New lug nuts for FJ Cruiser TRD rims for 09 Tacoma
Discussion in 'Wheels & Tires' started by nurseboy, Jan 3, 2015.
  1. Jan 3, 2015 at 11:42 AM
    nurseboy
    nurseboy [OP] Well-Known Member
    Jan
    Riverside, Ca
    So my wife bought me the gun metal/anthracite TRD FJ Cruiser rims for Christmas and they just came in today. I did my research on this site and I just want to confirm before purchasing new lug nuts. It seems like I needed to purchase extended thread lugs for these rims and from the sticky I read previous, Gorilla nuts part #68138 with wheel locks part #68631N were recommended. I found them here
    http://www.brandsport.com/grla-68138.html
    Before I puchase these, I just want to make sure I did my research correctly and would love any other input/advice. Thanks
  2. Jan 3, 2015 at 11:43 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Your current lug nuts won't work??
  3. Jan 3, 2015 at 12:49 PM
    SpruceJPG
    SpruceJPG Raging Dunkay
    .JPG
    Maryland
    2013 Spruce Mica DCLB SR5
    WeatherTech Floor Mats and some window tint
    Nope... I switched over to FJ wheels from stock steel wheels and had the same issue. Got a call from the tire shop that the lug nuts wouldn't work. They were able to get some from another local auto shop, but not sure of exact part number of the replacements.
  4. Jan 3, 2015 at 1:07 PM
    Jones
    Jones Well-Known Member
    Texas DFW
    06 SSM Prerunner TRD-OFFROAD
    Front: 5100@1.75 with SR5 coils; Rear: 5100 and 1.5 Toytec aal; Tires: Hankook 265/75R16 RF08 ATM; Wheels: powdercoated off-road wheels with FJ TRD center caps
    What does the lugnut hole look like on the wheel? Is it flat or does it have have cone seat to it, where it is beveled in?
    I think you need these if it is flat.
    http://www.brandsport.com/grla-73138t.html
    Just like the factory Off-Road wheels on the Tacoma.
  5. Jan 3, 2015 at 1:33 PM
    nurseboy
    Jan
    Riverside, Ca
    I think because of the +15mm offset of the FJ cruiser TRD rims, the stock lug nuts on the Tacoma don't grab enough thread on the stock stud to keep rims secure. Need to eiter get all longer studs (more costly) or by different type of lug nuts
  6. Jan 3, 2015 at 1:41 PM
    53wick
    53wick Well-Known Member
    kentucky
    2014 accesscab prerunner
    I got a new set of fj wheels, they came with new lug nuts, yours did not?
  7. Jan 3, 2015 at 1:41 PM
    nurseboy
    Jan
    Riverside, Ca
    Im at work and won't be able to check till I get home. I'm hoping someone with these rims can put their 2 cents in which lug nuts are recommending. I like the ones you posted becase it seems like the tip of the lug nut is far longer than the cone shape one, but my concern would be the width of it being .725" inch. Not sure how big the hole on the rims are and if these will fit. The cone shape lug nuts tip are only .62" wide, but have a shorter tip to grab less of the thread
  8. Jan 3, 2015 at 8:50 PM
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    this style is correct
    if you bought the wheels new, lugs were most likely included
  9. Jan 6, 2015 at 3:34 PM
    nurseboy
    Jan
    Riverside, Ca
    forgot to respond. I assumed they didn;t come with them, but after looknig into the box they did...ooops:)
  10. Jan 12, 2015 at 1:52 PM
    jasonrobo
    jasonrobo New Member
    Baton Rouge, Louisiana
    Tacoma TRD Off-road DC V6
    Did they come direct from Toyota? I ask because I just ordered mine, and want to know if they come from Toyota with the lug nuts in the box. I have a 2003 Taco.
    Any and all help would be greatly appreciated!
  11. Jan 12, 2015 at 4:56 PM
    nurseboy
    Jan
    Riverside, Ca
    Yes it came direct from toyota. Each individual rim came with another triangular box with 6 lug nuts for them. I would recommend ordering gorilla locking lug nuts though
  12. Jan 18, 2015 at 11:16 PM
    Yota64
    Yota64 Professional Threadjacker
    I'm looking for Anthracite... How much were they if you don't mind? Also have my black ones for trade if you ever want to change it up.
  13. Jan 19, 2015 at 10:13 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    These are not correct.
    These are the correct style, can't confirm for sure on the size.
    Sounds like you got it figured out, but these are the (correct for the FJ wheels) lug nuts that came with mine, I also went from 16" steel to the FJ wheels. Had a little issue getting them torqued correctly due to me being retarded, but got that sorted out.
  14. Jan 19, 2015 at 1:58 PM
    nurseboy
    Jan
    Riverside, Ca
  15. Jan 20, 2015 at 4:57 PM
    nurseboy
    Jan
    Riverside, Ca
