Need Suggestions for Good 2-3" AAL with Good Padding So No Sqeaking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jboudreaux1965, Apr 7, 2025.
  1. Apr 7, 2025 at 7:33 PM
    jboudreaux1965
    jboudreaux1965 [OP] Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    I needs at least a solid 2" AAL for the back. I tried a Deaver on my 2nd gen and sqeaked like crazy. Anyone for some that will give 2" lift that won't start sqeaking?
  2. Apr 7, 2025 at 11:05 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Both of my Deavers on my 2017 don’t squeak. I left the overload leafs in and have about 2” on the rear.
    Talk with Marie about it at @HeadStrong Off-Road
  3. Apr 8, 2025 at 6:25 AM
    evenslower
    evenslower Well-Known Member
    Totally agree with HS recommendation and I’d also suggest adding leaf liners while you’re in the process.
    HS add a leaf, 1/2 inch spacer, liners, removed overload, trail-gear ubolt flip with Fox 2.5s. perfectly quiet and right at 2” of lift over stock
  4. Apr 8, 2025 at 6:39 AM
    mootiger49
    mootiger49 It’s mine, not yours!
    23’ Lunar Rock OFF ROAD. 24’ Underground 4-Runner. 2000 IJM OFF ROAD
    V2 grille OTT Tune 5100’s Pro rims
    We did the icon
    Left the overload in
    No noise
    2” lifted
  5. Apr 8, 2025 at 7:38 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    It's rare but squeaking does occasionally happen with my 5 year old Headstrong 3 leaf AAL. It was completely silent for the first couple years (~25k miles) now is >95% silent. Unsure what the rare/occasionally squeak is from.. dirt/debris or sitting for a week. <shrug>
    I'm happy with them for the support/ride/price. I'd like a full leaf pack replacement but haven't opened the wallet wide enough.
  6. Apr 8, 2025 at 11:00 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    which liners do you use?
  7. Apr 8, 2025 at 12:12 PM
    evenslower
    https://a.co/d/7KpgiPX
    Only used liner on add a leafs and spacer, left original leaf pack alone. Was more than enough to do bioth sides.
  8. Apr 8, 2025 at 3:32 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Are they rubber? How long have they lasted? Did you get 2.25" or 2.5"?
  9. Apr 8, 2025 at 4:09 PM
    evenslower
    2.25 and I’d say they’re a really flexible plastic. Totally guessing on mileage since installed based on tire rotation intervals but 6-7k. Maybe a little more, not sure.
  10. Apr 18, 2025 at 3:24 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    I ennded up building a franken-pack or lead-enstein from stuff i had around my shop. End result was about 3-4" of lift and actually performs and rides really well! I'm only playing with these to determine the height pack i neef but if your on a budget I can say I would actually recommend the combo.
    I had a new set of 2nd gen recall leafs and a new set of 3rd gen TRD Sport leafs. The overload leaf on the 2ng gen recall pack is longer and thicker than the 3rg gen packs. And i had a cheap Torch AAL (https://www.amazon.com/gp/aw/d/B082VKNYL5) laying around.
    I took apart the 3rd gen pack, made sure to keep the aluminum spacer pad in place, the added the Torch AAL, placing a 1/4" Energy suspention pad and the OEM aluminum pad between the lowest leaf on the 3rd gen set and the Torch AAL, then placed the 2nd gen over loaf spring with the aluminum pad under the AAL, then placed the OEM 3rd gen overlaod leaf with OEM aluminum pad under the OEM 2nd gen overload leaf.
    It was a hell of a time with clamps squeezing the pack together but sime out pretty dang good.
    I also added 1/4" Energy suspension pads to the edges of the AAL to prevent future squeeking.
    With the block and the franken-leaf pack i have abour 29 5/8" from center of hub to fender. If i had a 4" lift in the front i would for sure keep running the pack!
    TheWildMan likes this.
