Need to remove passenger airbag cover before removing dash?
Discussion in '1st Gen. Tacomas (1995-2004)' started by crackedmirror, Jun 12, 2021.
  1. Jun 12, 2021 at 2:58 PM
    crackedmirror
    crackedmirror [OP] Well-Known Member
    trying to pull on dash but it seems stuck in the pax airbag area. cannot figure out which bolts/screws are holding the airbag cover in place.
  2. Jun 12, 2021 at 3:24 PM
    Jeremy Martin
    Jeremy Martin Well-Known Member
    1st Gen Taco
    I have attatched the instructions from Alldata, hope this helps.
    Mr Yoda and Black DOG Lila like this.
  3. Jun 12, 2021 at 5:36 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Are you talking about the passenger airbag switch (in the black, center section) of the dash above the climate controls or about the actual passenger airbag?
    If the former, then @Jeremy Martin's attachment outlines the general process. Here's a write-up with photos that demonstrates the entire process as well:
    Removing the Dash Trim
    If you're having trouble with the actual airbag, here's the procedure on that:
    If something else, please include a photo of the trouble area.
    Mr Yoda and SLAPS 65 like this.
  4. Jun 13, 2021 at 1:21 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    don't forget, if your messing around with a live airbag, disconnect the battery and wait 30 minutes before messing with it.
