NEED HELP WITH OBD2 code p0101
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Erick896, Dec 10, 2015.
  1. Dec 10, 2015 at 2:39 PM
    Erick896
    Erick896 [OP] New Member
    2008 Tacoma Trd sport
    is it possible that just cleaning my MAF sensor and PCV valve would fix the engine light problem on my Toyota Tacoma or what I need to get a whole new MAF sensor and PCV valve
  2. Dec 10, 2015 at 5:31 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This is what causes the error:
    MONITOR DESCRIPTION
    The MAF meter is a sensor that measures the amount of air flowing through the throttle valve. The ECM uses this information to determine the fuel injection time and to provide an appropriate air-fuel ratio. Inside the MAF meter, there is a heated platinum wire which is exposed to the flow of intake air. By applying a specific electrical current to the wire, the ECM heats it to a specific temperature. The flow of incoming air cools both the wire and an internal thermistor, affecting their resistance. To maintain a constant current value, the ECM varies the voltage applied to these components of the MAF meter. The voltage level is proportional to the airflow through the sensor, and the ECM uses it to calculate the intake air volume. If there is a defect in the sensor, or an open or short in the circuit, the voltage level deviates from the normal operating range. The ECM interprets this deviation as a malfunction in the MAF meter and sets the DTC.
    Example:
    If the voltage is more than 2.2 V, or less than 0.83 V while idling, the ECM determines that there is a malfunction in the MAF meter and sets the DTC.
    The service manual says IF you have other codes to troubleshoot them first.
    Then goes on to say if you have no other codes to replace the Mass Flow Sensor.
    You may need to replace the PVC Valve but it has nothing to do with the code P0101.
