New from TOTAL CHAOS | Long Travel Sway Bar
Discussion in 'Long Travel Suspension' started by TOTAL CHAOS, Feb 6, 2019.
  1. Feb 6, 2019 at 2:02 PM
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    TOTAL CHAOS | Sway Bar For 2" Long Travel Kit (2016-2023 Tacoma)
    PART# 86090
    PRICE $516.81
    - This custom sway-bar is designed to be used exclusivly with a TC 2" long travel kit.
    - Reduces body roll and increases cornering stability at high speed.
    - Does not limit suspension articulation, wheel travel or traction at slow speed.
    - Lighter rate than the stock sway bar designed specifically to TC.
    - Reuses the stock sway bar bushings, clamps and stock sway bar end links.
    - Includes machined sway bar drop spacers to clearance the lower radiator hose and creates reservoir mounting clearance on the 4 Runner, Lexus and FJ models.
    - Hardware is included.
    - Powder coated black.
    - Does not fit vehicles with KDSS system.
    PARTS INCLUDED
    +2" LONG TRAVEL SWAY BAR - QTY: (1)
    SWAY BAR DROP SPACERS AND HARDWARE (4RUNNER, LEXUS, FJ CRUISER ONLY) - QTY: (2)
    Please contact us for any replacement parts.
    - Team TC
    info@chaosfab.com
    Wero94, naaack, ceedless and 3 others like this.
  2. Feb 6, 2019 at 4:38 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Damn, now I have to chose between total chaos LT and the new Marlin LT
    First world problems
    :anonymous:
    Tango Bravo likes this.
  3. Feb 7, 2019 at 6:58 AM
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    Hell yea! :bananadance:
  4. Feb 7, 2019 at 2:14 PM
    TOTAL CHAOS
    Corona, CA
    Let us know if you have any questions about TOTAL CHAOS Long Travel Systems
    We're happy to help make the decision easier :thumbsup:
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  5. Feb 7, 2019 at 2:15 PM
    TOTAL CHAOS
    Corona, CA
    :cool::bikewhoops:
    fatfurious2 likes this.
  6. Feb 12, 2019 at 12:54 PM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    Decision should be easy...TC in stock and ready to bolt on with thousand of real off-road world testing.
    Gunshot-6A and ripcalifornia like this.
  7. Feb 15, 2019 at 11:43 AM
    TOTAL CHAOS
    Corona, CA
    Wero94 and tubbsisland like this.
  8. Feb 28, 2019 at 12:17 PM
    TOTAL CHAOS
    Corona, CA
    Have any questions about if you need a Swaybar on your Long Travel System? Comment below!
    We're happy to answer any questions
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    Wero94 likes this.
  9. Feb 28, 2019 at 12:23 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    maybe an option to include new sway bar bushings/links/clamps? i know i threw those away along with the old bar..
    buyobuyo likes this.
  10. Feb 28, 2019 at 5:49 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    End Links: 48820-04020 / 48810-04010
    Bushings: 48815-04080
    Brackets: 48829-04030 / 48824-04050
    Bolt: 90119-A0168
    Nut: 90178-A0057
  11. Mar 5, 2019 at 12:12 PM
    TOTAL CHAOS
    Corona, CA
    Sorry, we don't plan on offering an option for the bushings, end links, and clamps. It looks like @buyobuyo commented below with the parts
    Thanks for this :thumbsup:
    ManBeast likes this.
  12. Mar 24, 2019 at 1:37 AM
    alexplb
    alexplb Well-Known Member
    why would one want a sway bar on a LT set up to begin with? Especially if one can run dual shock front?
  13. Mar 24, 2019 at 11:53 AM
    TOTAL CHAOS
    Corona, CA
    A sway bar will increase cornering stability and reduce body roll during high-speed transitions. Bypasses or secondary shocks will increase performance and adjustability but won't quite reduce sway and body roll like a swaybar.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    Wero94 likes this.
  14. Mar 24, 2019 at 12:30 PM
    alexplb
    Ok but what about limiting travel ? Ideally would be nice if it was easy disconnect option of course.
  15. Mar 24, 2019 at 12:43 PM
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    The first post stated that it didn't limit wheel travel or articulation.
  16. Mar 25, 2019 at 11:46 AM
    TOTAL CHAOS
    Corona, CA
    Our custom sway bar is built with a lighter rate compared to the factory which doesn't limit wheel travel or articulation.
    alexplb[QUOTED] likes this.
  17. Apr 8, 2019 at 2:40 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
  18. Apr 9, 2019 at 9:07 AM
    TOTAL CHAOS
    Corona, CA
    At this time, we have no plans for a +3.5" Sway Bar System
    That could always change down the road. I'll let you know if we start considering it :thumbsup:
    VolcomTacoma[QUOTED] likes this.
  19. Apr 13, 2019 at 12:00 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Any plans to make one for 2nd gen trucks?
  20. Apr 13, 2019 at 10:04 AM
    taco_tallua
    taco_tallua MEGA-Known Member
    Anaheim, CA
    2016 MEGA Toyota Tacoma
    I'm here for the memes
