Need help with trimming fender and fender flares
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kevtaco209, Aug 3, 2023.
  1. Aug 3, 2023 at 10:12 PM
    Kevtaco209
    Kevtaco209 [OP] Member
    2nd gen taco
    Hi, I’m new to this tw. Pls let me know if I posted in the right forum.
    So I’m running 315/70 on my dcsb
    And I did the aggressive cmc and pinch weld mod. Now I need to trim the metal fender and fender flares. Anyone know someone or a shop in the Central Valley or Sacramento area that can do this. Thanks
  2. Aug 3, 2023 at 10:21 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Do it yourself, it's super simple. Remove your flares being careful not to break any clips or just order clips in advance cause they're prone to breaking. I use a jigsaw to make my cuts in sheet metal and a dremel for the flares. Rubber trim is used after cutting and will hide any imperfections in your cuts. I'll look up some threads for you and add them to this post as I find them.
    Clips: https://www.amazon.com/AUTOLA-75495-35010-75397-35010-Replacement-Exterior/dp/B07PYN8BGX?crid=HLEE3HJLTHZI&dchild=1&keywords=tacoma+fender+flare+clips&qid=1620068643&sprefix=tacoma+fender%2Caps%2C224&sr=8-6
    https://www.tacomaworld.com/threads/fender-trimming-so-many-people-so-little-info.401911/
  3. Aug 4, 2023 at 8:00 AM
    Kevtaco209
    2nd gen taco
    Right on. The toughest part is getting a good straight cut on the flares.
  4. Aug 4, 2023 at 11:20 AM
    UMC
    UMC I will not comply
    Thomas
    South Fork of the American river.
    13 TRD Sport DCLB 4x4
    35's & rear locker
    Stellar Built in Sacramento.
  5. Aug 9, 2023 at 3:51 PM
    Waitin4Snowfall
    Waitin4Snowfall Member
    South Lake Tahoe
    2015 TRD OR DCSB
    If you decide to try it yourself, I just cut my fender flares using a jigsaw with fine metal blade and the bed fenders for a hc bumper with an angle grinder and a metal cutting wheel. Went perfect.
    I'd stick with the jigsaw for both since you can get far more accurate cuts with it.
