Nerf bars rusting from inside out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hook78, Oct 2, 2018.
  1. Oct 2, 2018 at 6:13 AM
    Hook78
    Hook78 [OP] Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    So after Florence rolled through I had to drive through a couple flooded spots, and some water got inside my Lund nerf bars. I didn't notice until I kept seeing what I thought was dark mud around the plastic step platforms. Kept wiping it up only to find more the next day. Then I pulled off the plastic step molds and found tons of sludge underneath. Wiped all THAT up and still kept finding it. Well there was water just sitting inside the bars, tossing up the sludgy stuff during bumps and stops/gos.
    Finally I pulled the bars off, drilled drain holes in each end, and throughly rinsed them with soap. There was some material inside that kept draining out, at first I thought it was bark particles but that made no sense since when installed there's no way for something that big to get in. I looked more closely and it appears to be bits of metal sloughing off the inside of the bars as they rust. So this is not muddy sludge but rusty sludge (which has left awesome stains on my driveway).
    Silly me, I thought I recalled buying aluminum nerf bars and when I went back to look at the product info, they are steel.
    I'm afraid that after enough time goes buy, these will rust from the inside out and I'll step on the bar, and it'll disintegrate. Not to mention having drilled holes that are now perfect entrance ways for more rust.
    One of the step's attachment points broke during removal so I'm seeking replacement under warranty, but wondering what you all think. Is this a tragedy waiting to happen, and should I just toss these, consider it a lesson learned, and buy new ones if they aren't replaced under warranty? Or are they likely to hold up better than I think? They're only ten months old.
  2. Oct 2, 2018 at 6:18 AM
    Dan 77
    Dan 77 I leave my bikes outside
    Dan
    San Antonio
    06 DCSB TRD Sport 4X4
    Kings and TC UCAS 01 DCSB 4X4 Totaled All-Pro bumper, mile marker winch
    Thinking about the cheapest solution maybe after they are cleaned up from the inside spray some frame saver or some other rust proofing paint in it.
  3. Oct 2, 2018 at 6:24 AM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    Do they have any warranty?
  4. Oct 2, 2018 at 6:25 AM
    96carboard
    96carboard Well-Known Member
    Having drain holes will generally be better than having water stuck inside them, but seems to me to be a very poor quality product you got there.
  5. Oct 2, 2018 at 6:30 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Yeah they're under warranty, currently trying that.
    Blais03[QUOTED] likes this.
  6. Oct 2, 2018 at 6:30 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    I'm actually not surprised. My own fault for partially submerging them, and some of the water may have been briny. Considering it's been sitting in there for a couple weeks now the rust is about what I'd expect for steel.
  7. Oct 2, 2018 at 6:36 AM
    96carboard
    If water can get in the way you seem to think you got it in, then rain water can also get in, as can salted winter road sludge if you drive in wintery places.
  8. Oct 2, 2018 at 7:18 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    whatstcp[QUOTED] likes this.
  9. Oct 2, 2018 at 8:03 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I would make sure they don’t corrode onto the frame and just keep them until they rust.
    Pretty much all thise tube type steps will rust out at some point. Its just the way it goes.
  10. Oct 2, 2018 at 8:06 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Yeah, that's what I was worried about too. I was thinking I'd remove them as soon as the brackets holding them on started to accumulate rust. But the good news is that RealTruck.com is sending me brand new ones. I asked for warranty replacement based on part of the plastic trim on the step breaking, and they're replacing based on that and the rust they saw in the picture. Have to give credit to RealTruck.com and Lund for covering that. Turnaround in ordering the warranty replacement was three hours, impressive.
    PackCon[QUOTED] likes this.
  11. Oct 6, 2018 at 8:28 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    So how about RealTruck.com approving warranty replacement on Tuesday, with the new bars arriving today. Customer service response and shipping could not have been faster!
  12. Oct 6, 2018 at 8:33 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    I see rusted tube steps all the time. I think it's inevitable. I had a Smittybilt rear tube bumper on my 1991 and that started rusting the first winter. I eventually pulled the plastic caps off and welded the ends and that slowed it down a lot.
  13. Dec 31, 2022 at 5:14 PM
    Bennett2010
    Bennett2010 Active Member
    Ethan
    2015 SR5 prerunner dcsb
    Just took mine off the 2015 I just bought today and one was half full of water. They plastic steps on that one were peeled up a little. I definitely plan on drilling some drain holes in them for future use.
  14. Dec 31, 2022 at 7:10 PM
    SWPA Tacoma
    SWPA Tacoma Well-Known Member
    Stevo
    2006 White Tacoma DCLB
    The stainless steel nerf bars I have had since I bought the truck still look good. I'd like to replace with black powder coated stainless steel but cant find an affordable set. I have yet to see a black nerf bar that isnt showing signs of rust.
  15. Dec 31, 2022 at 7:23 PM
    Bennett2010
    Ethan
    Mine are the stainless steps... No signs of anything but wanted to take them off because at stock height I really don't need them. But when I took them off one was at least half full of water. Didn't pour out rusty colored ‍♂️ but might make sure yours aren't holding water
  16. Jan 1, 2023 at 7:52 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    I had Lund steel tube steps on my 08 many years ago. They rusted from the inside out after about 3 years and were never submerged like yours were. I guess it was from water seeping in around the edges of the plastic parts. I was out of the warranty period, so Lund was no help.
    I took them off, cleaned them up, removed as much rust as I could access, and painted them with black bed coating in spray cans. It extended the life of them for another 2 years but they ultimately just rusted away from the inside.
    I went without side steps for a few years and I now have N-Fab Nerf Steps. They're a lot more expensise but also come with a much better warranty.
  17. Jan 1, 2023 at 8:00 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    I was going to say fluidfilm
