New DS18 Pro-St Tweeters
Discussion in 'Audio & Video' started by ClassyTacos, Aug 4, 2023.
  1. Aug 4, 2023 at 3:10 AM
    ClassyTacos
    ClassyTacos [OP] National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    I just installed these and I'm really impressed. They are far superior to the factory junk. Supposedly they are better than the Subaru tweeters and they are cheaper. In no way am I knowledgable on speakers or sounds systems, probably what I know the least about cars. It was just such a difference and so easy to do. Really helps with road noise.
    https://amzn.to/3DGAAkr
    https://youtu.be/_Dt7Fi5480U
    9pm, MonkeyChief and Soul Surfer like this.
  2. Aug 5, 2023 at 4:24 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    Just ordered a set. Thanks for the video.
    Delivery is tomorrow. Can’t beat that for service.
    ClassyTacos[OP] likes this.
  3. Aug 7, 2023 at 3:16 AM
    ClassyTacos
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Really would like to know your thoughts on the sound. Trying to figure out if I'm over hyped a little.
  4. Aug 9, 2023 at 9:04 AM
    unclewede
    unclewede Well-Known Member
    'Nard
    23 TRD Sport 4x4 Lunar
    ABSOLUTELY necessary to remove A pillar?
    Looking at my '23, it has "SRS Airbag" on both A pillar covers. Wondering if I really want to do this on my own.
    Also, driver side has no OMG bar, should I assume it's just the clips holding that side on?
    Stevie17 likes this.
  5. Aug 9, 2023 at 2:10 PM
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    You’ll need a thin pry tool to take the small square tabs out then it 2 10 mm bolts holding the a pillar on each side. And I would disconnect the neg battery cable before you start so you don’t accidentally trigger the air bag.
    ULURU, AusBerg and MonkeyChief like this.
  6. Aug 9, 2023 at 2:32 PM
    MonkeyChief
    MonkeyChief Detachable member
    ACORLR
    WTB Topper Lunar Rock 6’ Leer
    +1
    AusBerg and Stevie17[QUOTED] like this.
  7. Aug 9, 2023 at 3:07 PM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    I only had one 10mm bolt on the drivers side. I popped out the tab that said airbag and it was there.
    No need to worry about the airbags. It's super simple install and shouldn't take more than 15 minutes max for both.
    AusBerg and soundman98 like this.
  8. Aug 9, 2023 at 5:24 PM
    unclewede
    'Nard
    Order placed!
  9. Aug 11, 2023 at 12:48 PM
    Dfpftw
    Dfpftw 1luv
    SoFLA
    SoFla
    Red DCLB Tacoma
    Trd intake stuff More intake stuff Kdmax pro 10.0 yayayaya
    these speakers are loud af lol. Just installed too. I’m happy
    Man y’all I didn’t even touch the side trim pieces. I just popped and wiggled the tweeet plate right out the top cuz it’s ez
  10. Aug 11, 2023 at 12:51 PM
    Dfpftw
    Dfpftw 1luv
    SoFLA
    SoFla
    Red DCLB Tacoma
    I replaced mine while the trucks running I needed the AC man to hot outside
    don’t judge
    I popped the Tweet cover out did NOT touch airbag trim panel.
  11. Aug 12, 2023 at 8:43 AM
    MonkeyChief
    ACORLR
    Pretty easy install, about 20 minutes with a two bum legs and sausage fingers
    ClassyTacos[OP] and Stevie17 like this.
  12. Aug 12, 2023 at 3:42 PM
    Phenom3030
    Phenom3030 Well-Known Member
    Jon
    Colorado Springs, CO
    2021 Lunar Rock TRD Pro
    OEM+
    Anybody with the JBL system install these and notice an improvement?
  13. Aug 13, 2023 at 3:56 PM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    I don’t think they will work…can’t tell you why specifically. I’ll leave that for a more knowledgeable audio file to explain. I have recently read another threads saying it’s a no go. Different ohms and connectors…or something like that.
    Phenom3030[QUOTED] likes this.
  14. Aug 14, 2023 at 11:44 AM
    MonkeyChief
    ACORLR
    These sound great, but clearly now there’s very clear, much more articulated Chris sound coming from the dashboard, and really not much sound coming from anywhere else. We all know the rear door speakers really aren’t worth much when it comes to family in the cabin with sound, but it’s so obvious now that the door speakers in the front are just weak.
    I ordered checkers over the weekend from Crutchfield and they should be here Thursday. This weekend I’ll get into sound deadening, and a little soundproofing and installing those, I can only imagine how much better overall the front of the cabin will sound.
    I have other plans for the rear, so I won’t be throwing in anything in the doors just yet.
  15. Aug 14, 2023 at 11:48 AM
    unclewede
    'Nard
    Accomplished in about 20 minutes Sunday morning. Didn't know how much difference they would really make. From all the TW videos I saw, I showed up with both 7mm and 10mm. On the 23, only 10mm was needed. I was britting shicks that I was going to drop that 10mm into the hole when swapping the actual speakers. That thing seemed to have a bottomless potential!
    The big test for me was freeway speeds with the window down. Didn't need to adjust the volume at all to continue hearing Free Bird jam!
    Since I'm in an Access Cab, the rear speakers have negligible worry.
    I could actually feel a new pressure on my ears if I have the level above about 25. Almost uncomfortable.
  16. Aug 18, 2023 at 2:22 AM
    ClassyTacos
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Be prepared, once these are in they will motivate you to upgrade the rest of the speaker junk in the truck. No way around it, got the sound deadening and new speakers in over the weekend. Huge improvement. This is one of those upgrades where you really don't realize how bad the factory stuff is until you feel the difference. Unless you're into sound systems, of course.
    Stevie17 and daveeasa like this.
  17. Aug 18, 2023 at 2:33 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Sound skins makes a set custom cut for DC 3rd gen. Very straightforward install, just a bit of time and patience. Good option for the classy guy to do a video.
    audiofrog 6x9’s w taco tunes adapters fill out the front doors nicely.
    Rears are for your kids so that’s a good place to save money :)
  18. Aug 21, 2023 at 12:58 PM
    unclewede
    'Nard
    MUST
    NOT COME BACK
    into this thread!!! :spending:
  19. Aug 26, 2023 at 7:28 AM
    TacoTaco-BurittoTaco
    TacoTaco-BurittoTaco Well-Known Member
    James
    Georgia
    2023 TRD Off-Road DCSB
    Stock
    Do you have a link for that by chance?
  20. Aug 26, 2023 at 12:03 PM
    daveeasa
    David
    PNW
