Need information on 2.4 to 2.7 engine swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zach3rz, Mar 3, 2024.
  1. Mar 3, 2024 at 8:37 PM
    Zach3rz
    Zach3rz [OP] Well-Known Member
    Zach
    1997 toyota tacoma 2.7 3rz
    I purchased a 1997 Toyota tacoma with a 2.7 5 speed 4wd after countless hours of testing and reading other inputs from this group it turns out the previous owner put a 1997 2.4 2wd cab onto im assuming a 1997 4wd frame with a 2.7 the engine wire harness and and ecu is for the 3rz my issues at hand are the 2 plugs behind the glove box connecting the cabs wire harness to engine. The truck has no cel light with the key on and the obd2 does not connect to scan tools after fixing the wire that goes to c.o.r the truck runs but you can tell it is not 100 percent right just looking for information from someone who has put a 2.7 into a 2.4 truck so i can maybe figure out what wiring inside the truck or the outside needs to be fixed to get the truck back on the road.
    Bigd83 likes this.
  2. Mar 4, 2024 at 6:19 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Your going to need the schematics from all the vehicles involved and look at each circuit there are no short cuts.
    Each swap is always some what different .
    Your problem might be in the 4th ECM plug where the cab harness needs repinned to match the 2.7 ecm . Your ahead of the Game the engine even runs . Most likely the OBDII plug is not wired correct or not at all.
    Good Luck!!
    Zach3rz[QUOTED][OP] likes this.
  3. Mar 4, 2024 at 7:07 AM
    Zach3rz
    Zach
    I am assuming that is my issue the signal wire for obd plug is not in the correct pin on the plug for the 2.7 i will be checking that out thanks for the input
    Bivouac likes this.
  4. Mar 4, 2024 at 9:20 AM
    Bivouac
    Getting into the middle of a swap with no notes or information is about the worst Thing I let myself get into. You just need to take your time and if need be walk away if needed.
  5. Mar 4, 2024 at 10:23 AM
    Zach3rz
    Zach
    Believe me i have been exercising that i have had this truck for a year and just work on it here and there when i have some spare time to mess with it. Im trying to find a ecm pinout diagram for a 97 2.4 and a ecm pinout for a 97 2.7. Engine side harness looks good but plug e5 22 pin connector seems to be where alot of my issues are.
  6. Mar 4, 2024 at 11:14 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    I have a 98 2.4 that they put a 2.7 out of a 4runner in it...
    they never changed the ecm, and it ran just fine...
    I got it with a blown head gasket........
    2rz blocks are so readily available......I just stuck one of those back in, still runs fine....
    ......same ecm whole time.....
    However that was with the a43d Aisin tranny.....whole time....
    if the tranny switches to the a340 one, which is common in the 4x4's.....that ecm may not shift right....
    As far the OBDII port......mine will not connect unless engine is running and has always been that way.
  7. Mar 5, 2024 at 3:28 PM
    Zach3rz
    Zach
    I have tried the obd2 multiple ways and get no communication. The truck is a 5 speed so wont have to worry about transmission
    Bigd83 likes this.
  8. Mar 5, 2024 at 3:44 PM
    Clearwater Bill
    Billy
    Largo Florida
    So you have the underpinnings of a 6 lug truck with a 5 lug cab?
    And the originater didn't keep the 6 lug electronics ?
    Zach3rz[OP] likes this.
  9. Mar 5, 2024 at 9:15 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    pinouts atached
    Fatal_Paradox and Zach3rz[OP] like this.
  10. Mar 5, 2024 at 10:26 PM
    Zach3rz
    Zach
    Apparently he did not they must of thought it was plug and play since the cab harness plugs in with the rest of the harness but once you start looking at the wires you can see real fast that it is definitely not plug and play
    Bivouac likes this.
  11. Mar 5, 2024 at 10:34 PM
    Zach3rz
    Zach
    Is the 96 pin out the same as the 97? I have read over that pin out a little bit trying to piece it together but i have not tried anything yet hopefully this weekend i will have a little extra time to work on it
  12. Mar 5, 2024 at 11:46 PM
    O'Silver_Taco
    MD
  13. Mar 6, 2024 at 12:03 AM
    O'Silver_Taco
    MD
  14. Mar 6, 2024 at 4:16 AM
    Zach3rz
    Zach
    Well maybe the 2.7 is newer then i thought it has the twin coils but the ecm says 1997 i will check the pin outs posted and see if there similar to what i have
  15. Mar 8, 2024 at 10:30 PM
    O'Silver_Taco
    MD
    2.4's were switched over to twin coils.....mfg date 9/97 and on...
    making these 98 models.....
    Thats reason why vin is needed to order some parts if yours in built right at the model change border.....
  16. Mar 10, 2024 at 8:21 PM
    Zach3rz
    Zach
    The build month was 04 of 97 but as of right now i have the plugs to the computer re-pinned and have gained a check engine light with key on and i can now pull the codes up only thing it is showing is idle control valve issue and my bank 1 02 sensor is not reading and causing the fuel system to stay in OL
  17. Jul 28, 2024 at 3:25 PM
    Bigd83
    Bigd83 Active Member
    2000 sr5
    I have about the same problem. I recently bought a 2000 4wd with 2.7.... Only I just realized today someone swapped a 2.4 into it. It seems to run great. Only it's pretty weak and only gets 15mpg at best. So I took it to a mechanic a few days ago and found out the check engine light doesn't work. So he hooked his computer up and pulled up probably a dozen codes. Told me the A/f sensor was the best place to start because it was dead in the water. Some of the wiring has been taped, so idk if the sensor is bad, or just isn't connected properly. Its pushing way too much fuel. So much that I can smell it in my oil. Idk how its running so smooth. But it's way out of whack. So I'm wondering if I should try and find a harness for a 2.4?? And would I need a different pcm or do both engines use the same pcm with different harness? Not trying to butt in on the original... this just looked like a thread that i may get some kinda idea on what to do. At least it runs but 15 mpg is costing me quite a bit driving 150 miles a day to work.
  18. Aug 1, 2024 at 8:18 AM
    O'Silver_Taco
    MD
    When I bought mine it had the 2.4 replaced with the 2.7.
    It ran fine with that same ecm.....no difference.
    Same with the harness on the 2.4/2.7.....they are the same...
    only the auto and manual differ from each other.
    I would closely check the pcv valve and hose......if those fail it cause increased fuel and oil consumption.
    It may not hurt you to go in clean/check/ and maybe replace some of the engine sensors........maf.......1st oxy sensor
    You should be cleaning the maf sensor at least once a year anyways.....the wire sensor has dust and crap build up on it.
    No1 reason these run bad when they get old is weak battery connection/ground......and shot leaking vacuum hoses...
    Bigd83 likes this.
  19. Aug 1, 2024 at 4:59 PM
    Bigd83
    2000 sr5
    My 2000 4wd is 5 spd man. If the 2.4 that was put in it was connected to an auto trans how could I tell, and would it need different sensors? Also I couldn't find a pcv valve on it. Just a hose going to the valve cover where I thought there should be one.
  20. Aug 1, 2024 at 7:35 PM
    O'Silver_Taco
    MD
    It doesnt matter what the 2.4 was connected to before.....
    its the harness that makes or breaks the deal.......I assume they just dropped the engine into the old harness and engine bay...
    the 2000's may have the screw in pcv valve.......the 99's and older like mine use the grommet......which sucks and has to be replace every few years......so you dont get a massive secret vacuum leak.....
    definitely a trouble spot on the pre 00's..
    Bigd83 likes this.
