Need more info on x-brace
Discussion in '2nd Gen. Tacomas (2005-2015)' started by amati5, Nov 19, 2009.
  1. Nov 19, 2009 at 2:42 PM
    amati5
    amati5 [OP] Well-Known Member
    2010 Prerunner TRD
    I did the search but didn't find enough info on this subject, including google. Doesn't seem like a popular upgrade.
    My questions are:
    1.Is it an upgradable item for a prerunner. Straight installation or need mods?
    2. How much and if there is a after-market version, who sells it.
    3. Is the result worth the $/mods?
    Thanks
  2. Nov 19, 2009 at 2:46 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
  3. Nov 19, 2009 at 2:56 PM
    calicoupe
    calicoupe Well-Known Member
    good looking out Viet! ur truk is duma approved!
  4. Nov 19, 2009 at 3:11 PM
    amati5
    2010 Prerunner TRD
  5. Nov 19, 2009 at 3:48 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    duma? :confused:
  6. Aug 22, 2015 at 10:08 PM
    urban
    urban Well-Known Member
    Illinois/Michigan
    12 DCLB sport OME lift
    305/65r17's on 17x9.5 Rotiforms Cab mount chop 4.10 gears Detroit true track OME 885's Dakars Camburg UCA's Undercover SE Weathertech liners and visors Black headlight mod Debadged Rock Blokz mudflapps (oversized)
  7. Aug 22, 2015 at 10:24 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  8. Aug 22, 2015 at 10:34 PM
    urban
    Illinois/Michigan
    They keep referring to both a front and rear brace on the X-runner. The rear one is quite obvious. I've not heard of the front one until reading that page. I'm apt to not believe until I see it.
  9. Aug 22, 2015 at 10:41 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    https://en.wikipedia.org/wiki/Toyota_Tacoma
  10. Aug 22, 2015 at 10:47 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    tinker_troy likes this.
  11. Aug 22, 2015 at 10:49 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    im out
  12. Aug 23, 2015 at 8:40 AM
    urban
    Illinois/Michigan
    Your gonna try and put them on your truck? Post pictures!!!!! speaking of X runner parts onto non x runner trucks, anyone put just the x runner bumper on? preferably I'd like to see in on a 12+ but I would be curious to see it at all. The 12+'s look like they have different flairs that wouldn't really line up though.
  13. Aug 23, 2015 at 8:43 AM
    urban
    Illinois/Michigan
    Oh, Oh, Any chance we could get some pictures of the other X-runner braces up here!?
    ...It would please me.
  14. Aug 23, 2015 at 8:49 AM
    urban
    Illinois/Michigan
    Braces? or Bumper?
    I'm actually curious about the braces, I'm just half interested to see what a the bumper would look like.
    Ask in a photo shop thread?
  15. Aug 23, 2015 at 3:23 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Iirc the splitters are a separate part from the bumpers.... Onxru I swear someone busted one and needed a new one and a part# was listed for it by some DB nmed wolfpack_5150
  16. Aug 25, 2015 at 11:46 AM
    tgear.shead
    tgear.shead Well-Known Member
    1) I'm pretty sure it would just bolt right up. If you look at the rear mounts for the leaf springs, there is a hole there at the bottom of the mount. That is the mount point for the brace. The other mount points are up in the receiver hitch region.
    2) Not sure it would be worth buying a pre-made one and almost certainly the dealer would be highway robbery. Its a real simple part that you could make up in 20-30 minutes out of $10 worth of steel and 4 bolts.
    3) No idea at all. I've been wondering myself off and on about what the thing will actually do. If it will reduce or eliminate the bad-traction bunny hop, it could be worth its weight in gold. I'm thinking that if the x-runner is the street racer-ish version tacoma, then you really would find the bunny hop to be murderous, so that would be my best guess.
  17. Aug 25, 2015 at 11:58 AM
    tgear.shead
    https://parts.olathetoyota.com/part...iteid=216493&vehicleid=314172&diagram=8512125
    The x-runner parts you would be interested in are numbered 8 and 9 in that diagram, plus the well known 11 which is the main rear brace.
    Edit, make that *only* 9 and 11. The diagram shows 8 as being x-runner only, but the part is present on other models as well, which means that it is only *different* for x-runner.
    Edit #2: also take a look at #5. That one is not present in other models.
    Edit #3: I see now... #5 isn't present on base 5-lug. Its present on all prerunner/4x4/xrunner. So it really is back to 9 and 11.
    Edit #4: Total price to add in all the x-runner braces from *factory* would be $421. Note that presence of a receiver hitch may interfere with the rear brace, and there is no telling if the front (which are actually in the middle of the truck) would fit at all. But like I said above, they would be very easy parts to reproduce.
  18. Aug 26, 2015 at 9:44 AM
    urban
    Illinois/Michigan
    Thanks so much!!! That's exactly what I wanted to see!
    So to confirm, just the one between 3 & 4 (9) and then the well known rear brace?
  19. Aug 27, 2015 at 12:20 PM
    tgear.shead
    I think so, as long as you know that there are *two* #9's that are mirror image of each other. One for the left side and one for the right.
  20. Aug 27, 2015 at 8:47 PM
    urban
    Illinois/Michigan
    yep yep, I figured that out :D
