New Cold Air Intake Install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jjcc, Mar 22, 2017.
  1. Mar 22, 2017 at 9:46 PM
    jjcc
    jjcc [OP] Member
    Hello everyone-
    So I just installed a cold air intake on my 2017 Tacoma Off-Road. This is my very first time installing one, I think I did ok installing it. The step-by-step instructions are not very well explained but I think I did ok put in it together.
    The question that I have for those who have one in their trucks, is the following. Are you suppose to hear a gasping/throttle body noise whenever you press the gas to rev the engine? Or is it that the filter is sucking-in the air that is making that noise?
  2. Mar 22, 2017 at 9:51 PM
    jjcc
    jjcc [OP] Member
    I installed a K & N cold air intake.
  3. Mar 22, 2017 at 10:00 PM
    Jkwolfe09
    Jkwolfe09 Well-Known Member
    Jerren
    Cedar Park, Texas
    2016 Blazing Blue Pearl Tacoma
    Pro Comp 6 inch lift, Toyo MT 33 12.50 R20 on Fuel Cleavers
    It is your air filter bringing in air wait until you hit 5k rpms for the first time! It gets loud lol
  4. Mar 22, 2017 at 10:06 PM
    jjcc
    jjcc [OP] Member
    Ok cool, I was a little worried that it was something else. I'll hit 5K rpms tomorrow morning lol
  5. Mar 22, 2017 at 10:15 PM
    Mceaglefan5
    Mceaglefan5 Member
    Joe
    Black n tan 16
    Does it improve your gas mileage?
  6. Mar 22, 2017 at 10:22 PM
    Jkwolfe09
    Jerren
    Cedar Park, Texas
    Let me know what you think about that 5k rpm range lol
    as far as gas milage ehh not so much help but it really wakes the truck up in throttle response!
  7. Mar 23, 2017 at 2:03 AM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    From an idle, if I hit the gas, I can hear my trucks stock intake. You def are hearing that from a K&N.
  8. Mar 23, 2017 at 3:56 AM
    Mr-Paul
    Mr-Paul Well-Known Member
    Paul
    2017 Qucksand Tacoma SR5 4x4 V6 Access-Cab
    It is even louder when actually driving under a load. It is not noticeable when driving under conditions. I have the K&N. I like the sound when you stomp on it.
  9. Mar 23, 2017 at 3:08 PM
    crymes
    crymes Well-Known Member
    Cameron
    CT
    2017 TRD OR DCSB QS
    kind of a silly question, but do you need to get a tune for a new CAI? or does the MAF values just automatically get processed by the ecu for it to be safe
  10. Mar 23, 2017 at 3:27 PM
    meyergsr
    meyergsr Well-Known Member
    Frederick, MD
    17 Tacoma OR, AC
    Yes the ECU will adjust for the increase in air flow. No tune needed
  11. Mar 23, 2017 at 4:07 PM
    DoubleAction
    DoubleAction Well-Known Member
    Any noticeable throttle response benefit?
    Thunder Fist likes this.
  12. Mar 23, 2017 at 4:14 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Is it worth it?
  13. Mar 23, 2017 at 4:21 PM
    Mr-Paul
    Paul
    I can't tell much of a difference in power on the V6. It does sound better for me.
  14. Mar 23, 2017 at 4:24 PM
    Mr-Paul
    Paul
    After spending $35K on a new truck, $300 is not even a concern. I like how it looks and it sounds good to me.
    I am not installing an aftermarket exhaust because I think the truck sounds like a tuner/rice burner with it.
  15. Mar 23, 2017 at 6:56 PM
    Mceaglefan5
    Mceaglefan5 Member
    Joe
    Black n tan 16
    What does the k&n intake run?
  16. Mar 23, 2017 at 8:57 PM
    Jkwolfe09
    Jerren
    Cedar Park, Texas
    if you drive with the ect button on all the time like me you will notice the extra pick up you get around 4k rpms
    Mr-Paul likes this.
  17. Mar 23, 2017 at 10:05 PM
    k_j_souv
    k_j_souv Well-Known Member
    NorCal
    3G OR DCSB, Dual Case, 42s
    I'm considering adding a TRD intake, but is there a real gain in HP?
  18. Mar 23, 2017 at 10:08 PM
    k_j_souv
    NorCal
    Also, I'm kind of afraid of it sounding like a Honda civic tuner car
  19. Mar 24, 2017 at 5:38 AM
    DoubleAction
    You can't gain hp I think people are getting throttle response when increasing the airflow but you have to do it at both ends and also add a y tube magna flow exhaust system.
  20. Mar 24, 2017 at 9:01 AM
    su.b.rat
    su.b.rat broken truck
    doesn't change the sound like that, not even a bit. no problem. just a tad more intake woosh in the cab and a bit of improved throttle response. nothing weird.
