Need OEM Fog Light Switch Wiring Diagram
Discussion in 'Lighting' started by TerryS, May 11, 2011.
  1. May 11, 2011 at 2:19 PM
    TerryS
    TerryS [OP] Well-Known Member
    Terry
    Cape Cod, Mass.
    '24 Celestial Silver DCLB SR5
    OEM cast aluminum running boards & tonneau cover.
    I'm seriously considering swapping the OEM fog light switch for the FJ counterpart. I have the wiring diagram for the FJ switch, but not for the Tacoma switch. Life would be easier if I could find it. I have seen others use the FJ switch for new/add-on lights, but has anyone done a straight switch swap?
  2. May 11, 2011 at 2:48 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Interested
  3. May 11, 2011 at 5:35 PM
    TerryS
    Terry
    Cape Cod, Mass.
    Thanks for your reply. My problem is determining what locations the connecter pins from the Tacoma switch go to on the FJ switch. That's why I was asking for the switch wiring diagram.
    I'm not sure which of the 2 FJ switches I'll need. Maybe you or someone else can clarify.
  4. May 11, 2011 at 6:27 PM
    Tacokevin
    Tacokevin Well-Known Member
    Kevin
    East Hartford, CT
    Kenwood Excelon DNX9960, Hertz speakers, Extang Trifecta Tonneau, 3" Toytec Bilstien 5100 coilovers, LR UCA, Diff Drop, Rear AAL Bilstien 5100's, XD Series Bully Wheels, 285/74R16 Nitto Terra Grapplers, Yellow fog lights w/ anytime mod to FJ oem switch, DTRL custom mod w/Switchback LED and stealth switch, Smoked Headlights, Wired Streamlight Rechargable LED flashlight, Color matched grill, Color matched power mirrors w/oem switch, Heated Murth Bicolor signal mirrors w/Highlander oem heater switch, URD short shifter
    THE BOTTOM TWO PINS ARE THE SWITCH ILLUMINATION (GREEN AND GREEN WHITE) TERMINAL 3 (BLUE WIRE) TO FOG LAMP RELAY COIL 4 (WHITE-BLACK WIRE) FROM JUNCTION CONNECTOR GROUND GIVE ME A FEW MINUTES ILL TRY AND UPLOAD A DIAGRAM FOR YOU
  5. May 11, 2011 at 6:32 PM
    Tacokevin
    Kevin
    East Hartford, CT
    here is the diagram
  6. May 11, 2011 at 6:38 PM
    Tacokevin
    Kevin
    East Hartford, CT
    the the FJ switch have an indicator light?
  7. May 11, 2011 at 6:38 PM
    TerryS
    Terry
    Cape Cod, Mass.
    That's kind of you, Kevin. I can't really understand it too well, but thank you.
  8. May 11, 2011 at 6:43 PM
    TerryS
    Terry
    Cape Cod, Mass.
    Yes, the FJ fog light switch has an indicator light, looks like all our other switches and fits the holes in the dash. Why Toyota didn't use it in the Tacoma is a mystery.
  9. May 11, 2011 at 6:48 PM
    Tacokevin
    Kevin
    East Hartford, CT
    its connector f16 on the second page.......on the first page see where it says F16 Fog Lamp SW 3 and 4 those are the wires for pin three and four on te stock switch
  10. May 11, 2011 at 6:53 PM
    Tacokevin
    Kevin
    East Hartford, CT
    circled the wires and the connector
  11. May 11, 2011 at 6:55 PM
    TerryS
    Terry
    Cape Cod, Mass.
    Thanks, Kevin. I do see that now.
  12. May 11, 2011 at 6:57 PM
    Tacokevin
    Kevin
    East Hartford, CT
    what year fj cruiser did switches come from?
  13. May 11, 2011 at 7:05 PM
    TerryS
    Terry
    Cape Cod, Mass.
    I really don't know; I've got the part numbers for the fj fog light switch and the similar fj auxiliary light switch. I don't know which to use yet, but am beginning to think that it doesn't matter.
  14. May 11, 2011 at 7:10 PM
    Tacokevin
    Kevin
    East Hartford, CT
  15. May 11, 2011 at 7:21 PM
    Tacokevin
    Kevin
    East Hartford, CT
    i didnt know that these were available....thanks.....im going to get the aux one for my fogs and the light bar one for my DTRL mod i did
  16. May 11, 2011 at 7:21 PM
    TerryS
    Terry
    Cape Cod, Mass.
  17. May 11, 2011 at 7:35 PM
    Tacokevin
    Kevin
    East Hartford, CT
    from what i see here is this diagram either switch they are wired the same....the bottom 1 and 2 are the illumination of the switch when interior lights in truck go on.... 1 would goto green wire 2 to the green-white wire......3 goes to blue wire (to relay) 4 goes to white-black wire (ground).....only difference is that you have to ground terminal 6....terminals 5+6 on the fj switches are to illuminate the indicator light
  18. May 11, 2011 at 7:40 PM
    TerryS
    Terry
    Cape Cod, Mass.
    Excellent, Kevin. Just what I was asking for. Thanks. I'm going to order the switch and harness tomorrow. I've had enough for one day.
  19. May 11, 2011 at 7:43 PM
    Tacokevin
    Kevin
    East Hartford, CT
    i just ordered them....thanks for bringing them up....let me know how it works out
  20. May 11, 2011 at 7:48 PM
    TerryS
    Terry
    Cape Cod, Mass.
    You too.
