Need help with PAC SWI-RC **FIXED**
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Strictlytoyz, Sep 10, 2015.
  1. Sep 10, 2015 at 5:26 PM
    Strictlytoyz
    Strictlytoyz [OP] Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    So i just recently purchased an aftermarket kenwood stereo which came with a SWI-RC steering wheel control interface. I followed all of the directions and cant seem to figure out how to program it. It turns on i just can't get it to work. I spliced the white wire to the wire in pin 7 on the stock plug and the white/black to the wire in pin 8. Any tips would be greatly appreciated.
  2. Sep 10, 2015 at 6:27 PM
    Northof62
    Northof62 Active Member
    Alaska
    2015 4x4 AC 6cl
    Toytec Boss 3" LR UCA 265/75 Toyo AT2 Blue Seas Fuse Panel Rear Diff Breather Mod After Market Stereo
    I have been trying to get mine to work for awhile. I'm thinking of throwing it in the trash and buying the Metra which I believe is plug and play, no splicing or soldering in resistors.
  3. Sep 10, 2015 at 7:20 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Gonna try something out tomorrow. Ill let you know if it works
  4. Sep 10, 2015 at 8:05 PM
    Northof62
    Alaska
    2015 4x4 AC 6cl
    Thanks!
  5. Sep 11, 2015 at 2:24 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Well once again no luck..you have a link to the metra kit you were thinking of getting?
  6. Sep 11, 2015 at 8:03 PM
    Northof62
    Alaska
    2015 4x4 AC 6cl
  7. Sep 11, 2015 at 11:30 PM
    DaveB.inVa
    DaveB.inVa Well-Known Member
    SWVa
    2015 AC SR5 4x4 V6 AT MGM
    Oil Catch Can, OIl Pressure and Temp Gauges, Falken Wildpeak A/T3W 265/70R16
    http://www.crutchfield.com/p_120708114/Metra-70-8114-Steering-Wheel-Control-Harness.html
    http://www.crutchfield.com/p_120ASWC1/Axxess-ASWC-1-Steering-Wheel-Control-Adapter.html
    This is what you need. I've not done my Tacoma yet but have a radio and harness made up sitting on my kitchen table.
    You can make the ASWC-1 do whatever you want if you don't like the factory setup. Programming is tedious but it is very flexible. If there is a function that your radio supports and you don't have a button that does it, you can reassign buttons to perform that function.
    You can put just about any resistor combination in and build controls if you want and make this recognize it. I added controls to my Dodge Ram and went totally away from the factory setup as it relied on a data connection that the dealer would have to program, so the controls would send a signal to the truck can-bus system and then to the ASWC-1. Most dealers didn't know how to do this and said what I was trying to do couldn't be done, so I just cut out the middle man and everything works perfectly.
  8. Sep 12, 2015 at 5:04 AM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Ive seen how easy it is to install the axxess and how it self programs but to pay 80 dollars? Would be nice to have seering wheel controls but not at that price
  9. Sep 12, 2015 at 6:30 AM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    So after countless different methods i decided to just take the chance and cut the harness off. Ended up crimping the wires srraight to eachother and now it works perfect. No delays on the buttons to the reciever. Pretty happy i got it to work. Persistence = success
    Northof62 likes this.
  10. Dec 5, 2015 at 10:17 PM
    Turdsport
    Turdsport Well-Known Member
    Josh
    '14 TRD Sport Supercharged
    I just got my kenwood/pac in the mail yesterday. So you're saying you cut the wires at the factory harness and straightwired them? I gotta say that I'm pretty good at wiring, but reading through these directions is a little confusing. I mean damn, can a guy get some pictures?
  11. Dec 24, 2015 at 6:10 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Sorry for such a late reply. Did you get it to work?
  12. Dec 24, 2015 at 6:37 PM
    Turdsport
    Josh
    Yes I did. Wasn't too bad. Still have to figure out the back up cam.
  13. Jan 3, 2016 at 9:37 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    The factory backup cam?
