Neutral safety switch
Discussion in '1st Gen. Tacomas (1995-2004)' started by vettehigh, Sep 8, 2020.
  1. Sep 8, 2020 at 1:02 PM
    vettehigh
    vettehigh [OP] Tacoma Tank
    Jon
    Upstate, NY
    Believe mine is going on my 95.5
    OEM 84540-30270
    Easy to remove/replace?
  2. Sep 8, 2020 at 1:04 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    mine seems to need lubrication sometimes because its hard going in gear from park, I saturate it with silicon spray and it loosens up, not a long term fix
    GQ7227 likes this.
  3. Sep 8, 2020 at 1:08 PM
    vettehigh
    Jon
    Upstate, NY
    Ordered new OEM for $99 shipped
    BillsSR5[QUOTED] likes this.
  4. Sep 8, 2020 at 1:28 PM
    BillsSR5
    bill
    2014 SR5
    vettehigh[OP] likes this.
  5. Oct 5, 2020 at 11:34 AM
    vettehigh
    Jon
    Upstate, NY
    Had my OEM switch replaced a month ago and everything was perfect until this morning. I went to start and nothing...put in neutral...turned the key...started
    Could I have a faulty OEM switch?
  6. Oct 5, 2020 at 11:54 AM
    BillsSR5
    bill
    2014 SR5
    try hosing it down with Silicone spray, they rust up and wont shift good, I hit mine everytime I feel a stiff clunk going in gear
  7. Oct 5, 2020 at 12:15 PM
    vettehigh
    Jon
    Upstate, NY
    Even if it's new? Only a few weeks old
  8. Oct 5, 2020 at 12:21 PM
    BillsSR5
    bill
    2014 SR5
  9. Nov 17, 2020 at 9:46 AM
    vettehigh
    Jon
    Upstate, NY
    It happened again yesterday. Would not start nor would it today unless I moved to neutral. The dealer is giving me another OEM one free of charge this week. If this happens again with the second new one, what the hell could be causing the problem? :mad:
    BillsSR5 likes this.
  10. Nov 17, 2020 at 10:23 AM
    BillsSR5
    bill
    2014 SR5
    I wonder if the plug connection contacts on the truck side have corrosion or are getting moisture in the connection, since your truck is an older model they might need to be cleaned out with some elect. cleaner spray and dielectric grease in there https://shop.advanceautoparts.com/p...VicDICh0ezQNmEAQYASABEgIgyPD_BwE&gclsrc=aw.ds, still sounds like a neutral safety switch issue since it was replaced once and worked good for a time
    vettehigh[QUOTED][OP] likes this.
  11. Nov 17, 2020 at 10:33 AM
    BillsSR5
    bill
    2014 SR5
  12. Nov 17, 2020 at 12:09 PM
    vettehigh
    Jon
    Upstate, NY
  13. Dec 3, 2020 at 4:39 AM
    vettehigh
    Jon
    Upstate, NY
    Cleaned the contacts on the truck side with the above and installed the new OEM switch yesterday. Hopefully all is well from here on out. I wonder if it happens again, then it could be a starter issue?
  14. Dec 3, 2020 at 11:19 AM
    vettehigh
    Jon
    Upstate, NY
    Just started my truck since last night, and again the same issue. Ordering OEM reman starter
  15. Dec 3, 2020 at 11:26 AM
    BillsSR5
    bill
    2014 SR5
    or you could just buy the solenoid contacts and use the old starter, usually its just the copper contacts that wear out on Toyota starters the rest is bulletproof
    Black DOG Lila likes this.
  16. Dec 3, 2020 at 11:29 AM
    BillsSR5
    bill
    2014 SR5
  17. Dec 3, 2020 at 12:07 PM
    vettehigh
    Jon
    Upstate, NY
    My luck has been bad lately, so I got the OEM for $150 shipped. Odd thing is, the only time it does this is the mornings when I first try to start it. Never had an issue after the first start throughout the day the past couple months
  18. Dec 3, 2020 at 12:30 PM
    BillsSR5
    bill
    2014 SR5
    battery and contacts check out? weird situation
  19. Dec 3, 2020 at 12:34 PM
    vettehigh
    Jon
    Upstate, NY
    Interstate battery is fine....ordered the starter, but when the old one is pulled out it will be tested first along with the contacts. Best case, I just ship the starter back
  20. Dec 3, 2020 at 12:37 PM
    BillsSR5
    bill
    2014 SR5
    yeah the starter wouldn't have nothing to do with not starting only in neutral, more of a no start,clicking sound like a low battery, you can hear the noise in that video I put up