  11. Apr 18, 2025 at 3:29 PM
    Gen3TacomaOBX
    S
    You don't mention anything about the (what appears to be) 3" block in the rear.
  12. Apr 18, 2025 at 3:31 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    I did, i mentioned the measurements with the block. The whole reason for the thread is i am trying to determine what size pack i need to match the front lift. The block is 4.5"
    The block doesn't effect the flex or ride quality. The post was just to give people on a budget a good option for a 3-4" lift pack :)
    Gen3TacomaOBX likes this.
  13. Apr 18, 2025 at 3:33 PM
    Gen3TacomaOBX
    S
    Ok. I see that now. That's a lot of lift for the current tires.. I assume you're planning on going up to 35s?
  14. Apr 18, 2025 at 3:37 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    I have a set of 36's for it once lift iis settled. Thats what it will look like. I have 29" center of hub to fender in front
    16" brake lines up front, 22" brake lines in the rear snd extended ABS lines 14"'s
  15. Apr 25, 2025 at 12:02 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Right now, with the block and the Franken-pack I'm estimating I am getting about 8" of lift. The back sits a little higher than the front. I think I am going to go with a 7" pack. The front measure right under 47" fender to the ground, once I get Castor set I'll take a final measurement to the ground and hub.
    All in all, if you have 2 good sets of OEM leaf packs laying around, especially a set of the 2nd gen recall packs laying around and just want a solid 3"-4" leaf pack for a low cost, the Franken-Pack is a good option. I'd run it if I only had a 3 or 4 inch lift. rides good and flexes well.
  16. Apr 25, 2025 at 12:14 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Franken-Pack details...
  17. Apr 25, 2025 at 1:55 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
  18. Apr 25, 2025 at 2:06 PM
    dgilbert2006
    dgilbert2006 Well-Known Member
    Dan
    Northglenn, Colorado
    2015 Tacoma 4x4 SR5 DCSB
    5100s, Dakars, D2S Retro, Level 8 MK6 285
    Is this one of those Friday deals? How the hell?
    71tattooguy and Tocamo like this.
  19. Apr 25, 2025 at 9:16 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    no, LOL!
    I put new coilovers in the front a few weeks ago. I have been making adjustments until I figured out how much lift I was going to go with in the front. I am not going to order my Alcan's until I know what specs I need. So I kept adjusting the front and everytime I adjusted the front I would either add a different size block or leaf in the back to even it out. Once I got to 4.5"-5" blocks in the back I did not want to try any blocks taller than that. So I started messing with the leaf packs. I started the thread originally because I was looking to take the easy route and order a 3" AAL setup to stack on top of the blocks to keep making adjustments with the height.
    Then I decided instead of spending money on an AAL setup just to use until I can order my Alcan's I started looking around my shop to see what I had to just put a leaf pack together.
    I had a new set of 2023 new OEM TRD Sport leafs and a set of new 2nd gen recall leafs in the shop. And I dug up the cheap set up Torch AAL's. So I started playing with those originally just to find the height I needed and came up with the Franken-Pack. Which turned out to be a pretty durn good setup if all you need is 3-4 inches of lift. So i decided to share my findings.
    LOL, I have an extra Deaver leaf from a lift pack and the rest of the OEM leafs from the 2 OEM leaf packs. So once I place my order for my new Alcan's I plan on putting that Deaver leaf in the Fraken-Packs and add a couple more of the extra OEM leafs to see what I end up with, just to experiment :)
    So to wrap it up, in the pics I have the 4.5" blocks and the Franken-Pack leafs on top of the blocks. Which gave me around 8 inches total lift or so. Again for the sole purpose of finding out how much lift I needed for my new custom made leaf packs. BUT while doing my experimenting I discovered a way for guys on a budget to build a pretty durn good 3-4 inch leaf pack using spare or easy to get parts for cheap.
    Isn't that sort of the spirit of TacomaWorld to share stuff you discover when experimenting :)
