New Battery for the Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by fss, Nov 28, 2023.
  1. Nov 28, 2023 at 6:43 AM
    fss
    fss [OP] Member
    Fred
    2004 silver tacoma sr5
    air cleaner
    I want to replace the three and a half old battery in the Tacoma. What is the best brand to buy?
    Thanks for your time.
    Black97v6MT likes this.
  2. Nov 28, 2023 at 6:50 AM
    Clearwater Bill
    Billy
    Largo Florida
    Normal people find Interstate from Costco a good value.
  3. Nov 28, 2023 at 6:51 AM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    define best, please
    Black97v6MT and Kiloyard like this.
  4. Nov 28, 2023 at 7:05 AM
    Svridge
    Svridge Well-Known Member
    Ventura, California
    '99 Tacoma Extended Cab, 3.4l Pre-Runner
    Walmart has the best prices and warranty in my opinion
    Black97v6MT, wee, Bob12321 and 2 others like this.
  5. Nov 28, 2023 at 7:25 AM
    cbhunt
    cbhunt Active Member
    Brad
    1997 Toyota Tacoma 4x4 V6 Xtracab 5-spd Cardinal Red
    Black97v6MT, leid and cruiserguy like this.
  6. Nov 28, 2023 at 7:30 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
  7. Nov 28, 2023 at 8:00 AM
    leid
    leid Well-Known Member
    Brandon, MS
    1997 V6 Tacoma 4x4 & 2020 V6 Tacoma TRD 4x4
    ECGS & ZUK diffs w lockers/Marlin R150F/NITRO axles/winches
    Luckily, I installed EverStart Platinum 24F AGM batteries from Walmart in both of my 4WD Tacomas in December 2021. The 24F was an optional size on my '97 V6 Taco 4x4 and the standard size for the '20 TRD 4WD. Both Tacos have large battery killing winches up front & these AGM batteries have worked very well for my purposes. I did a tremendous amount of winching with the '97 V6 Taco 4x4 when an unforcasted tornado ripped thru the woods while I was turkey hunting in April 2022. Over the next 4 days, I had to cut and remove 55 hardwood trees from the trails and roads just to get out. That EverStart Platinum 24F AGM battery performed very well powering the old 8K Warn winch even with the original small 70A alternator in the old Taco.
    EDIT: After checking my notes, the original OEM Denso alternator in my 1/97 built '97 V6 Taco 4WD was not rated at 70A as posted above. It was only rated at 60A which was just too small to support the power-hungry older 8K Warn winch on front of the Taco. I have a new 80A Denso on it now only because the high output Denso 210-0461 reman. 105A alternator now available from RockAuto and Summit was unavailable at that time. The new Denso 80A alternator charges at 14.4V which works very well with the AGM battery, so no need for the ALT-S mod. with the 1A diode to boost the charging voltage.
    Just after the embedded tornado came spinning thru sounding like a jet on takeoff:
    The last oak trees blocking my way out 4 days later:
    Fantastic11, gilligoon and tacoma_ca like this.
  8. Nov 28, 2023 at 8:31 AM
    Wyoming
    Wyoming Well-Known Member
    Alex
    Nunya, WY
    03 Lunar TRD 4x4 Xtracab
    sunflower seeds under the seat
    Holy smokes, crazy story! :cheers: I've always thought about the chance of a tornado or fire when you're already deep in the woods... glad to hear you made it out, thanks for the great reminder of how a capable truck can be indispensable when things go sideways!
    OP, I went with the gold lead acid Everstart last winter and it's done fine for me, even through some tough negative temps. My friends tease about the "Neverstart" but it hasn't let me down yet.
    leid[QUOTED] likes this.
  9. Nov 28, 2023 at 8:33 AM
    Toyotas4Tots
    Toyotas4Tots Well-Known Member
    NC
    2023 Tacoma SR5
    Toyota offers lifetime batteries (and front brake pads and rotors) for most models now.
  10. Nov 28, 2023 at 8:40 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    The best battery is a fresh battery....and they dont come any fresher than the Walmart everstarts...
    a lot of times they sell em so fast.....they're still on the pallet...
    Cucvfan, Svridge and leid like this.
  11. Nov 28, 2023 at 8:40 AM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    My definition of best IMHO
    Odyssey extreme 34R with 2 amp battery maintainer (which has been update to a 5 amp)
    Bahamayellow and leid like this.
  12. Nov 28, 2023 at 8:40 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Bottom line if you have see every battery made you have basically seen all 3 or 4 of them. Tons of different name though.
    taco57, 808BOGEYMAN and wayupnort like this.
  13. Nov 28, 2023 at 9:33 AM
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    I run the Odyssey extremes (2 of them) in my other truck, hoping to get a long service life out of them. I will only use AGM batteries but I went cheaper for the Tacoma and stuck an Exide AGM in it. Prior to that it had a Diehard Platinum, from back when they were essentially a relabeled Odyssey. It got pulled at around 9 years of use.
    Do they make a 5 amp maintainer designed to be mounted like the 2 amp?
  14. Nov 28, 2023 at 11:02 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    NAPA 27F battery installed 2013 in my 2011 still there and I also runs my plow motor!
    TartanEagle, wayupnort and leid like this.
  15. Nov 28, 2023 at 2:49 PM
    babylon5
    David
    I have mounted my 5 amp on the driver side fenderwell. Used stainless rivet nuts and allen head bolts.
    leid and Gen1andDone[QUOTED] like this.
  16. Nov 28, 2023 at 2:55 PM
    v5ensx
    v5ensx CARB legal is not CALI legal
    o_O
    MadNachos likes this.
  17. Nov 28, 2023 at 3:00 PM
    babylon5
    David
    My factory Toyota battery dies at almost exactly two years. Was on the way home from work and parked at the top of my street to get groceries. Came out and totally dead. Luckily its a down slope to my house. Put in in neutral and coasted all the way home. Pulled the existing 34R AGM from my other car and was up and running in a couple of minutes.
  18. Nov 28, 2023 at 3:01 PM
    Toyotas4Tots
    NC
    2023 Tacoma SR5
    Call and ask if they have it for your model. That’s all I can say. I’d rather have a lifetime guaranteed battery that they’ll replace than a prorated parts store battery.
  19. Nov 28, 2023 at 3:18 PM
    THatt
    THatt Well-Known Member
    Upstate SC
    1996 Tacoma 2.7L MT 4X4
    Dang right that’s a story to survive and tell. Hope the hunt was successful. Had my own experience with a tornado producing storm predating I phones and weather alerts. Mine consisted of a terrified couple mile run to the truck through wind, driving rain, hail and trees popping all around.
  20. Nov 28, 2023 at 3:23 PM
    voodoomaster33
    voodoomaster33 VoodooMaster
    Dave
    Asheville NC
    02 Std Cab 5 spd 4WD Mystic Gold
    Lifted a little.........
    I really like a DIEHARD. Advance here in Asheville still carries them.
    All Visible Hues 14 likes this.
