New light wheels and mpg/power?
Discussion in '4 Cylinder' started by tacoslocos, Jan 14, 2013.
  1. Jan 14, 2013 at 8:03 PM
    tacoslocos
    tacoslocos [OP] Member
    Hey friends,
    I have a '11 2.7 4x4 ac auto and am thinking about getting some new wheels for it to replace the stock steelies (specifically the mb72 in 16"). I see that they are pretty light and affordable and am curious if any of you have noticed any mpg or power increases going to a light aluminum wheel from the stock steelies? any lighter in the unsprung weight can't hurt right?
    Thanks and keep on truckin!
  2. Jan 15, 2013 at 12:04 PM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    You most likely will not see any change. Go with the wheels for looks but run a skinnier tire
  3. Jan 15, 2013 at 1:52 PM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    I did the change over and saw nothing but its prolly my tires that made it that way. I still see 27avg
  4. Jan 15, 2013 at 1:56 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    When I bumped up from a 15" wheel to a 16" and 28" to 31.7" tires I kept it as light as possible and mileage went up a bit (with a few other things replaced too, like everything from my intake back through the headers and exhaust.)
    Point is, I went up nearly 4 inches and didn't lose mpg because I kept it very light. It does help.
    I'm not saying you'll see the same because of the number of mods I did when I fixed this little Pickup up, but I am saying that lightweight will make a small difference, added on top of whatever other things you do over time that make a small difference will yield you greater FE.
  5. Jan 16, 2013 at 1:32 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    How much do those wheels weigh OP?
  6. Jan 16, 2013 at 4:01 PM
    JayC06
    JayC06 Well-Known Member
    Jay
    fairhaven ma
    06 4cyl ac 4x4
    5100's front at 1.75, procomp light bar, kc lights, dynomax muffler
    i noticed my mpg went up a few when i went from steelies to new wheels.
  7. Jan 17, 2013 at 12:13 AM
    tacoslocos
    thanks for the answers very helpful!. I pulled the trigger and should have them installed next week. i believe they are 23 lbs. Not expecting them to pay for themselves but i do like the look. Any mpg/ power increase would just be icing on the cake!. I haven't seen many threads about this topic specifically regarding the 4cyl so keep the responses coming if anyone has any further input!
  8. Jan 17, 2013 at 9:20 AM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    I weighted one of mine last night 81.3lbs. That's wheel and tire combo. My tires are 31x10.5-15 BFG TA/KO load C. Idk what they weigh.
  9. Jan 17, 2013 at 9:39 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Unsprung weight is not the same as rotational mass. The reduced weight of the wheels will have a few effects -- these effects are very slight, so some may be noticable and some may not:
    -- brakes more effective due to less rotating mass to slow and less overall vehicle weight, but this will also affected by the tires you choose and their available traction
    -- better acceleration (for the same reasons, also affected by available traction)
    -- better handling due to suspension's ability to respond more quickly to road surface (less unsprung weight), and less overall vehicle weight
    -- anything else that I may not have thought of :)
    The stock steelies on my 2006 2wd are quite boring, but I don't really feel any better or worse about myself because of the vehicle that I own, as long as it's not a thrashed rust-bucket POS (everyone has their minimum standards LOL). These wheels aren't ugly, they work fine for my needs, plus they probably won't catch the attention of any thieves, and that's all I really care about. Everyone's different... enjoy the new wheels! :)
  10. Jan 17, 2013 at 9:49 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Stock 16x7 steelies are around 28 lb, if I remember correctly. If the MBs are 23 lb, they aren't that much lighter, so you won't see a noticeable improvement over stock.
    Konig Countersteers (~$700/set) are 18 lb. And the Rays TE37 forged wheels ($3000/set) are 16 lb.
  11. Jan 17, 2013 at 11:06 AM
    tacoslocos
    the stock steel wheels are 32 lbs each. so around 9 lbs per wheel between stock and mb 72 at 23. 16 lbs sounds awesome though but the price for these is right
  12. Jan 17, 2013 at 5:16 PM
    KenLyns
    Belly of the Beast
    ^That's why I bought the Konigs. :D At 18 lb they are a good value.
    Something is not adding up. The tire weighs only 43 lb according BFG's website. That means your 15" alloy wheel weighs 38.5 lb. That's heavier than a 16" OEM steel wheel.
  13. Jan 17, 2013 at 7:01 PM
    tacoslocos
    16" steel wheels... I have a 4x4
  14. Jan 17, 2013 at 7:15 PM
    KenLyns
    Belly of the Beast
    ^My comment about not adding up was directed toward Kirk1589. If the numbers were true, his 15" alloy wheel would be heavier than your 16" steel wheel.
  15. Jan 17, 2013 at 8:58 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Konig Countersteers or SCS 5 spoke wheels are the way to go if you want to watch weight and not spend $ on volks ha
    18lb wheel + 40lb tire = only 58lbs per corner. The tires I "really want" weight over 50lbs a piece alone, so I'm happy with these for now. Doesn't help that I'm at about 125 hp haha
  16. Jan 17, 2013 at 10:03 PM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Re-weighted them on a digital scale made for weighting metal, 67lbs tires 44 alone according to tire rack.
  17. Jan 17, 2013 at 10:11 PM
    KenLyns
    Belly of the Beast
    That makes more sense, so the stock 15" alloy weighs 24 lb.
    BFG's site says tire weighs 42.8 lb. Tire Rack says 44 lb. Tire Rack claims to get the specs from the mfr...
  18. Jan 17, 2013 at 11:21 PM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    +/- 2lbs
