New ball joints installed
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tigwelder, Nov 23, 2020.
  1. Nov 23, 2020 at 3:48 AM
    Tigwelder
    Tigwelder [OP] Well-Known Member
    Southeast texas
    2001 5 speed 4x4
    2" leveled front . 32/8.5/16 buckshot mudders
    I'd installed new Bilstein shocks and ome coils a week ago . And noticed the passenger side upper ball joint boot was cracked and no grease was left inside.
    So I ordered new upper and lower joints for both sides.
    I stopped by harbor freight and picked up a nice ball joint press kit.
    It's extremely beefy.
    The bottom wasn't bad at all . But the top was a bear . I wound up beating the upper joint out. Replacing it was easy with the press.
    I'm waiting a week or so to do driver's side.
    jammer and AKsavanaman like this.
  2. Nov 23, 2020 at 6:20 AM
    AKsavanaman
    AKsavanaman Well-Known Member
    Lower 48 :( U.P MI
    01' Xtra Cab TRD, Kings, JBAs, Dakars and 295's on F5
    Kings, JBA's, Dakars, Prinsu Rack, ARB, Trail gear sliders... and rust
    Ball joints are known to fail on our trucks ... lower more so than upper...so good on you for getting ahead on maintenance! I did my uppers not 3 months before I switched to new UCA’s....go figure.
    When I did it I kept the spindle on the truck... what a PITA that was... I know for a fact I coulda had the hub and spindle out in less time than it took me fiddling for space to fit the press in the wheel well
    jammer likes this.
  3. Nov 23, 2020 at 6:52 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Could you tell us the part number of the kit that you ordered, or post an image?
  4. Nov 23, 2020 at 8:21 AM
    Tigwelder
    Southeast texas
    2001 5 speed 4x4
    I'll dig it up. Or take a pic of part number. When I get back home.
    I ordered them.on Amazon.
    They came in from 1a auto .
  5. Nov 23, 2020 at 8:33 AM
    Tigwelder
    Southeast texas
    2001 5 speed 4x4
    I didn't see a part number anywhere on order page. But price and company info should be on it.
    But I know it's on the bag they came in. I'll post a pic when I get in from work.
  6. Nov 23, 2020 at 8:46 AM
    Tigwelder
    Southeast texas
    2001 5 speed 4x4
    Bottom wasn't bad.
    But the top was a bear to get out.
    With the spindle still in the truck there's no place to get a good leverage on removal clamp. And hold ball joint upright . Hold clamp from twisting. And try to tighten clamp enough to push joint out .
    When it was over I felt like I needed a new joint.
    A 5 lb shop hammer is how I finally got top out.
  7. Nov 23, 2020 at 8:49 AM
    Tigwelder
    Southeast texas
    2001 5 speed 4x4
    I may do driver's side lower during my Thanksgiving holiday. Then upper when enough time has passed for me to forget how much trouble it was.
  8. Nov 23, 2020 at 9:38 AM
    Tigwelder
    Southeast texas
    2001 5 speed 4x4
    Upper and lower packages
  9. Nov 23, 2020 at 1:34 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I'm going to suggest right now before you go and do the other side to ditch those Amazon ball joints, and get OEM or 555 branded BJs.
    You can find OEM lower BJs for !$100 a
    The lower balljoints are nothing to skimp on.
    Uppers probably aren't as critical, but jesus, the lowers are.
    Rachelsdaddy and Lfaub03 like this.
  10. Nov 23, 2020 at 1:58 PM
    Tigwelder
    Southeast texas
    2001 5 speed 4x4
    I'll look into new lowers .
    They or easy enough to change out.
    I may need a new passenger spindle.
    One of the 4 bolt holes on bracket won't get tight .
    Bolt went in fine . But won't get tight.
    And won't back out ether
  11. Nov 23, 2020 at 2:01 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Like this guy said... see that “made in China” label? Trust me, I installed a full set of those in mine. Lasted four months. Sorry for the downer.
  12. Nov 23, 2020 at 2:02 PM
    Rachelsdaddy
    Southern NH
    WHAT?!?!! Oh my Christ......find a New England style pothole. They will come right out....
    Abeyancer and Kevins60 like this.
  13. Nov 23, 2020 at 5:06 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    They said it already but ill share my experience. I bought the A1 auto kit that included the tie rods as well.. in under 10k miles of only on road driving they were scary loose when I replaced them with quality parts. I mean SCARY loose
  14. Nov 23, 2020 at 8:38 PM
    Cornerblock
    Cornerblock New Member
    SLC UT
    2002 Tacoma 4x4
    2002 4x taco. Tried replacing lots of front end stuff today. Had experienced friends with all the tools helping me. We COULD NOT get the left lower left ball joint out. I’ve been using pb blaster for six weeks in anticipation. Nuts were fine. By “could not” I mean impossible. Three grown men. Two knowing what they were doing. Heat, hammers, pressure from C clamps and ball joint press, a few choice words. Three hours. Nope. We also couldn’t get the right upper or right tie rod end out. This is rust free Texas/California truck. My friends are Nissan guys and real trail guys. They’ve done plenty of trail repairs. They were baffled. Tomorrow we will cobble it back together and limp to their mechanic. I’ve watched 20 videos just on ball joint removal on 1st gens. Most guys just beat them out. In 2020 isn’t there a more elegant, dependable way?
  15. Nov 23, 2020 at 9:11 PM
    Madjik_Man
    Colorado Front Range
    pittman puller is the elegant way
    jbrandt, Rachelsdaddy and SierraMare like this.
  16. Nov 24, 2020 at 3:07 AM
    Tigwelder
    Southeast texas
    2001 5 speed 4x4
    Good thing is ive only done one side
    Lol
    I'll order oem lower joints .
    I want to take it apart and see how to fix the one bolt hole that seems to be stripped out.
  17. Nov 24, 2020 at 4:13 AM
    Rachelsdaddy
    Southern NH
    Psst; Don’t tell anyone but I’ve had one snapped off for over 8 yrs....
  18. Nov 24, 2020 at 4:41 AM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
  19. Nov 24, 2020 at 7:13 AM
    Tigwelder
    Southeast texas
    2001 5 speed 4x4
    Oh. Hell ya. Mines staying like it is then. Lol
    It's a second vehicle I drive around town. And around 90 acres we have where I deer hunt .
  20. Nov 24, 2020 at 10:11 AM
    jbrandt
    Justin
    I stripped the 1st couple threads on mine a while back from not noticing that 2 of the bolts were shorter. Luckily, I was able to just clean the threads with the appropriate tap, and then used a slightly longer bolt (Ace hardware has TONS of good hardware - I found all the metric grade 10.9 I needed there).
    depending on which bolt is stripped, you could just use a nut and bolt, or you may need to get a helicoil kit if it's one of the bolts that doesn't go all the way through the spindle.
    good luck!
