Need to Seal Open/Unused Fog Light Connectors?
Discussion in 'Lighting' started by JERBEAR69, Aug 5, 2022.
  1. Aug 5, 2022 at 12:07 PM
    JERBEAR69
    JERBEAR69 [OP] Member
    I've purchased BajaDesigns Squadrons to use as fog light and for now I'm going to connect the lights up to the truck's existing fog light wiring. Once I have a couple other parts of the build figured out I'm going to switch to the BajaDesigns wiring harness which will leave the truck's fog light connection open. I live in SoCal so water isn't something we see often but it does rain occasionally and when off-roading I expect to run across at least a few water crossings here and there. Does the truck connector need to be sealed up somehow and if so what's the best way to do that? Just tape it up with electrical tape or duct tape or....?
  2. Aug 5, 2022 at 12:11 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
  3. Aug 5, 2022 at 1:05 PM
    JERBEAR69
    Perfect - as it turns out I think those are already in the box with the lights in case I wanted to do my own wiring harness, just need to get some dielectric grease. Thanks!
    Cipher94 likes this.
  4. Aug 5, 2022 at 1:06 PM
    Cipher94
    Cipher94 Well-Known Member
    Madison, WI
    2016 TRD OR
    Yes! I have the same thing with the plugs for the parking sensors and blind spot monitoring system... I've bagged andd ziptied them but occasionally road salt wiggles in and triggers the Blindspot mirrors in the winter..
  5. Aug 10, 2022 at 3:43 PM
    caribe makaira
    Caribbean, Puerto Rico
    Metri-Pack Cavity Plug in place of wire terminal.
