Need help with removing steering wheel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kjf216, Dec 9, 2010.
  1. Dec 9, 2010 at 5:43 PM
    kjf216
    kjf216 [OP] Fitz
    Kyle
    Ridley Park, PA
    2016 Jeep Wrangler Sahara
    Head unit, speakers, LEDs
    So a few weeks back i had to have some work done to my truck and they pulled off my steering wheel and put in back on not straight so the wheel looks like im truning to the left when im going straight. I dont feel like dealing wiht the dealership again so i would rather just do it my self so can anyone explain how i would do that. pictures would be a great help.
    also talking with a buddy he was saying he has heard of air bag being set off where they didnt go off until the battery was reconnected, do i need to really worry about this?
    thanks for any advice
  2. Dec 9, 2010 at 7:00 PM
    elutheros
    elutheros Active Member
    Copperas Cove, TX
    07 Crew Cab
    Bike rack above bed Locking Fuel door
    Here's a link for the removal/installation of the steering wheel. Just be sure to park it with the wheels straight ahead when you start and keep the front wheels on the ground so they can't move when you are doing this.
    Do disconnect the battery negative cable--and if you have an alarm system have your remote in your hand when you reconnect when the job is done as the alarm will probably activate. Press unlock twice to silence it.
    After you get the airbag out by backing out the 2 Torx fasteners, I would suggest marking the current position of the steering wheel in relation to the shaft just so you have a reference point. You really don't need a puller to do this. You may have to do it a couple times to get it absolutely straight.
    for the airbag removal:
    Hope that helps.
  3. Dec 9, 2010 at 7:05 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    good stuff to know:)
  4. Dec 9, 2010 at 8:08 PM
    kjf216
    kjf216 [OP] Fitz
    Kyle
    Ridley Park, PA
    Thanks thats exactly what i was looking for
  5. Dec 10, 2010 at 12:20 AM
    JKD
    JKD Well-Known Member
    Are you *sure* that they removed and reinstalled the steering wheel, and didn't just perform an alignment that resulted in the steering wheel being off-center?
  6. Dec 10, 2010 at 12:32 AM
    cactuscorn
    cactuscorn Another FNG
    Rapid City, South Dakota
    2019 Cement TRD OR AT DCLB w/JBL Premium Package
    Ironman Stage 2 FCP 3" lift kit, Ironman skid plate kit, C4 Fab Hybrid front bumper and frame supports, C4 Fab sliders, Smittybuilt X2O 10k lb winch, Diode Dynamics Pro fogs, Baja Designs Sport fogs, Falken Rubitrek AT's, Midland Micro MXT275 GMRS radio, Victory 4x4 hood hinge antenna mount, ARE MX shell, 12 Volt Solutions remote starter w/ phone app module, Overland Equipped aux power tray/Blue Sea 12 circut ST blade fuse block w/ 187 series 100a circut breaker, OEM bedmat and floor mats, Hooke Road tailgate cover, JDM ASTAR 800 lumen LED reverse bulbs, iOttie wireless phone charger, blue LED dome light, back seat dog bed and rear seat12v/USB ports, Ironman diff breather, ac drain mod,, tons of rad recovery equipment and every cubbyhole filled with crap. On order: Method MR 316 wheels and 285/70R/17 BFG KO2's.
    bingo! or a steering shaft tsb?
  7. Dec 10, 2010 at 3:16 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    usually the factory has a mark on the steering wheel so if you remove the airbag you can see if they really did remove the steering wheel.
  8. Feb 3, 2013 at 1:40 AM
    Angelalorenzo
    Angelalorenzo Member
    Angela
    2000 Toyota Tacoma regular cab pick-up
    Has anyone replaced a steering wheel from a 2000 Tacoma pick-up? When replacing the steering wheel with an after-market one, can the black piece be removed from underneath the steering wheel? (Black piece that has the airbag and horn connecter)...only because I can't fit the after-market steering wheel kit for the '96-'04. THANK YOU in advance...
  9. Apr 16, 2014 at 10:47 AM
    bruth
    bruth Well-Known Member
    Brian
    Alamo ca
    2000 access cab 4x4 Tacoma
    Total chaos is currently shipping
    Have you found out how to do this yet? I want to put a quick release whe on mine with no airbag
