New Battery for the Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by fss, Nov 28, 2023.
  1. Nov 30, 2023 at 5:33 AM
    #41
    phoforbreakfast
    phoforbreakfast Well-Known Member
    I use the Duracell AGM batteries at Sam's Club and if I recall, they are rebranded East Penn which is Deka.
  2. Nov 30, 2023 at 6:11 AM
    #42
    Markmmg
    Markmmg Well-Known Member
    Mark
    Baton Rouge, LA
    Prerunner double cab
    I buy Interstate batteries from Costco. I would definitely stay away from Autozone Duralast Gold batteries. I have had very bad luck with those. My previous vehicle was a Jeep Wrangler. One Sunday my Jeep barely started and I was near an Autozone so I went there and bought a battery. About 11 months later that battery went out. It was under full warranty so it was replaced for free. That replacement battery died after 18 months. The warranty was prorated so I only had to pay a little for another battery. That 3rd battery did not last 2 years. After that, there was no warranty left so I went to Costco and bought an Interstate battery and it was still going strong several years later when I sold the Jeep.
    Charlie Bravo and ScrippsRanch67 like this.
  3. Nov 30, 2023 at 11:30 AM
    #43
    Toyotas4Tots
    Toyotas4Tots Well-Known Member
    NC
    2023 Tacoma SR5
    Oh it’s not cheap. Usually runs in the neighborhood of $260ish installed
  4. Nov 30, 2023 at 9:30 PM
    #44
    808BOGEYMAN
    808BOGEYMAN Member
    Dino
    98 4x4 limited xtra cab 3.4
    I was a big fan on Optima Red tops. First one lasted 9 yrs and 2nd lasted 7yrs. When I needed a new battery spring of last year, all the horror stories of the Optima’s that are now made in Mexico made me start looking for something else. Lucky for me I work next door to the Interstate Distributor and was able to pick up a 24f AGM MTX. All the stats for RC and CCA were comparable to the Optima and cost $100 less. After 18 months and with the added GM diode in the Alt-s fuse box, happy to say I’m hooked on this setup.
    Side note: I live in Hawaii so we don’t have extreme temps to deal with, always nice 80degrees, so your mileage may vary
  5. Nov 30, 2023 at 9:36 PM
    #45
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    I had both Sam’s and Costco. Nothing beats the Toyota 27F from the dealership. Price was even cheaper.
    Kolter45 likes this.
  6. Dec 2, 2023 at 8:53 AM
    #46
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
  7. Dec 2, 2023 at 5:17 PM
    #47
    asuchemist
    NONE
    I figured they didn’t manufacture the batteries. But possibly they require higher specs or something.
    The good thing about Costco the battery always died before the warranty. They would always just give me my $ back and I would buy again. Finally I think they only replace battery once or until original warranty ends.
  8. Dec 2, 2023 at 6:57 PM
    #48
    tacoman2001$
    tacoman2001$ Well-Known Member
    Interesting. I have yet to have one go bad. I pick them up for like $200 so it's not that bad. If it lasts 6 years instead of 3 I consider it a win.
  9. Dec 6, 2023 at 5:36 PM
    #49
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 80K miles
    FOX 2.5, Deavers, ARB, 4xInnovations
    I just installed a Noco Gen5X1 on-board in my gen 2.5 Fits nicely on the inside of the fender, to the right of the battery (when standing facing the back of the truck.)
    My Optima yellow-top is about 2 years old, seems OK but maybe weakening a bit from not being fully charged over time.
    Did you use the special "battery repair" mode on your NOCO to restore your yellow-top AGM, or did the NOCO just do it "naturally" over repeated normal AGM charge/top-off/maintain cycles?
  10. Dec 6, 2023 at 9:15 PM
    #50
    leid
    leid Well-Known Member
    Brandon, MS
    1997 V6 Tacoma 4x4 & 2020 V6 Tacoma TRD 4x4
    ECGS & ZUK diffs w lockers/Marlin R150F/NITRO axles/winches
    It took several normal AGM cycles to bring the 2013 Optima Yellow Top back, but the 2016 Yellow Top normalized after just a single AGM charge cycle.
    GilbertOz[QUOTED] likes this.
  11. Dec 7, 2023 at 6:10 AM
    #51
    voodoomaster33
    voodoomaster33 VoodooMaster
    Dave
    Asheville NC
    02 Std Cab 5 spd 4WD Mystic Gold
    Lifted a little.........
    Go with a DIE HARD.......however, I just saw a Copper Top....a Duracell. Sounds interesting.
  12. Dec 7, 2023 at 8:19 AM
    #52
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    I've moved on from Costco interstate batteries to Walmart everstart. I just didn't have a good experience with the Costco batteries after a few that died at the 3 year mark.
    asuchemist likes this.
  13. Dec 8, 2023 at 4:54 PM
    #53
    Spirohydra
    Spirohydra Member
    Jake
    2004 Toyota Tacoma Crewcab Silver TRD
    Interstate battery has always worked for me
  14. Dec 8, 2023 at 9:46 PM
    #54
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Those have a 3 year warranty-lifespan?
  15. Dec 9, 2023 at 7:25 AM
    #55
    LanceRN
    Lance
    Yes.
  16. Dec 9, 2023 at 8:48 AM
    #56
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    I'm at the 6 year point with an everstart.
  17. Dec 23, 2024 at 7:46 AM
    #57
    suomiM31
    suomiM31 Well-Known Member
    Could someone explain to me the rationale and details of how this arrangement works.I carry a charged up NOCO Boost HD GB70 2000 in my emergency recovery box.
    Thanks for any kind explanation,no need to tell me I'm ignorant about such things, I already know that.
    Cheers!
  18. Dec 23, 2024 at 7:54 AM
    #58
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    Not sure what the question is but this is why i did this. I drive very little now and sometimes not for weeks. I keep the charger plugged in to keep the battery fully charged and it even helps to keep it a little warmer on really cold days since at the point it drops to just a trickle charge it still adds a little warmth. And I agree if my odyssey battery dies an under hood charge wont save me. Its more about trying to extend the useable life and compensate for my infrequent and mostly short trip driving style.
    As for how it works its attached directly to the battery and the cord sticks out a short distance from the front grill and is secured with zip ties.
    leid and suomiM31[QUOTED] like this.
  19. Dec 23, 2024 at 8:17 AM
    #59
    suomiM31
    I think I got it now, it's being used like I use a trickle charger on my quad in the winter. I only use the quad to plow my driveway during winter. I couldn't see in your photo that your device was plugged in to an external power source.
    Thanks for the clarification.
    Merry Christmas to you and yours!:santa:
  20. Dec 23, 2024 at 6:52 PM
    #60
    JuniorVarsity
    JuniorVarsity I'm not a pickup truck guy. I have two.
    PacNW
    1999 Tacoma SR5 4x4, 2021 TRD Sport Access Cab
    Lots of good anecdotes here. OP @fss what did you decide? And why replace a 3.5yr old battery? dead, or preventive maintenance? Go Air Force!
    Charlie Bravo likes this.
