Need Info: Swapping a 2TRFE for a 1GRFE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RastaTaco, Nov 16, 2010.
  1. Nov 16, 2010 at 11:41 PM
    RastaTaco
    RastaTaco [OP] New Member
    South Padre Island TX
    06 2.7 4X4
    Level kit, BFG A/T
    The power of my 2.7 isnt cutting it after 2 years, I want to swap for a 1GR-FE but I need to know if it'll fit on my R155F Tranny??
  2. Nov 16, 2010 at 11:48 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Welcome to TW.com.
    You're better off just selling your truck and buying a truck with a V6. It involves more than just making sure it will fit your transmission.
    If you don't want to do that....you may want to look into putting a super charger in.
  3. Nov 16, 2010 at 11:57 PM
    RastaTaco
    06 2.7 4X4
    Level kit, BFG A/T
    Yeah I'v been considering trading it in, but im weighing my options.
  4. Nov 17, 2010 at 12:06 AM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Yeah I understand, we have a lot of members who made the mistake with buying the I4. Just wasn't the right match for them.
    You may also want to consider 'biting the bullet' and waiting until the new Tacoma comes out. I think it will come with a more powerful V6 Vs. the currant 2nd Gen.
    You could also consider re-gearing the diff, if torque/acceleration is an issue. But like I said, the super charger option could be good too.
    Have a good one.
  5. Nov 17, 2010 at 6:43 AM
    Quick_1911
    Quick_1911 Well-Known Member
    Brad
    Georgia
    08 Prerunner
    This could be interesting...Probably the first 4.0 Reg Cab Taco ever.
  6. Nov 17, 2010 at 7:43 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Dont quote me but I am pretty sure its not, but you can always go to 6 speed manuall which is better anyway
  7. Nov 17, 2010 at 9:24 AM
    RastaTaco
    06 2.7 4X4
    Level kit, BFG A/T
  8. Nov 17, 2010 at 9:28 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    if you get a wrecked donor truck it might not be that bad to do this swap. I found a wrecked truck with good power train for 5500. but itd besweet to have the 6 in my reg cab and part the unused stuff out. itd still be a big endevor
  9. Nov 17, 2010 at 9:41 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    regear instead?
  10. Nov 17, 2010 at 9:48 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Problem with regearing is because you get amazing low end you lose up top and is not all that freeway friendly
    Depoxy likes this.
  11. Feb 16, 2011 at 12:33 PM
    offrdwes
    offrdwes New Member
    wes
    sd
    07 prerunner regular cab 2.7l
    trd fron suspention with 3'' coil spacer lift, 31x10.5 bfg's,truck covers usa tanue cover, genuine gear g2 4.88 diff, afe dry intake, custom flowmaster catback,sony marine speakers in holes above fender wells, bed lights, add a leaf package, leghthend driveshaft because of lift.
    what superchargers are availible for the 2.7
    and would a turbo be a better option
  12. Feb 16, 2011 at 12:38 PM
    98tacoma27
    Ben
    Not Beech Creek
  13. Feb 16, 2011 at 12:41 PM
    offrdwes
    offrdwes New Member
    wes
    sd
    i havethought about putting the new 4.0 in my truck. i dont know if there would be different mounting holes or how much wireing harness there would be then needs to be changed but it seems like the best way to add hp. the 159hp from the 2.7 is great from that 4 banger but i need more power. i am affraid if i put a turbo or blower on it i will blow it up
    any ideas?:confused:
  14. Feb 16, 2011 at 12:59 PM
    98tacoma27
    Ben
    Not Beech Creek
    It's not going to blow up. Consider this to go to the 4.0:
    4.0 motor
    tranny (and possibly tc if 4x4)
    driveshaft (and possibly front if 4x4)
    engine harness
    ecu
    exhaust (including CATS and sensors)
    engine mounts (more than likely)
    .........that's just off the top of my head
    You would need all of that to do it properly.
    With time and $$$$$ anything is possible,
  15. Feb 16, 2011 at 1:05 PM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    If only they made a Reg Cab 4.0 :cool:
  16. Feb 16, 2011 at 1:05 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
  17. Feb 16, 2011 at 1:05 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    s/c, the 2.7 is an amazing motor for durability keep it
