Never change your differential fluid?!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nazareth7, Jul 16, 2023.
  1. Jul 16, 2023 at 11:50 AM
    Nazareth7
    Nazareth7 [OP] Well-Known Member
    2007 Tacoma 2x4
    Hello community. How do I know when to change my differential fluid? my Tacoma has 187k miles. Do I need to change the fluid or leave as it? And what about my transmission fluid? Thanks y’all, we rock.
    Williston likes this.
  2. Jul 16, 2023 at 11:58 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Yea at 187k id change it if they have never been touched.
    Id jump on that like yesterday.
  3. Jul 16, 2023 at 12:04 PM
    Nazareth7
    2007 Tacoma 2x4
    drain and refill only ?
    also my trans shifts smooth tho. Do I still need to change the fluid thanks . Flush it or drain and refill only ?
  4. Jul 16, 2023 at 12:08 PM
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    Yes im aware there is a difference. I maintain a high mileage vehicle myself. I prefer drain and fills and although its shifting fine thats alot of miles on trans fluid or any fluid for that matter.
    Being proactive with maint. is never a bad thing.
    kidthatsirish likes this.
  5. Jul 16, 2023 at 1:28 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    You can't really "flush" a diff unless you are willing to waste a bunch of fluid. Just drain and fill.
  6. Jul 16, 2023 at 2:08 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    A diff is drain and fill only, not sure how you would “flush” it.
    And change it asap. Toyota says 30k miles.
    Tranny, drain and fill. Do it 3-4x
    One drain and fill once a week for 3 weeks
  7. Jul 16, 2023 at 3:03 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    at 187k miles on original diff fluid.... be prepared for pinion bearings, ring and pinion gears, and carrier bearings needing replacement.
    Too Stroked and wi_taco like this.
  8. Jul 16, 2023 at 3:53 PM
    Nazareth7
    2007 Tacoma 2x4
    Not talking about differential
  9. Jul 16, 2023 at 3:55 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    The maintenance schedule in your owners manual should tell you when to change both.
  10. Jul 16, 2023 at 4:00 PM
    Clearwater Bill
    Billy
    Largo Florida
    Do you have an owners manual?
    You have a 5 lug, right? Meaning you have a trans dipstick. Easiest drain and fill you'll ever see.
    Murd3rd likes this.
  11. Jul 16, 2023 at 4:02 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    All of the Toyota trucks (some with excess of 300K) I have owned first and last diff change at the same time. Checks yes.
  12. Jul 16, 2023 at 6:16 PM
    TacoTuesday1
    FL
  13. Jul 16, 2023 at 8:48 PM
    Nazareth7
    2007 Tacoma 2x4
    Yes it’s 5 lug . But I bought it at 174k miles . So I don’t know if it has been changed it , fluid looks clean tho.
  14. Jul 16, 2023 at 8:48 PM
    Nazareth7
    2007 Tacoma 2x4
    Steves104x4 likes this.
  15. Jul 16, 2023 at 8:51 PM
    Nazareth7
    2007 Tacoma 2x4
    stevesnj[QUOTED] likes this.
  16. Jul 16, 2023 at 10:11 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
  17. Jul 17, 2023 at 7:57 AM
    sbMT
    sbMT Active Member
    Montana
    ‘09 Off-Road Access Cab
    I would do it asap. Get the right fluids from anywhere and new drain and fill plug gaskets from Toyota.
    I just did both differentials, transfer case, and transmission on my ‘09 with 249k miles. Took a couple hours and <$200. Yours will be a lot less with 2 fewer boxes to worry about.
    I do my rear diff more often than most due to mostly hard miles (not a daily driver) with water crossings and raft launches.
  18. Jul 17, 2023 at 10:33 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Now there is a real need to drain and refill! Water is not a real good lubricant.
    jackn7 and Williston like this.
  19. Jul 17, 2023 at 11:40 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I changed mine at 170,000 as well as the transfer case. I'm getting close to 240,000 now. I'll probably change it again at around 300,000. The diff's should last a LOOOOONG time as long as you never get in water so deep that you let water get inside. If that ever happens it needs to be changed yesterday. Lots of guys out there with 400,000+ miles that have never touched the diff fluid.
    Transmissions are different. They have an expected lifespan of 400,000 to 500,000 miles if driven carefully. If you let them get too hot, or find other ways to abuse it the transmission may die sooner. And sometimes you just get unlucky and get one that dies sooner. But changing the fluid doesn't change anything. It's going to die when it dies regardless. It's cheaper to just drive it till it dies and get it rebuilt.
    Generally speaking changing the transmission fluid is at best a waste of money. Most of the time it neither helps nor hurts. But with that many miles on the transmission with an unknown history it may well be starting to go bad. If so, keeping the old fluid in there will buy you some time. Putting new fluid in a transmission that is compromised will lead to it failing in just a few days. You might not even get it home from the shop. Keep the old fluid in there and you may get a year or more before it completely dies.
    Blockhead likes this.
  20. Jul 17, 2023 at 2:19 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer), Factory/TSB OEM rear leaf spring modification.
    The point about the water crossings and raft launches is a good one: If I had a boat and was backing down the launch ramp on a regular basis, I would change the rear differential oil after the last haul-out every season: Especially if it's salt water you are dealing with. One other thing to add: if you have to back your vehicle more than 1/3rd up the rear wheels to get the boat off of the trailer: find a new ramp: it's not deep enough. (drop-off) The boat should float right off of the trailer. Sometimes it takes a strong push.
    Also, don't rely on/assume that the vent hose connection at the top of the axle is sound/waterproof. Putting the rear-axle housing and/or pumpkin under water is not a good thing.
