New neutral safety switch, shifting trouble
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Byrrne, Sep 10, 2021.
  1. Sep 10, 2021 at 11:00 AM
    Byrrne
    Byrrne [OP] Member
    Ethan
    2006 Tacoma TRD Sport
    Okay guys , 2006 tacoma 4.0l auto trans , just replaced the neutral safety switch , got it adjusted as best as I could by myself , shift through all the gears fine all dash lights light up when you put them into the gear, 2 and low sometimes take a bit of playing but they will illuminate , but now more often than not when I put into D it doesn’t engage , have to shift down to 3rd and it kind of hammers into gear then shift back up to D to have it engage , any ideas ?
  2. Sep 10, 2021 at 2:26 PM
    Byrrne
    Byrrne [OP] Member
    Ethan
    Update after driving home from work, it seems I have park, reverse , neutral , then drive is totally gone , truck needs to be shifted down to 3rd gear before I get any forward motion, then if I put in 4th or D it’s still clearly driving in a low gear , driving at very high Rpms to get home , the shaft and nss were lined up perfectly like the old one was. Anyway I jumped something in the tranny or any ideas ? Thanks in advance
  3. Sep 10, 2021 at 2:47 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Jimmyh likes this.
  4. Sep 10, 2021 at 3:01 PM
    Byrrne
    Byrrne [OP] Member
    Ethan
    The switch I have doesn’t actually have the neutral line on it for some reason but I aligned everything exactly how it was when the old one came off , brand new nss, I tried moving it around and tried 20 diff angles today and it’s just like D is totally gone , I’m at a loss , I do believe it’s driving 4th tho
  5. Sep 10, 2021 at 3:11 PM
    TnShooter
    Deogee
    STOCK
    It’s been awhile since I looked over the diagrams.
    But best I can remember the the gears that you slide up/down. Are controlled by the NSS. The ones that slide left and right are controlled by the shift console.
    Some where on this site there is a diagnostic for that too. I remember helping out in that one too.
    Like I say, I’m not home. And do not have access to diag. But it sounds like the NSS isn’t working right. Best I remember 5th (D) is on the NSS.
    Test the switch in the link above.
  6. Sep 10, 2021 at 3:13 PM
    TnShooter
    Deogee
    STOCK
  7. Sep 10, 2021 at 3:18 PM
    Byrrne
    Byrrne [OP] Member
    Ethan
    Thanks man I’ll let you now what I find I appreciate it
    TnShooter likes this.
  8. Sep 10, 2021 at 3:40 PM
    Byrrne
    Byrrne [OP] Member
    Ethan
    And just threw code p2714 Tranny solenoid performance d …. Fuck lol
    Steves104x4 likes this.
  9. Sep 10, 2021 at 3:57 PM
    Byrrne
    Byrrne [OP] Member
    Ethan
    So does anybody know if there’s any chance the neutral safety switch could have anything to do with this code or not likely ?
  10. Sep 10, 2021 at 6:46 PM
    TnShooter
    Deogee
    STOCK
    Not likely.
    Here about as good as I can do.
    This looks like a question for @gearcruncher (sorry buddy, hate to bother you. But I’m at loss on this one)
    P2714
    MONITOR DESCRIPTION
    The ECM calculates the amount of heat absorbed by the friction material based on the difference in revolution (clutch slippage) between the turbine and output shaft. The ECM turns on the MIL and outputs this DTC when the amount of heat absorption exceeds the specified value.
    When the shift solenoid valve SLT remains on, the oil pressure goes down and the clutch engagement force decreases.
    NOTE: If driving continues under these conditions, the clutch will burn out and the vehicle will no longer be drivable.
  11. Sep 10, 2021 at 7:12 PM
    Byrrne
    Byrrne [OP] Member
    Ethan
    Well shit boys I was going to hammer it till I got my beater back together but from the big bold text at the end of that message I’d say bad idea lol, I appreciate everything guys , what a great group of guys on here , love all the help and Info on here , thanks again !
