Negative Ground Cable Broken
Discussion in '1st Gen. Tacomas (1995-2004)' started by ghostfart, Apr 3, 2017.
  1. Apr 3, 2017 at 4:51 PM
    ghostfart
    ghostfart [OP] Well-Known Member
    Oakland, CA
    2002 Tacoma XtraCab TRD
    I was replacing my spark plugs this weekend and when I went to hook my battery back up, I realized the ground cable that connects from the negative wire to the frame was completely broke. I'm not sure how long it's been like this. I know the truck started at least once while it was disconnected. I've since "repaired" it by reattaching the wires with electrical tape. Can I anyone let me know what a proper way to fix these wires is?
    I'm assuming that if this becomes totally disconnected again my battery will die, right?
  2. Apr 3, 2017 at 4:52 PM
    ghostfart
    Oakland, CA
    Here's a picture of what it looks like now so you know exactly what wire I'm talking about. [​IMG]
  3. Apr 3, 2017 at 4:54 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Yep, that is a body ground. Your battery will still charge, just not as good.
    Soldering a new length of wire is one of the best ways to fix.
  4. Apr 3, 2017 at 4:55 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Mine was disconnected for weeks before I realized it and I noticed nothing wrong with my truck...I reconnected it and now I just make a point to check on it every so often.
  5. Apr 3, 2017 at 4:59 PM
    Clearwater Bill
    Billy
    Largo Florida
    Solder can make things brittle, or at least reduce flexability in the area of the solder. And flexing is what caused the issue it looks like.
    I'd be looking for a replacement at a wrecking yard, or at least pricing an aftermarket replacement.
    Or depending on exactly how that is assembled, you might only need a new clamp and a length of the correct gauge wire.
    But I'm curious about why unhooking the battery to change spark plugs?
    medic2230 likes this.
  6. Apr 3, 2017 at 5:04 PM
    Hoangde
    Hoangde Well-Known Member
  7. Apr 3, 2017 at 8:39 PM
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    Any accessories that are attached to a body ground rather than back to the negative terminal shouldn't be able to work anymore since there would no longer be a complete circuit. You could always make a custom length cable at a place like West Marine.
  8. Apr 3, 2017 at 8:46 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Same thing happened to me. That body ground cable is really stiff and really short, I just electrical taped it really tight to where it broke off of, I haven't really found a permanent solution yet.
  9. Apr 3, 2017 at 9:12 PM
    computeruser6
    Dirk
    Escondido
  10. Apr 3, 2017 at 9:20 PM
    SunSetPrez
    SunSetPrez Well-Known Member
    Orange County
    Get a piece of 4 gauge wire and crimp on 2 connectors and replace. Or even easier like someone already said just get a new generic one from any auto parts store.
  11. Apr 4, 2017 at 1:15 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I use Marine battery terminals and upgrade all my cables .
    I get short pieces of welding cable that would be thrown out it works really great.
    fla_sun likes this.
  12. Apr 4, 2017 at 1:41 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    As long as the ground on the back of the intake is still hooked to the firewall it still has a body ground.
    DrZ likes this.
  13. Apr 4, 2017 at 12:59 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    What mechanicjon said. The negative terminal is also attached to the engine or transmission, and the engine is grounded to body, so as long as you don't lose both grounds you're good.
  14. Apr 4, 2017 at 1:04 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Plan and simple, easiest fix, right here ^
  15. Apr 4, 2017 at 4:49 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I went ahead and fixed mine using the Lynx battery cable. Pretty easy, the metal is reasonably flexible to conform to any mounting surface. The cable is a lot thicker and higher gauge than the original OEM grounding cable. It was like $6 dollars at Pep Boys. It's a tight squeeze.
    I grounded it behind the fuse box since my HID relay was in the way.
    Xtremsiege2 and jammer like this.
