New Battery/Alternator Not charging (much)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bkrdave36, Oct 1, 2024.
  1. Oct 1, 2024 at 6:01 PM
    bkrdave36
    bkrdave36 [OP] Well-Known Member
    Dave
    Wittmann,AZ
    06 Prerunner Double Cab Black
    Front OME Springs, Upper Control Arms, Icon Stage 3 Rear Leaf Springs, Durobump bump stops,Bilstein 5125 shocks, BFG All Terrain KO2 Tires, Avid Light bar and step rails, Victory 4x4 bed rack with Tepui Ayer Rooftop Tent, Anytime Fog light mod, Outside Air Temp Gauge mod, ImMrYo Rearview Mirror mod, Chinese Knockoff LED lights, Body Armor 4x4 Offroad Swingout rear tire carrier and bumper, Victory 4x4 Bed Stiffeners, Rattle can Custom Camo paint stripe, Truxedo Lo Pro tonneau cover, various Blue Ridge Overland Gear storage solutions in cab, thats it so far .... to be continued!
    This topic was covered in the 1st Gen Forum in 2020 but I'm not sure how well it translates to 2nd Gen Tacos.
    Here is my situation.
    2006 Tacoma Prerunner 4.0 V6 auto trans w/tow package. 444k miles.
    I installed a new battery because the old battery was shot. Now, my cigarette-lighter plug voltmeter shows 13.2v when the truck is driving down the road with the AC running. 12.5v at the battery when turned off (with my multimeter).
    As I'm 60+ yrs old, all of my life I'm used to seeing 14v on voltmeters when running.
    I picked up a remanufactured Denso alternator for my truck and installed it (what a pain!). Nothing changed. Still have the same voltage readings.
    On the post I mentioned at the beginning from the 1st Gen Forum, people were talking about the green plug and 3 wires coming out of the alternator going to a fuse block? They were saying that the culprit usually lies in those wires. Does this sound familiar to anyone? If it is, they say it goes into a box under the fuse box. Which fuse box? The one under the dash by the drivers left knee or the one under the hood on the driver side?
    Does anyone know of a link, a video, some photos, etc. that might help decipher this?
    I really hate (and suck at) automotive electrical so any assistance would be appreciated.
    Thanks.
  2. Oct 1, 2024 at 7:08 PM
    Bishop84
    Bishop84 Well-Known Member
    Batteries should be 12.4-12.6 off.
    Modern vehicles should be 13-14.4 running.
    Revelations, bkrdave36[OP] and Dm93 like this.
  3. Oct 1, 2024 at 7:10 PM
    shmn
    shmn Well-Known Member
    Pacific NW
    2007 Tacoma 2.7L 5sp
    Take a reading at the battery with AC and lights off and engine revved up to at least 1500 rpm. At idle the alternator puts out less volts and amps. Before assuming there is a problem, collect some good data first.
    TXpro4X4 likes this.
  4. Oct 1, 2024 at 7:24 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    This
    2nd gens run around 13.2-14.4 depending on temperature, higher temps = lower charging voltage.
    bkrdave36[OP] likes this.
  5. Oct 1, 2024 at 7:35 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    It is an '06
    The alternator may have gone out
    By any small chance you know if any like WD-40 or oil, lub of any kind has gotten in bindings of the alternator?
  6. Oct 2, 2024 at 3:13 PM
    bkrdave36
    Dave
    Wittmann,AZ
    Alright. I took the multimeter out. The following readings are measured at the pos and neg posts on the battery.
    Truck off (after having driven around town today.) 12.7v
    Truck on and running (at idle)13.4v
    Truck on and running (at idle) with radio, AC, lights on 13.3v
    I am by myself so I don't have anyone to press down on the throttle until later this evening.
    Ambient outside air temp at time of measurement 105F (I live outside of Phoenix AZ)
    Is this low? Or am I good?
  7. Oct 2, 2024 at 3:15 PM
    bkrdave36
    Dave
    Wittmann,AZ
    Its a "new" (remanufactured Denso) alternator that I just installed yesterday. The battery is new as well, it was installed early last month.
  8. Oct 2, 2024 at 3:19 PM
    bkrdave36
    Dave
    Wittmann,AZ
    If it means anything, the "Charging System light" (battery symbol) on the dash does light up when the key is turned to ignition. When engine is running it goes off.
    But there are no codes showing or other lights showing on the dash.
  9. Oct 2, 2024 at 3:43 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Perfectly normal, mine stays 13.2-13.4 on a warm day. Has since it was new.
  10. Oct 2, 2024 at 4:24 PM
    Waasheem
    Waasheem
    2007 xrunner
    I have this chart. 12.7 puts you at 80%, which is ok. Look at column E, 12s meaning 12v static. Column F is for load testing.
  11. Oct 3, 2024 at 12:22 PM
    bkrdave36
    Dave
    Wittmann,AZ
    Sounds like I'm OK, and maybe I should ditch the "Jungle website" digital voltmeter/ USB charge port that plugs into cigarette lighter?
  12. Oct 5, 2024 at 3:17 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Ignore the Amazon voltage reading.
    I too have been a victim of “shitty” products.
    Cheap garbage does one of two things.
    Creates a problem.
    Or has you looking for a problem that doesn’t exist.
    SUMOTNK and Dm93 like this.
  13. Oct 5, 2024 at 3:55 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer), Factory/TSB OEM rear leaf spring modification.
    With those numbers, I don't really think you have a problem. Heat and high temps influence the numbers as much, (down) if not more than when cold.
    I have had several cars with factory volt meters/gauges and they all indicated higher voltage readings in the winter verses summer, soon after initial the initial start-up and warm up. Turn on everything you can in the truck, including fan on high speed, lights in high-beam, AC, etc. and check the numbers again. They should be very close to what you see with everything off. The alternator and battery should be able to handle the load and maintain the voltage.
  14. Oct 8, 2024 at 10:49 AM
    Rep15
    Rep15 Member
    Tumwater, Wa
    2005 red Tacoma TRD
    I’m having the same problem. Instead of talking about voltage and amps, does anyone have an answers to his actual question. How may wire are connected to the alternator post and where is the fuse bloc. I know that the fuse block is separate from the two fuse boxes he mentions.
  15. Oct 8, 2024 at 11:29 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Not sure what your question is?
    The charging system description & operation as well as wire colors and pin designations can be found in the post below.
    https://www.tacomaworld.com/threads/2nd-gen-information-diagnostics.784008/#post-28042155
  16. Oct 8, 2024 at 12:39 PM
    Rep15
    Rep15 Member
    Tumwater, Wa
    2005 red Tacoma TRD
    Thanks. That helps
