Needle Bearing - Yes, Replace It (ECGS)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by irritable_vowels, Apr 9, 2021.
  1. Apr 9, 2021 at 9:16 AM
    irritable_vowels
    irritable_vowels [OP] Member
    B-Face
    Bend, OR
    '17 Limited
    JBA UCAs, Dobinson C59-352s, Ironman 4x4 leaf packs, Firestone air bags, Bilstein 5100s Smitty XRC 9.5k winch, front/rear Body Armor bumpers, TRD skid Cali Raised roof rack, Softopper K&N CAI, OVTune with Valley Runner 2.0, Tekonsha brake controller
    Seen back and forth on this issue, including some reputable posters from shops who have stated the needle bearing replacement is not necessary. Your experience may vary, but I wanted to put this up to add to the debate.
    ~3" lift on my 17 Limited with JBA UCAs, Bilstein 5100s, Dobinson C59-352s plus Taco lean spacer on the front. Had the often-described rubbing sound start from the front driver's side. Interestingly, it was rhythmic, but not rapid (was maybe 1 rub a second at 60mph). Read these forums and had enough concern to spring for the ECGS replacement. Popped everything off and here's the stock bearing... speaks for itself.
  2. Apr 9, 2021 at 9:20 AM
    Ubercod
    Ubercod Satellite Pilot
    UK
    2016 White TRD OF
    dang, I was wondering if it was worth the effort when i do suspension in the future.
    irritable_vowels[OP] likes this.
  3. Apr 9, 2021 at 9:23 AM
    irritable_vowels
    B-Face
    Bend, OR
    '17 Limited
    Exactly why I wanted to put it up. Not the most thrilling mod but seems like it's got to be part of the package
    Ngneer, Oatwillie and Ubercod[QUOTED] like this.
  4. Apr 9, 2021 at 9:28 AM
    You Suck I Suck More
    You Suck I Suck More Well-Known Member
    Meatloaf
    North Florida
    2017 Super White DCSB TRD OR
    Your parents' favorite Airman
    The real question is why not do it? It's a relatively cheap upgrade that will do wonders for the longevity of your truck. Just do it
    jpg366, Ngneer, KY_Rob and 11 others like this.
  5. Apr 9, 2021 at 9:33 AM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I did mine the other night. Owned the truck for 4 months and regret not doing it sooner.
  6. Apr 9, 2021 at 9:36 AM
    06trdtaco
    06trdtaco shouldn't be trusted
    Brian
    Cincinnati, OH
    2017 T4R TRD Off Road Premium
    No...the real question is: WHY DOES TOYOTA KEEP USING THIS P.O.S. PART?
    ...sorry about the yelling ;)
  7. Apr 9, 2021 at 9:37 AM
    KVTaco
    KVTaco Well-Known Member
    Thanks for the post and picture. Can someone link the "How To" please?
    Ngneer likes this.
  8. Apr 9, 2021 at 9:44 AM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    I have a stock truck I am fine
    kgilly, maineah, petethemeat and 3 others like this.
  9. Apr 9, 2021 at 9:45 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    Vinyl Trooper, Jruk, KeNnETT and 3 others like this.
  10. Apr 9, 2021 at 9:45 AM
    ryanvar42
    None
    because it doesn't typically fail on stock trucks and they don't make the truck so people can modify it
  11. Apr 9, 2021 at 9:49 AM
    Mad German
    Mad German Well-Known Member
    2016 TRD Off Road
    Because Toyota is cheap. And they know they'll sell every single Tacoma they make, regardless of the shortcomings it has. Tacoma fans are some of the most loyal and will buy damn near anything Toyota sells as a Tacoma.
  12. Apr 9, 2021 at 9:49 AM
    Meatloaf
    North Florida
    YOU'RE RIGHT! I AGREE! THIS TRULY IS THE QUESTION THAT NEEDS TO BE ANSWERED!
    06trdtaco[QUOTED] likes this.
  13. Apr 9, 2021 at 9:54 AM
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    Should I replace my bearing if I don't have a lift and I'm pretty easy on my truck? If so, when should I plan on replacing my bearing? Will there be any collateral damage if I wait until it starts making noise? I'm at 13K now.
  14. Apr 9, 2021 at 9:56 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    You sure you didn't break that upon removal? Looks like you didn't shave down the removal tool and forced it into position.
  15. Apr 9, 2021 at 9:57 AM
    scflyntaco
    scflyntaco Well-Known Member
    brandon
    09 tacoma sport
    lift, supercharger, trd exhaust
    Does anyone have the removal tool I can borrow?
  16. Apr 9, 2021 at 9:59 AM
    amansker
    amansker Ramen!
    Andy
    San Diego, CA
    2010 AC 4x4 6cyl Auto TRD Sport
    I see ECGS also offers an axle seal to go with the bushing. Should I buy one of those too?
    tacotoe, 4×4×4 and Superdave1.0 like this.
  17. Apr 9, 2021 at 10:00 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    might as well, its cheap, and better to have it and not need it.....you know the rest......
    Jruk, Gen3TacomaOBX, jsinnard and 3 others like this.
  18. Apr 9, 2021 at 10:05 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    johnnytwotimes and Jruk like this.
  19. Apr 9, 2021 at 10:23 AM
    06trdtaco
    Brian
    Cincinnati, OH
    Failed on my '17 T4R before it was lifted.
    Did not fail on my '06 or '14 Tacoma. Neither of those were ever lifted.
    So based on my independent research the needle bearing fails 1/3 of the time...whether lifted or not :eek::D;)
    LeakyAC, MyWyfsRnnr, Auzea and 3 others like this.
  20. Apr 9, 2021 at 10:31 AM
    JTFisherman
    JTFisherman Well-Known Member
    Jake
    Texas / Missouri
    4Runner
    Mint
    gabbo2112 and 06trdtaco like this.
