New Brake Pads measurement in mm
Discussion in '3rd Gen. Tacomas (2016-2023)' started by brosenz, Jun 19, 2020.
  1. Jun 19, 2020 at 1:28 PM
    brosenz
    brosenz [OP] Well-Known Member
    What is the brand new Brake Pads measurement in millimeters (mm) , for the Front and Rear brakes, thank you
  2. Jun 19, 2020 at 1:40 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Front: 12 mm new 2WD, 11.5 mm new 4WD , 1.0 mm minimum
    Rear: 5.0 mm new, 1.0 mm minimum
    TeecoTaco likes this.
  3. Jun 19, 2020 at 1:41 PM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    ^ what he said
  4. Jun 19, 2020 at 1:43 PM
    brosenz
    Today I brought my truck for the first service, with 3,670 miles, the multipoint inspection said the Front brake pads were 10mm and the Rear 4mm, it sounds like too much to me for just 3,670 miles, or maybe it is just a measurement mistake? It is easy to miss 1mm
  5. Jun 19, 2020 at 1:47 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I guarantee they didn't actually measure your pads. They just threw something on paper because they had to.
    mattleg and TeecoTaco like this.
  6. Jun 19, 2020 at 2:01 PM
    Jmac2408
    Jmac2408 Well-Known Member
    Justin
    Southern California
    18 TRD Off Road 4x4
    probably eye balled it since they’re practically new
  7. Jun 19, 2020 at 2:04 PM
    VirusCage
    VirusCage Well in the secondary immune response
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 1995 Landcruiser 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    I took mine in for my free inspection in April....they told me I need tires and brakes. I said really?!? The writer said yep and called the tech up. The tech scratched their head and said "I didnt even bring the truck in yet". They were literally going by age of the truck alone. I had just put new tires on the truck and checked the brakes myself BTW. At least the tech was honest.
    Skydvrr likes this.
  8. Jun 19, 2020 at 2:13 PM
    brosenz
    When they delivered the car I open the hood to check, the "dip stick" was loose, at least 5-7 inches far from the close position, I called the advisor, he called the tech, tech didn't even say sorry, he said, no worries nothing would have happened. Then driving home I noticed the PSI for the tires was 35 vs 29 in the cluster, I had setup 29 prior, called the advisor when got home, and he said, the machine is set to 35 psi, there is nothing they can do to check, I said why did you put air if the tires were ok, he said, well, we don't measure the PSI, we just connect the compressor and put air until it stop automatically at 35 psi. This is ridiculous, I did expect something like this, but to be honest, this is too much, basic stuff. I can't imagine having them replacing the water pump or something major, it would be a mess.
  9. Jun 19, 2020 at 2:18 PM
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    Tech's are paid by the job (book time) regardless of how long it actually takes. So, it is in their best financial interest to do the job as quickly as possible.
  10. Jun 20, 2020 at 9:51 AM
    rolled93slc
    Jerry
    Lynchburg VA
    I work for a dealer. Shop procedure is to set tires to 35 psi. This is done for several reasons. 1. Most people don't check their pressures to maintain proper pressure. 2. To help eliminate the "my tire light is on" walk ins.
    IF people actually checked their pressures, we wouldn't do this. But most people are too lazy or were never taught how to. So be happy they actually set tire pressures.
    Jmac2408 likes this.
