Need muffler , Oem or aftermarket?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by igno1tus, Feb 8, 2021.
  1. Feb 8, 2021 at 4:55 PM
    igno1tus
    igno1tus [OP] Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    So I got a hole in my muffler and I need a new one . Should I get OEM from the steelership or aftermarket ? If aftermarket anyone have a good suggestion ?
    Thanks !
  2. Feb 8, 2021 at 5:06 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    If you're wanting a direct replacement, I would do OEM or a true stainless steel replacement. I did one of those $120 Walker Quiet Flo "Aluminized" muffler/tailpipe assemblies. It didn't even last a year. I bought a new OEM assembly and installed myself.
    Plain Jane Taco likes this.
  3. Feb 8, 2021 at 5:14 PM
    igno1tus
    The one that’s on there now is stock Oem , the hole is progressively getting worse. I don’t know if that will make the truck run like crap ? I just thought about replacing it with Oem . I mean if someone knows something special and there is a good aftermarket one I’m open to that too
    was it hard to change ?
  4. Feb 8, 2021 at 5:17 PM
    Sig45
    Mark
    Maine
    You can't buy (at least not that I'm aware of) just the OEM Muffler. It's the entire assembly right up to behind the Cat.
    A custom muffler shop could probably install a stainless muffler. I considered that, but it was nearly as much as the entire OEM assembly.
  5. Feb 8, 2021 at 5:22 PM
    igno1tus
    Yea I see it looks like the entire pipe, a SS one would probably be a pretty penny I bet
  6. Feb 8, 2021 at 5:39 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    You could do a TRD exhaust.
    I'd give you my stock exhaust setup (since I still have it), but shipping to you would be more than it's worth multiple times over.
    igno1tus[OP] likes this.
  7. Feb 8, 2021 at 5:50 PM
    Sig45
    Mark
    Maine
    igno1tus[QUOTED][OP] likes this.
  8. Feb 8, 2021 at 5:51 PM
    igno1tus
    Hmm I’m going to check that out ! Good idea ! A stock one looks like it’s $437 + tax
  9. Feb 8, 2021 at 5:53 PM
    igno1tus
  10. Feb 8, 2021 at 5:54 PM
    Sig45
    Mark
    Maine
    Yup.
  11. Feb 8, 2021 at 5:58 PM
    Sig45
    Mark
    Maine
    There was a gasket in there too.
  12. Feb 8, 2021 at 6:01 PM
    igno1tus
    Now if it werent 20 degrees outside lol
  13. Feb 9, 2021 at 1:43 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    I would go trd im saving up for it
    igno1tus[OP] and Island Cruiser like this.
  14. Feb 9, 2021 at 2:29 AM
    GOLIVER0131
    GOLIVER0131 TrdMo
    Socal
    '17 Wht Trd OR DCLB(TrdMo)
    TrdPro grille, blackout badges. Pretty much stock.
    A full cat back install is totally doable by urself, I upgraded to the trd exhaust a few weeks ago and took me an hour, took my time. Wd40 on the exhaust hangers and using channel locks to nudge them out works wonders. That tip was from someone's post here on tacomaworld. If your budget for this isn't at the $500+ level for full ss you can always do a cut and weld performance muffler. The exhaust note is noticeably louder. Cost is about $150 for the ss muffler and install is about $50-$75 at a muffler shop.
  15. Feb 9, 2021 at 6:07 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    I just did this myself and went with the OEM muffler which comes all in one piece with mid and tail pipes. It is a bit more $$ that the aftermarket crap but a perfect fit and made of good materials. The TRD cat back and presumably other might be just a little easier to install since the pipes are separate and get clamped. But I like the clamp less OEM muffler. Quiet and bulletproof. A few things to consider... Just cut the pipes off the old one... makes it a lot easier to remove. If using a new OEM muffler you'll need to have the truck up at least on jack stands to have clearance to wiggle it in. And you will probably have to cut the bolts that hold the front of the mid pipe to the rest of the exhaust up front... and get the specific new hardware kit (shoulder bolts and springs) for that. Oh, and make sure the new shoulder bolt and spring kit you get has nuts since the OEM welded on ones will be gone. Mine just disintegrated from the rust.
    yotaTom and vtown like this.
  16. Feb 9, 2021 at 6:13 AM
    Boco10
    Boco10 Well-Known Member
    ADK
    My old Taco I went with a Walker quiet flo that had a lifetime warranty. Super cheap and lasted longer then expected. After a few years they replaced it for me at no charge.
  17. Feb 9, 2021 at 6:17 AM
    Raylo
    MD, USA
  18. Feb 9, 2021 at 10:43 AM
    RHHousehold
    RHHousehold Well-Known Member
    CA
    2008 Access Cab TRD Offroad 4x4 V6
  19. Feb 9, 2021 at 10:47 AM
    igno1tus
    So does the trd exhaust actually offer any performance ? Or is it just sound
  20. Feb 9, 2021 at 10:51 AM
    Raylo
    MD, USA
    Sound only... I suspect if you like the sound of your muffler with the hole in it, which in my case wasn't too terrible, you'd be happy with the TRD. But I like the stock quiet. It does have a nice chrome tip that looks a little better than the stock pipe.
    vtown likes this.
