Needle bearing labor
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bassassasin1, Dec 24, 2022.
  1. Dec 24, 2022 at 12:23 PM
    Bassassasin1
    Bassassasin1 [OP] Active Member
    2016 TRD Off-road
    How much should I pay to have my bearing replaced?
  2. Dec 24, 2022 at 12:26 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    1.5hr max, with a lot of profit there. That said with the ECGS tools, it is only 3 fasteners and some hammer work once the wheel is off. Way easier than it seems.
  3. Dec 24, 2022 at 1:37 PM
    Bassassasin1
    2016 TRD Off-road
    Thanks. I ordered the bushing and seal. A local mechanic told me $4-500 labor, ‍♂️
  4. Dec 24, 2022 at 1:45 PM
    runandgun18
    runandgun18 Well-Known Member
    Nate
    Arizona
    20 MGM SR 4X4
    That's steep. Don't feel comfortable doing it yourself? Would save you a good chunk of change for not an overly complicated task. You can borrow the two specific tools needed, there's a thread on here where people share the tools needed for removal and install. After that you just need a torque wrench that will get you to 173ft/lbs. Everything else is straightforward and easy
  5. Dec 24, 2022 at 1:55 PM
    Andrew.arw
    Andrew.arw Chief Beer Officer
    South Carolina
    2018 Toyota Tacoma TRD OR 3.5 V6
    *** Current Setup - 2/27/24 *** - Wheels // Method 316, 17” - Tires // 275/70/R17 // Falken WildPeak A/T4W - Suspension // 2.5” lift // Eibach’s Pro lift, Stage One - front & rear // Eibach Pro Springs // Icon AAL // TC UCA’s - Lights // Rigid Industries Dual Pod’s [Grille] // Rigid Industries Dual Pod’s [Rear Bumper] // Rigid Industries 40” LED Bar [Roof Rack] // XenonPro Hi/Lo Beam // LASFIT Switchback Fogs - Auxiliary // Switch-Pro controller, SP-9100 Series - Audio // Rockford Fosgate R500X1D Amplifier // Dual Rockford Fosgate P1 10" Subs - Accessories // TRD Pro Grille // Prinsu Roof Rack // Rough Country Soft Tri-Fold Tonneau - Armor // Body Armor Rear Bumper, 4x4 Desert series // TRD Pro Skid Plate - Misc Mods // ECGS Bushing // Cali Raised AC Drip relocate // CMC
    DIY? An hour.
    If you do have a shop do it, some will not be familiar with what’s involved. It’s dead simple, but I’ve heard a few stories from folks that came to me and were given the run around, and 3+ hrs labor.
    I’d say 1.5 hr max. Stand-alone job, part included, shouldn’t exceed 300$. Just my honest opinion.
  6. Dec 24, 2022 at 1:57 PM
    Bishop84
    Bishop84 Well-Known Member
    Warranty time is 2.0, so don't expect many shops to go below 1.5 unless they are freeballing it.
  7. Dec 24, 2022 at 1:58 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Shop price to remove/install the - CV & axle seal + .5hr more for the bushing sounds fair.
    Mark77 and Andrew.arw like this.
  8. Dec 24, 2022 at 2:11 PM
    Bassassasin1
    2016 TRD Off-road
    Thanks for all the info. I probably could do it. I just did my lift myself.
    AmateurTaco1313 likes this.
  9. Dec 24, 2022 at 2:13 PM
    runandgun18
    Nate
    Arizona
    20 MGM SR 4X4
    Yeah, you'll be fine. Recommend doing a new axle seal while you're in there and make sure you have diff fluid to replace what leaks out during install.
    Andrew.arw likes this.
  10. Dec 24, 2022 at 2:16 PM
    TnShooter
    Deogee
    STOCK
    It isn’t too terribly difficult.
    I can not stand to work in confined spaces.
    So I opt to pull the cv out completely.
    I also disconnect the tie rod from the knuckle and spin the knuckle out of the way for more room.
    You can probably get by with leaving the cv in the hub and just undoing the ball joint mount bolts.
    But I’m not about speed. I’m not paid by book hours. I’m not not paid at all:rofl:
    Bivouac likes this.
  11. Dec 24, 2022 at 2:18 PM
    mabupa
    mabupa Well-Known Member
    Miguel
    2021 trd off-road 6 speed manual
    I would Not pay that much for that job. I did mine the week after I installed my eibach suspension and didn’t take me 2hrs. I borrowed the removal tool from a forum member. Like others mentioned, it’s a DIY job and there are several good YouTube videos you can watch prior to doing the job.
  12. Dec 24, 2022 at 2:24 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Since Labor rates vary so much in different areas .
    Very hard call to make . Some areas that $500.00 would be a fair price .
    It comes down to what your willing to pay .
    TnShooter likes this.
  13. Dec 24, 2022 at 2:42 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    a few guys rent the puller tool for the bearing and a generic set of bearing race / seal driver set is necessary. pitman arm puller / i needed also. (for me personally) i had bought one but it was lost in my shop. I spent half an hour trying to get that off and then another half looking for the tool to make it a 10 second task
    Monster0Frankenstein likes this.
  14. Dec 24, 2022 at 2:55 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome.
    LoL! That's robbery. Takes more than an hour for a homegamer.
  15. Dec 24, 2022 at 2:58 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If you did the lift, then the bushing is no problem.
  16. Dec 24, 2022 at 3:18 PM
    Bassassasin1
    2016 TRD Off-road
    Thanks guys. Also, how long can I drive with the vibration before it becomes a big issue? I drive the truck 30 miles a day or so back and forth to work.
  17. Dec 24, 2022 at 3:18 PM
    auskip07
    Skip
    Atlanta, Ga
    i did mine before installing the lift. i wanted to avoid the "how long can i do this" approach
  18. Dec 24, 2022 at 3:23 PM
    runandgun18
    Nate
    Arizona
    20 MGM SR 4X4
    Yep, I'll be doing it all in one swoop.
    auskip07[QUOTED] likes this.
  19. Dec 24, 2022 at 3:27 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    I’ve got 25k miles on my current suspension lift set up with no noticeable vibrations. I drive 80-100 miles a day for work btw
  20. Dec 24, 2022 at 3:32 PM
    auskip07
    Skip
    Atlanta, Ga
    also, its 50% if you will develop the issue from what people say.
