Need help with wiring for the tekonsha p3
Discussion in 'Towing' started by Saechao503, Apr 15, 2019.
  1. Apr 15, 2019 at 4:16 PM
    Saechao503
    Saechao503 [OP] Well-Known Member
    Khae
    troutdale oregon
    2015 tacoma dc trd offroad
    I need help some wiring for my teknonsha p3 to the factory wiring harness. I just need to know which wires goes to which ones??
    Here's a picture of both of the plugs and wires. The stock harness has 5 wires but the p3 only has 4
  2. Apr 16, 2019 at 4:52 AM
    Cnasianfire
    Cnasianfire Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    The P3 should have labels on the wires or a diagram that states what each wire is. I know that the tacoma wiring harness has a diagram.
    Saechao503[OP] likes this.
  3. Apr 16, 2019 at 11:11 AM
    Mofirejeff
    Mofirejeff Well-Known Member
    Jeff
    Frankford, Missouri
    15 Gray DCSB 4x4
    Buy the adapter and it is just plug in. Makes it super easy.
    YF_Ryan and D2. like this.
  4. Apr 16, 2019 at 11:18 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    @Saechao503 , I second this. The adapter makes install effortless. Installed mine on 2nd gen in less than 10 min (and that included deciding where to mount the controller).
  5. Apr 16, 2019 at 3:16 PM
    Cnasianfire
    Charles
    Wilmington, NC
    I am thinking about getting this controller, where did you get the adapter
  6. Apr 16, 2019 at 3:31 PM
    YF_Ryan
    Kent, WA
  7. Apr 17, 2019 at 4:42 AM
    Cnasianfire
    Charles
    Wilmington, NC
  8. Apr 18, 2019 at 5:32 AM
    Mofirejeff
    Jeff
    Frankford, Missouri
    15 Gray DCSB 4x4
    Well worth it for ease of use and simplicity.
  9. Apr 29, 2019 at 4:36 PM
    HeyHoLet'sGo
    HeyHoLet'sGo Well-Known Member
    Kentucky
    2015 Black TRD Sport DCSB
    I bought the wiring harness for the Tekonsha brake controller and there's a ground wire. The instructions say to tie it to an already grounded wire but I can't find one near the plug in for this. Anyone have any advice that's done this before? It says if there's no existing ground to drill and screw it to the metal.
    It didn't come the screw it was supposed to, and I'd rather not drill into my truck anyway.
    Thanks for any advice on this!
  10. Apr 30, 2019 at 8:08 AM
    Mofirejeff
    Jeff
    Frankford, Missouri
    15 Gray DCSB 4x4
    There is a forum on this in the towing section. It shows which bolt to hook it to. It has pics in it. I looked at it and that made it simple. I’ll look back and see if l can find it. The bolt already is there, holding something else on. Just unscrew it put bolt thru ground wire piece and put right back.
  11. Apr 30, 2019 at 8:15 AM
    Mofirejeff
    Jeff
    Frankford, Missouri
    15 Gray DCSB 4x4
    Look up “Who has the Tekonsha P3 brake controller installed”. It was on page 3 of towing section. It showed where to hook the ground wire.
  12. Apr 30, 2019 at 4:34 PM
    HeyHoLet'sGo
    Kentucky
    Thanks for the info. The pic for the ground wire isn't great though. I think I found a good place for it, but I don't know a lot about wiring. There is another plastic plug with a bunch of wires connected to a bolt that's going into the metal. Is this a good place to put my ground wire? I don't want to put it in the wrong spot and end up frying something!
  13. May 1, 2019 at 4:54 AM
    Mofirejeff
    Jeff
    Frankford, Missouri
    15 Gray DCSB 4x4
    Not sure where you are talking about. It needs good metal to metal contact for the ground. I believe it said there are several bolts that could be used. Read the forum posts. I did a couple times. No problems after that.
  14. May 1, 2019 at 4:58 AM
    wtjl240
    wtjl240 Well-Known Member
    Jeff
    Spring Hill, TN
  15. May 1, 2019 at 5:10 AM
    Mofirejeff
    Jeff
    Frankford, Missouri
    15 Gray DCSB 4x4
    How did you put the direct link to it? I had to tell him the name of forum and page number. Thanks for your help.
  16. May 1, 2019 at 5:16 AM
    wtjl240
    Jeff
    Spring Hill, TN
    Click the post # of what you're trying to link to and paste it
  17. May 1, 2019 at 6:09 AM
    Mofirejeff
    Jeff
    Frankford, Missouri
    15 Gray DCSB 4x4
    Thank you
  18. May 1, 2019 at 5:50 PM
    HeyHoLet'sGo
    Kentucky
    Thanks for all the help! I've got the controller wired and mounted with velcro tape. Now I can't wait to pick up my brand new R Pod tomorrow!
  19. May 2, 2019 at 5:12 AM
    Mofirejeff
    Jeff
    Frankford, Missouri
    15 Gray DCSB 4x4
    I put mine in the little cubby hole. Nice and secure. Let’s see pics of it and your R Pod.
  20. May 2, 2019 at 5:21 AM
    Mofirejeff
    Jeff
    Frankford, Missouri
    15 Gray DCSB 4x4
    So much easier and nicer to do plug and play. I don’t usually have any luck splicing wires. Murphy’s Law takes over for me then.
