New 255/75R17s
Discussion in '3rd Gen. Tacomas (2016-2023)' started by brian2sun, Oct 5, 2022.
  1. Oct 5, 2022 at 2:04 PM
    brian2sun
    brian2sun [OP] Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    The wife got me SEMA 4Runner wheels for my birthday, and I had to get some new 17” tires for them, so I went with some (semi) tall skinny 255/75R17 Duratracs. Not a super popular size around here for whatever reason, but I’ve seen a few. They’re a true 32x10 tire… I think the perfect “in between stock and 33s” size for a Tacoma with a small lift (mine is 1” all around). Anyway, thought I’d share if anyone cares. Cheers.
    No_Code, bizarrocolin, Ffej and 16 others like this.
  2. Oct 6, 2022 at 1:27 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Very nice! I have a 2/1 Bilstein lift with the TRD SEMA wheels but run 265/70s and looking at 275/70s or 255/75s. I'm hearing a 265/75 is coming out from Toyo and a 275 in SL or C rated as well. How is the handling with a skinnier tire and what rating C or E?
    brian2sun[OP] likes this.
  3. Oct 6, 2022 at 6:41 AM
    Gord0
    Gord0 Well-Known Member
    I have the exact same set up as the OP, just installed two weeks ago. I also a tune on my truck. Either I got lucky or this tire size/weight is the sweet spot for this truck cause it drives amazing now. Zero gear hunting, just smooth predictable power. Ride quality/handling is great so far. I’ve gone from being on the fence about selling this truck to loving it.
  4. Oct 6, 2022 at 7:22 AM
    brian2sun
    California
    Mine are SL rated (which seems to be about the same as C). The handling feels a little tighter with these new tires, I’m guessing because the skinnier contact patch, but it’s not a huge difference in handling from the SL 265/75R16s Wildpeaks I had. The New Duratracs ride about the same as far as comfort too.
    Nice. I noticed my truck has a little more get up and go now, which surprised me since these Duratracs are taller. But they only weigh 40 lbs. compared to my Wildpeaks at 44 lbs., and the SEMA wheels are 24 lbs compared to my stock OR wheels at 26, so I think losing ~6 lbs. per tire/wheel is what made the difference in better acceleration, because it’s noticeable, and a pleasant surprise! My truck has never really hunted for gears too much like most report, but I noticed it holding the gears for a few more RPM before shifting with the new Duratracs… almost like it’s halfway between the normal shifting and ECT on, which I like too. So yes I agree, I think these tires are the absolute sweet spot for my truck too!
    fatz likes this.
  5. Oct 6, 2022 at 2:42 PM
    fatz
    fatz Well-Known Member
    Ontario, Canadian
    2022 Trail
    255/75/17 Duratracs on FJ color matched steelies
    Have the same tires would agree definitely a great fit for the Taco. My wheels went up in weight with FJ steelies from Trail 16" alloys, but ride is better
  6. Oct 6, 2022 at 3:12 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    No difference in handling whatsoever coming from 265. Not sure why so many folks think that 10mm per corner makes any difference in handling.
    If we talking about 235s then I could see that.
    vicali likes this.
  7. Oct 6, 2022 at 4:14 PM
    brian2sun
    California
    I agree, there’s little to no difference in handling between 265s and 255s. And even though the 255s are a little bit skinnier, with the 4mm offset SEMA wheels, my overall stance still ended up about 1.25” wider overall than it was with my (25mm) OR wheels and 265s. My truck corners better now, rides smoother, takes off quicker, my MPGs seem about the same, and it looks better.. win win win win win.
    Junkhead[QUOTED] and fatz like this.
  8. Oct 6, 2022 at 6:17 PM
    hiimbrando
    hiimbrando Well-Known Member
    Brandon
    DFW TX
    2017 White Tacoma TRD sport
    Anyone switch from 285's to 255/75/17? I have the 285's now just wondering if its worth the switch.
  9. Oct 7, 2022 at 7:30 AM
    brian2sun
    California
    I haven’t ever had 285s on this truck, but I have had them on other trucks, and the 255s will no doubt save you some mpgs and restore a bit of that lost power coming from 285s. 255/80R17s are actual 33s (and there will still be a difference), but 255/75R17s are 32s. So, going from 285s to the these 255/75s, you’ll be going from a ~33x11 tire to a 32x10 (that’s also several lbs. lighter), and that will make a huge difference in performance.
  10. Oct 10, 2022 at 9:40 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Looks good. Do they rub the mud flaps at all in any condition? 265/70R17 on the SEMA wheels rubbed the mud flap when turning and hitting a bump or braking. Was annoying enough for me to downsize tires. I’m on the fence between 255/75 and 235/80.
    I suppose your 1" lift might help you, I have no lift and no plans to.
  11. Oct 10, 2022 at 12:20 PM
    brian2sun
    California
    I haven’t heard any rubbing on the mud flaps or anywhere else so far in the 5 days I’ve had these tires on. I’ve made a few tight turns over curbs to see if I could make it rub and it didn’t. I haven’t been on any dirt roads yet, but I don’t think it’s going to be an issue. I asked the tech to push the caster forward as much as possible at my last alignment, so that probably helped in the rub dept. too.
