually come to a stop (my case I slow to 10 kms then accelerate back up to 50kph/30mph) luckily my shop is on a service road and I can time it right, but I agree with you it can be hard to find a safe place to bed brakes
    HondaGM likes this.
  15. Oct 27, 2023 at 9:12 AM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    I do something similar with all my vehicles. I usually do ~35 mph and ~45 mph. Typically brake pad MFRs will have a recommendation for their pads, so it's a safe bet to go with the MFR recommendation (which is typically similar to what you've described above).
    HondaGM likes this.
  16. Oct 27, 2023 at 9:12 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I bought my 2015 brand new with 3 miles on the odometer, never did a break-in procedure and somehow the brakes lasted 100k with no issues
    HondaGM likes this.
  17. Oct 27, 2023 at 10:29 AM
    Ted Striker
    Ted Striker Well-Known Member
    2 WHEEL DRIVE!
    ^^^ a friend worked at the car port. All Japanese built vehicles got their brakes "worked" from the boat to the parking lot.
    HondaGM likes this.
  18. Oct 27, 2023 at 10:41 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    It depends ..do you have OEM brakes...or Aftermarket Road Rage pads
    b_r_o likes this.
  19. Oct 27, 2023 at 12:21 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    This is what I do, I'm just a little bit careful until Everything is working the way it should.
  20. Oct 27, 2023 at 1:58 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I bed mine, but new cars are likely never bedded to that procedure. It's like asking if you need to break in a new rifle barrel.
    I bed mine and I re-bed them every year or so. My brakes work great.
