New brakes grinding - Fixed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrlee, Jun 22, 2019.
  1. Jun 22, 2019 at 7:33 PM
    mrlee
    mrlee [OP] I like crunchy Tacos!!
    2013 TRD Sport (Yeah, it's gotta skewp, Haterz gonna hate)
    Bed rug, ARE bed top, Weathertechs. Little goodies here and there!
    Hello everyone.
    I replaced my rotors and pads today. Took me longer than I thought as this is the 1st time doing on a Toyota and those rotors were a.bitch to get off.
    So I went to test drive and didn't even get down the block as there was a lot grinding. I've never heard this after placing brakes and I've done many, but not toyos . Just turned around and came home. Pads are installed correct. They are Toyota factory pads. Rotors are Powerstop JBR1121XPR which I've verified they are correct per multiple sites.
    Attached a pic of what they already did to the rotors. Btw, it's like this on both sides.
    Is this normal before break in? Resolution was the backing plate was rubbing. Once that was taken care, all was quiet.
  2. Jun 22, 2019 at 7:36 PM
    mrlee
    Whoops,.meant to post on 2nd gen forum.
    @tcBob can you move this to 2nd gen thread?
  3. Jun 22, 2019 at 8:59 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Did you go through the bedding process? Check for any paperwork in the box the pads came in. That rust resistant coating on the rotors is going to wear off the contact surface and they should smooth out.
    You really should bed them though. If you can't find the instructions in the pad box, do a little Google search.
    mrlee[OP] likes this.
  4. Jun 23, 2019 at 6:03 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    I bet you simply put the new pads in and did not take out the pins the calipers slide on, clean them up and regrease them with silicon grease.
    Even though those pins have a rubber boot, they still take on moisture and develop rust. When you put in the new pads, the brake calipers are pushed open to a new spot and often no longer move the way they are supposed to on the pins due to the rust and junk that is on the pins. That causes the new brakes to hold their position when applied instead of relaxing like they should and thus the wear on the rotors.
    I also bet you smelled burning brake pads also.
    Get back in there and take those pins out and service them and all will be good again.
    Biscuits, winkel and mrlee[OP] like this.
  5. Jun 23, 2019 at 6:09 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You're thinking of 5 lug calipers.
    The 6 lug cals are fixed w/pistons on both sides of the rotor. The pad retaining pins need to be clean but they dont need grease
    Was there a coating in the rotors? Any coated rotor will have a rough feel for the first couple miles until that stuff gets scraped off, keep following the break in procedure and see if it smooths out
    Biscuits and mrlee[OP] like this.
  6. Jun 23, 2019 at 6:25 AM
    mrlee
    New pins, mounting bolts, even added a second return spring
    Nice try though.
    Sound didn't change when applying brakes
  7. Jun 23, 2019 at 6:28 AM
    mrlee
    Sound didn't change when pressing brakes. Sounded like metal on metal. I'm going to pop off a wheel this morning and look closer to see if I can find the source
  8. Jun 23, 2019 at 6:31 AM
    mrlee
    Sounded like metal on metal and didn't change when pressing brakes. Freaked the shot out of me so turned around.
  9. Jun 23, 2019 at 7:50 AM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    Didja tweak the dust shield into contacting the rotor? It's not hard to do, and the symptoms fit the bill.
    On the rear of Subarus, they spot weld a thinner dust shield to the thicker parking brake backing plate, in what looks like a pinch weld. In rusty areas, that joint likes to "bloom" with rust, and a lot of aftermarket rotors don't have enough chamfer inside the drum-in-hub inside lip to clear... it's rather harmless, but you should hear the racket it makes.
  10. Jun 23, 2019 at 10:50 AM
    mrlee
    Nope
    I just finished removing wheel and nothing but pad is touching. Never knew toyo pads were so noisy prior to break in. Gonna go give her hell in a few and see if it irons out.
    b_r_o likes this.
  11. Jun 23, 2019 at 12:40 PM
    mrlee
    Ding, ding, ding, you were right. Thats some tight fitting shields. All is good now. Thank you very much
  12. Jun 23, 2019 at 12:43 PM
    mrlee
    Turned out to be the shields rubbing. Thanks everyone. Tacomaworld rocks
    Biscuits and TnShooter like this.
  13. Jun 23, 2019 at 1:27 PM
    Tacologist
    Bob
    Tenessee
    Gave it my best shot from my own past (and a bit lazy) experience. Glad to hear you got it taken care of though. I will remember that fix.
    Biscuits and mrlee[QUOTED][OP] like this.
  14. Jun 23, 2019 at 1:37 PM
    mrlee
    No problem man, appreciate the responses. I probably shouldve put it out there in the 1st place. Thanks
  15. Jun 23, 2019 at 3:48 PM
    fb40dash5
    11 V6 AC 4x4
    I kinda figured, once you said it didn't change when you apply the brakes... even putting the pads in backwards (you laugh, and you should, but it has been done!) would sound different when you hit the brakes. Sound doesn't change = something outside of the normal pad/rotor contact points.
    mrlee[QUOTED][OP] likes this.
  16. Jun 23, 2019 at 4:01 PM
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    did you break them in go 40 50 come down hard on brakes do that a few times all the noise will be gone
  17. Jun 23, 2019 at 5:24 PM
    winkel
    Corydon, IN
    Glad you got it sorted out! :thumbsup:
  18. Jun 23, 2019 at 5:25 PM
    mrlee
    Backing plates were rubbing. Once that taken care of, did breaking period
  19. Jun 23, 2019 at 5:27 PM
    mrlee
    My sentiments as well. I was really concerned the rotors rubbing on the calipers, but just didn't make sense.
  20. Jun 24, 2019 at 6:29 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Could you add “FIXED” to the thread title?
    Helps when others are searching for a similar problem.