    BLtheP[QUOTED] likes this.
  12. Oct 11, 2022 at 1:25 AM
    VaToy
    Parts Unknown
    I have 5100s set on the 4th perch, SEMA wheels and 265/70s Toyo with no rubbing and not even close. Maybe an alignment willhelp you. The Off Road shop that I have used for years did mine and I have the factory mud guards. They swear a 285/70/Toyo at3 will fit and wont rub. I do have almost 2 inches of clearance on the closest points of contact on the factory the mud guards. a year ago I tried on a set of SEMA wheels with BFGs in 285 and they fit just perfect. Drove around and no issues, didn't flex it much. The only draw back is his center of the tire was worn versus the sides. The wheel is too narrow for a 285. Love to see a 265/75 or maybe a 275 in a SL or C rated tire from Toyo.
  13. Oct 11, 2022 at 8:27 AM
    baltimorebirds2
    baltimorebirds2 tacomama
    Brooks
    Maryland, United States
    2018 MGM Tacoma TRD Sport DCSB 4x4
    TRD Pro 17” Wheels, Toyo Open Country AT3 33s” (255/80/R17), Hooke Road Offroad Roof Rack, LEDs (Low Beams, High Beams, Fog Lights, Interior Lights, Reverse Lights, License Plate Lights), Diode Dynamics SS3 Sport Fog Lights (Yellow), Sequential Turn Signals, OME Nitrocharger Plus, OME 4004's & HS 0.5 Spacer for 3" Lift, JBA UCA, Icon RXT Option 2 Leaf Springs 2.25" Lift, Yukon Clamshell Bushing, Alpine ILX W-650 Stereo, Infinity Primus 6004a Amplifier (140w*2), Sound Ordnance M75-4 Amplifier (75w*4), Infinity Kappa 693C Component 6x9 Speakers, Infinity Kappa 63XF 6.5 Speakers, TRD Shift Knob, Black Emblem Overlays, TRD Grille Badge, OEM Door Sill Protectors, Driver’s Seat Jackers, Pop and Lock Power Tailgate Lock, AJT Designs start button and trim, 4x4 knob, shifter trim, and cupholder trim, MESO Customs Vent Rings and Door Handle Covers, Gasshole, Drop Stops, AC Drain Mod, Bed Lights, Rough Country Roll Up Tonneau Cover, Window Tint, KDMAX Tune
    They look cool. Definitely a different sort of size though. I run 255/80/17s on my rig.
    Junkhead and brian2sun[OP] like this.
  14. Oct 13, 2022 at 2:09 AM
    VaToy
    Parts Unknown
    Can you please post some more pics of the sides and rear.
  15. Oct 13, 2022 at 4:35 AM
    baltimorebirds2
    Brooks
    Junkhead likes this.
  16. Oct 13, 2022 at 1:38 PM
    acorn27
    acorn27 Well-Known Member
    2021 MGM TRD DCSB Sport
    Loving this thread as I've been looking at 265/70/17 so the 255/75/17 is an interesting option. One question that I've been wondering, are the SEMA 4-Runner wheels the same as TRD Pro wheels except for 17" vs 16"? Are there SEMA Tacoma wheels?
  17. Oct 13, 2022 at 4:17 PM
    brian2sun
    California
    Toyota only makes the style of wheels on my truck (OP here) in a 17x7 as far as I know, and they are the 4Runner TRD SEMA wheels. I know there are some aftermarket companies that make 16” versions of this SEMA wheel tho. I saw several of them when I was shopping around, but ultimately went with the OEM 17s because there are a lot more tire options for 17s compared to 16s, and the aftermarket SEMA style wheels weren’t really much cheaper than OEM anyway, so it was a no brainer for me to get the real deals.
    There are a couple different styles of Tacoma TRD Pro wheels that are 16s, but none of them look like the SEMA wheels. I believe they are all 13mm offset (vs. 4mm for the SEMAs), so they will be tucked in a little bit more as well. Toyota also makes the bronze TRD Trail Edition wheels, which are 16s and have the same 4mm offset as the SEMAs, but again, they have a different look than the SEMAs.
    baltimorebirds2 likes this.
  18. Oct 13, 2022 at 4:19 PM
    baltimorebirds2
    Brooks
    The ones I have on my truck I believe are the 2021 new style SEMA wheels, which come on the new 4 runners I think. I liked the look of the new ones vs. the old ones but kinda personal opinion…
    brian2sun[QUOTED][OP] likes this.
  19. Oct 15, 2022 at 1:24 AM
    VaToy
    Parts Unknown
    I see a Nokian Outpost AT in 255/75/17 comes in a SL rating at 41 pounds with tuff sidewalls, a killer warranty and not too expensive. I'm wishing for a SL in some Toyos 255s or 275s.
  20. Oct 15, 2022 at 8:18 AM
    brian2sun
    California
    Toyo AT3s come in a C rated 255/75R17. C and SL are pretty similar load ratings. I have C rated 285/75R17 Toyo AT3s on my 4runner and they ride about as smooth as the SL Duratracs on my Tacoma. Cs are definitely not harsh if what you’re trying to avoid is Es.
